[pdal-commits] [PDAL/PDAL] 7b4927: add note for #177
GitHub noreply at github.com
Thu Oct 3 13:56:06 PDT 2013
  Branch: refs/heads/issues/176-PointBuffer-index
  Home:   https://github.com/PDAL/PDAL
  Commit: 7b492774d98c29a4bddb9fb36742e5ebb2769641
      https://github.com/PDAL/PDAL/commit/7b492774d98c29a4bddb9fb36742e5ebb2769641
  Author: Howard Butler <howard at hobu.co>
  Date:   2013-09-06 (Fri, 06 Sep 2013)
  Changed paths:
    M include/pdal/filters/Scaling.hpp
  Log Message:
  add note for #177
  Commit: 2583251ecb174baf35dea1de277c0b3ea8c5f3b0
      https://github.com/PDAL/PDAL/commit/2583251ecb174baf35dea1de277c0b3ea8c5f3b0
  Author: James Klassen <klas0037 at umn.edu>
  Date:   2013-09-11 (Wed, 11 Sep 2013)
  Changed paths:
    M src/Schema.cpp
  Log Message:
  Fix schema operator== comparing self with self and always returning true.
  Commit: 4f339a32734fd734745708273f6aa221b08c32c8
      https://github.com/PDAL/PDAL/commit/4f339a32734fd734745708273f6aa221b08c32c8
  Changed paths:
    M src/Schema.cpp
  Log Message:
  Merge pull request #178 from klassenjs/master
Fix schema operator== comparing self with self and always returning true...
  Commit: 2c67af5bc3780309c04e5ed721d1f732c481029a
      https://github.com/PDAL/PDAL/commit/2c67af5bc3780309c04e5ed721d1f732c481029a
  Date:   2013-09-16 (Mon, 16 Sep 2013)
  Changed paths:
    M include/pdal/filters/Chipper.hpp
    M src/filters/Chipper.cpp
  Log Message:
  clean up used memory
  Commit: 8d5a3196ad5f82c5e53d75bbd094accd6c37243c
      https://github.com/PDAL/PDAL/commit/8d5a3196ad5f82c5e53d75bbd094accd6c37243c
  Changed paths:
    M src/drivers/las/Reader.cpp
  Log Message:
  properly size buffer when point count is large #123
  Commit: 8704462a276266def6462a91d8b5fc2b1c1e403d
      https://github.com/PDAL/PDAL/commit/8704462a276266def6462a91d8b5fc2b1c1e403d
  Changed paths:
    M boost/boost/functional/hash/detail/hash_float.hpp
  Log Message:
  silence annoying warning now that boost is not a SYSTEM include again
  Commit: ac764af05d21460c7b6a8d56607b269204aae4d7
      https://github.com/PDAL/PDAL/commit/ac764af05d21460c7b6a8d56607b269204aae4d7
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2013-09-17 (Tue, 17 Sep 2013)
  Changed paths:
    M CMakeLists.txt
    A cmake/modules/FindSQLite3.cmake
    M include/pdal/drivers/soci/Writer.hpp
    M include/pdal/drivers/soci/common.hpp
    M include/pdal/third/nanoflann.hpp
    M src/CMakeLists.txt
    M src/drivers/soci/Writer.cpp
    M test/unit/CMakeLists.txt
    A test/unit/drivers/soci/Writer.cpp
  Log Message:
  working drivers.soci.writer for #180
  Commit: b9bf12a73efc7fd881b1e258d58ac64153e24e31
      https://github.com/PDAL/PDAL/commit/b9bf12a73efc7fd881b1e258d58ac64153e24e31
  Changed paths:
  Log Message:
  don't run soci test if no soci around
  Commit: 8468e4ffdfcf37cbc13f7727596be32de5b5a5c1
      https://github.com/PDAL/PDAL/commit/8468e4ffdfcf37cbc13f7727596be32de5b5a5c1
  Date:   2013-09-18 (Wed, 18 Sep 2013)
  Changed paths:
  Log Message:
  Commit: f0b290589ed171046d54f24a4d7db3cc03263fac
      https://github.com/PDAL/PDAL/commit/f0b290589ed171046d54f24a4d7db3cc03263fac
  Date:   2013-09-19 (Thu, 19 Sep 2013)
  Changed paths:
    M include/pdal/PointBuffer.hpp
    M include/pdal/filters/Colorization.hpp
    M include/pdal/filters/Crop.hpp
    M include/pdal/filters/InPlaceReprojection.hpp
    M src/PointBuffer.cpp
    M src/filters/Colorization.cpp
    M src/filters/Crop.cpp
    M src/filters/InPlaceReprojection.cpp
    M src/filters/Index.cpp
    M test/unit/PointBufferTest.cpp
  Log Message:
  Merge branch 'issues/177-scaling-filter'
  Commit: 756fffbd298c1524c06aaa23211f371329ad0e03
      https://github.com/PDAL/PDAL/commit/756fffbd298c1524c06aaa23211f371329ad0e03
  Date:   2013-09-20 (Fri, 20 Sep 2013)
  Changed paths:
  Log Message:
