[pdal-commits] [PDAL/PDAL] c49c71: Don't resize the buffer for every chunk if its cap...
GitHub noreply at github.com
Fri Feb 1 13:40:37 PST 2013
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: c49c71700f5a8d512e70eb37a49a0e58ca0b6969
      https://github.com/PDAL/PDAL/commit/c49c71700f5a8d512e70eb37a49a0e58ca0b6969
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2013-02-01 (Fri, 01 Feb 2013)
  Changed paths:
    M src/Writer.cpp
  Log Message:
  Don't resize the buffer for every chunk if its capacity is != the number of points to read per chunk (just make sure it is big enough. Allocate the size of the Writer's buffer to be the min(num_to_write, def_chunk_size) if num_to_write is not 0
  Commit: 2b7ac4c78deee691c7745e5caebdce26e1e4aaea
      https://github.com/PDAL/PDAL/commit/2b7ac4c78deee691c7745e5caebdce26e1e4aaea
  Changed paths:
    M include/pdal/Stage.hpp
    M src/Stage.cpp
  Log Message:
  getNumPoints caches the previous stage's point count if it is expected to forward it instead of asking the entire pipeline every time for the point count
Compare: https://github.com/PDAL/PDAL/compare/af26f96af18f...2b7ac4c78dee
More information about the pdal-commits mailing list
