[pdal-commits] [PDAL/PDAL] 08b51e: use BOOST_CHECK_EQUAL for checking in tests
GitHub noreply at github.com
Wed Mar 20 12:14:16 PDT 2013
  Branch: refs/heads/vectorize-lasreader
  Home:   https://github.com/PDAL/PDAL
  Commit: 08b51e2dd476042bcd7223dfcbd0c61b2d6ebb3c
      https://github.com/PDAL/PDAL/commit/08b51e2dd476042bcd7223dfcbd0c61b2d6ebb3c
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2013-03-17 (Sun, 17 Mar 2013)
  Changed paths:
    M test/unit/drivers/las/LasReaderTest.cpp
  Log Message:
  Commit: 8f8977ba948a1ec10b083f7d948a83ebf68cf6b4
      https://github.com/PDAL/PDAL/commit/8f8977ba948a1ec10b083f7d948a83ebf68cf6b4
  Changed paths:
    M test/unit/filters/CacheFilterTest.cpp
  Log Message:
  Commit: b9111096e044bd1f46f25fd163ba9d8bf3708a56
      https://github.com/PDAL/PDAL/commit/b9111096e044bd1f46f25fd163ba9d8bf3708a56
  Changed paths:
    M test/unit/Support.cpp
  Log Message:
  use BOOST_CHECK_CLOSE instead of our own Compare function
  Commit: da1818e3bac7d1ed61150e4b65ccf72b6967b482
      https://github.com/PDAL/PDAL/commit/da1818e3bac7d1ed61150e4b65ccf72b6967b482
  Changed paths:
    M include/pdal/PointBuffer.hpp
    M src/PointBuffer.cpp
  Log Message:
  provide a defaulted optional 'exact' switch to resize to force a resize of the PointBuffer even if current capcity is larger than the requested capacity
  Commit: 199785ab1068e78a3795b9d783a03fbf9305a1a0
      https://github.com/PDAL/PDAL/commit/199785ab1068e78a3795b9d783a03fbf9305a1a0
  Changed paths:
    M include/pdal/filters/Chipper.hpp
  Log Message:
  method to return chipper threshold
  Commit: 06ceb5bb78f76d0f78b08a97974af31f70ac289f
      https://github.com/PDAL/PDAL/commit/06ceb5bb78f76d0f78b08a97974af31f70ac289f
  Date:   2013-03-19 (Tue, 19 Mar 2013)
  Changed paths:
    M include/pdal/filters/PointBufferCache.hpp
  Log Message:
  add method to return number of objects in cache
  Commit: b5b9d54b7bd9a52f1823c2bdca36502e865cbeb5
      https://github.com/PDAL/PDAL/commit/b5b9d54b7bd9a52f1823c2bdca36502e865cbeb5
  Changed paths:
  Log Message:
  move cache testing into CacheFilterTeset
  Commit: 18d4888acc7f7ec12e45b917fa109fbf756f6f9a
      https://github.com/PDAL/PDAL/commit/18d4888acc7f7ec12e45b917fa109fbf756f6f9a
  Changed paths:
    M src/filters/Chipper.cpp
  Log Message:
  force a resize of the PointBuffer's capacity to the chipper's threshold when constructing the sequential filter
  Commit: 59e0ecc267d2e1cac276d76b93f799353457a1e7
      https://github.com/PDAL/PDAL/commit/59e0ecc267d2e1cac276d76b93f799353457a1e7
  Changed paths:
    M include/pdal/filters/Cache.hpp
    M src/filters/Cache.cpp
  Log Message:
  sequential filters.cache working for block-based reads
  Commit: cc6823bc6dfe8e88f03320e61cf7b84c8123f564
      https://github.com/PDAL/PDAL/commit/cc6823bc6dfe8e88f03320e61cf7b84c8123f564
  Changed paths:
  Log Message:
  make IteratorBase class to contain common methods for filters.cache iterators
  Commit: 2036ec78996faf5661dc2ef1d3250e376e3a62d6
      https://github.com/PDAL/PDAL/commit/2036ec78996faf5661dc2ef1d3250e376e3a62d6
  Changed paths:
  Log Message:
  random iterator mostly working
  Commit: b0cfc2b776dc3382e9490c123fd122dfb1a83b46
      https://github.com/PDAL/PDAL/commit/b0cfc2b776dc3382e9490c123fd122dfb1a83b46
  Changed paths:
  Log Message:
  account for situations where you're requesting the very first point
  Commit: bfe32964ad226f820bd68fba897ee673072d9673
      https://github.com/PDAL/PDAL/commit/bfe32964ad226f820bd68fba897ee673072d9673
  Changed paths:
  Log Message:
  stop here, cache filter tests pass at least
  Commit: 6c3ad5417a46a85e0065f824dd688746141929f6
      https://github.com/PDAL/PDAL/commit/6c3ad5417a46a85e0065f824dd688746141929f6
  Date:   2013-03-20 (Wed, 20 Mar 2013)
  Changed paths:
    M test/unit/filters/ChipperTest.cpp
  Log Message:
  don't create the one_point PointBuffer for every point, initialize RandomIterator with it
  Commit: 49010faa2f7ef9cf260c64e7eff2abb0022d9e53
      https://github.com/PDAL/PDAL/commit/49010faa2f7ef9cf260c64e7eff2abb0022d9e53
  Changed paths:
    M test/data/oracle/cleanup.sql
  Log Message:
  fix up table name
  Commit: 8ee881279bd84f21e901cc0ecc4bd9df68ef741d
      https://github.com/PDAL/PDAL/commit/8ee881279bd84f21e901cc0ecc4bd9df68ef741d
  Changed paths:
  Log Message:
  nuke the map every block read -- will make a map of these for inserts
  Commit: 0918a2f69f72e396bd0cf173896ae0197f9049ba
      https://github.com/PDAL/PDAL/commit/0918a2f69f72e396bd0cf173896ae0197f9049ba
  Changed paths:
  Log Message:
  fix up chpper to not create one_point every time through
  Commit: aa42119a263a4b5030c9a43b8ed98758d79973fb
      https://github.com/PDAL/PDAL/commit/aa42119a263a4b5030c9a43b8ed98758d79973fb
  Changed paths:
  Log Message:
  reset dimension map every read()
  Commit: 6e71d7a05b6fb7e1239fbc9cf985641e5491b769
      https://github.com/PDAL/PDAL/commit/6e71d7a05b6fb7e1239fbc9cf985641e5491b769
  Changed paths:
  Log Message:
  keep a map of dimension maps for per-cached block lookups
Compare: https://github.com/PDAL/PDAL/compare/b0fc9a674db9...6e71d7a05b6f
More information about the pdal-commits mailing list
