[pdal-commits] [PDAL/PDAL] c69e49: fix up cpack configuration to have a 'make dist' c...
GitHub noreply at github.com
Wed Nov 13 12:05:14 PST 2013
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: c69e49f83468ce62612666f6c76a41597519a902
      https://github.com/PDAL/PDAL/commit/c69e49f83468ce62612666f6c76a41597519a902
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2013-11-13 (Wed, 13 Nov 2013)
  Changed paths:
    M CMakeLists.txt
    R VERSION.txt
    R apps/pdalinfo.cpp
    R config.bat
    A mpg-config.bat
    R test/data/apps/pdainfo_stats-win32.txt
    A test/data/apps/pdalinfo_stats-win32.txt
    A test/data/soci/sthelens-write.xml
  Log Message:
  fix up cpack configuration to have a 'make dist' command after configuration #204
  Commit: 7e661bc171b5485c4a63b40242567a9638afeb17
      https://github.com/PDAL/PDAL/commit/7e661bc171b5485c4a63b40242567a9638afeb17
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M CMakeLists.txt
    R VERSION.txt
    R apps/pdalinfo.cpp
    R config.bat
    A mpg-config.bat
  Log Message:
  Merge pull request #204 from PDAL/issues/204-cpack-configuration
Beef up packaging and install scripts
Compare: https://github.com/PDAL/PDAL/compare/b0e75dc8a8f9...7e661bc171b5
More information about the pdal-commits mailing list
