[pdal-commits] [PDAL/PDAL] 50772e: optional use of static runtime will be more helpfu...
GitHub noreply at github.com
Fri Jun 7 09:30:35 PDT 2013
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 50772ec6e71dd3d70da5589a8df5ebd23f0792fd
      https://github.com/PDAL/PDAL/commit/50772ec6e71dd3d70da5589a8df5ebd23f0792fd
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2013-06-06 (Thu, 06 Jun 2013)
  Changed paths:
    M CMakeLists.txt
    M src/gitsha.cpp
  Log Message:
  optional use of static runtime will be more helpful if it is tested
  Commit: 76c2da5f07d6138a0ce61def30b78e0e58859763
      https://github.com/PDAL/PDAL/commit/76c2da5f07d6138a0ce61def30b78e0e58859763
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2013-06-07 (Fri, 07 Jun 2013)
  Changed paths:
    M CMakeLists.txt
    M src/gitsha.cpp
  Log Message:
  Merge pull request #137 from chambbj/static-runtime-bug
Compare: https://github.com/PDAL/PDAL/compare/e6d1613cdfd7...76c2da5f07d6
More information about the pdal-commits mailing list