  clean up definition of buffer's byte sizes to use a single typedef instead of uint64_t's
  Commit: 6023c12b93998cc44996c46600c778b2a4e75208
      https://github.com/PDAL/PDAL/commit/6023c12b93998cc44996c46600c778b2a4e75208
  Date:   2013-09-23 (Mon, 23 Sep 2013)
  Changed paths:
    M src/filters/Cache.cpp
  Log Message:
  clean up dimension maps when destructing filters.cache iterator
  Commit: 2ce11e18c969143e19eb87e979ab5a68dae7804b
      https://github.com/PDAL/PDAL/commit/2ce11e18c969143e19eb87e979ab5a68dae7804b
  Changed paths:
    M src/drivers/las/SummaryData.cpp
  Log Message:
  turn off return number data checks for now
  Commit: ffe49c508780c3c393a476219f2535a40ffe8d8e
      https://github.com/PDAL/PDAL/commit/ffe49c508780c3c393a476219f2535a40ffe8d8e
  Changed paths:
  Log Message:
  clean up PointBuffer's byte size calculations to be more clear
  Commit: 61489f28eb1686464dd75674fb54e05adbd68088
      https://github.com/PDAL/PDAL/commit/61489f28eb1686464dd75674fb54e05adbd68088
  Changed paths:
    M src/Writer.cpp
  Log Message:
  merge 01c84eb5ebc2314c3afbae66e6c7db01a85b2c74 into master make sure to writeBufferBegin, even if we're not writing any points, so we can write 0-point files
Conflicts:
	src/Writer.cpp
  Commit: cc7ff7ff3b75b82318aabef45d9e37eab3fbf47f
      https://github.com/PDAL/PDAL/commit/cc7ff7ff3b75b82318aabef45d9e37eab3fbf47f
  Changed paths:
  Log Message:
  can't call methods until we're actually constructed
  Commit: 7834135058a9a8b327b6916c15c83dda1ba91b0e
      https://github.com/PDAL/PDAL/commit/7834135058a9a8b327b6916c15c83dda1ba91b0e
  Date:   2013-09-26 (Thu, 26 Sep 2013)
  Changed paths:
  Log Message:
  turn off radiusSearch because it is causing Travis to fail
  Commit: 9dba0d400fcda5c8827e14a77ea0d1ff48fa06d1
      https://github.com/PDAL/PDAL/commit/9dba0d400fcda5c8827e14a77ea0d1ff48fa06d1
  Changed paths:
    M test/unit/filters/CacheFilterTest.cpp
  Log Message:
  add large cache example (but mostly turned off for now due to the memory allocation taking forever
  Commit: d80934a4d7e8b5b8acb95050bf9773bfe1462fee
      https://github.com/PDAL/PDAL/commit/d80934a4d7e8b5b8acb95050bf9773bfe1462fee
  Changed paths:
    M src/Writer.cpp
  Log Message:
  Merge branch 'master' into issues/180-sqlite-driver
  Commit: 24a0d430aba7f73329a4477fca9fecefd36bc2e3
      https://github.com/PDAL/PDAL/commit/24a0d430aba7f73329a4477fca9fecefd36bc2e3
  Date:   2013-09-27 (Fri, 27 Sep 2013)
  Changed paths:
  Log Message:
  some interprocess scaffolding, nothing done yet
  Commit: 43fa812bbe14ca3580ccfff5893d938b3b59a232
      https://github.com/PDAL/PDAL/commit/43fa812bbe14ca3580ccfff5893d938b3b59a232
  Author: Mateusz Loskot <mateusz at loskot.net>
  Date:   2013-09-29 (Sun, 29 Sep 2013)
  Changed paths:
  Log Message:
  Do not ignore non-existent variables
Fix build issue reported on IRC by Massimo Di Stefano
  Commit: 06ba110c9a1b5696e6147243ebcf89fefcb104b2
      https://github.com/PDAL/PDAL/commit/06ba110c9a1b5696e6147243ebcf89fefcb104b2
  Date:   2013-10-01 (Tue, 01 Oct 2013)
  Changed paths:
  Log Message:
  never add to cache from random iterator
Conflicts:
  Commit: 5c43edd66733a7d86d5130ae8a8f4c003f9dd284
      https://github.com/PDAL/PDAL/commit/5c43edd66733a7d86d5130ae8a8f4c003f9dd284
  Changed paths:
  Log Message:
  tighten up the 64bit calculations for PointBuffer offsets
  Commit: 13b11f25f6ce440f19f6a75d6060e0d0542940c0
      https://github.com/PDAL/PDAL/commit/13b11f25f6ce440f19f6a75d6060e0d0542940c0
  Changed paths:
  Log Message:
  make sure to use 64bit math for calculating buffer position when reading data
  Commit: e5e3a7a1ae67cd6cd894e05cb57ab83a9342e4f0
      https://github.com/PDAL/PDAL/commit/e5e3a7a1ae67cd6cd894e05cb57ab83a9342e4f0
  Changed paths:
  Log Message:
  Merge branch 'master' into issues/181-boost-interprocess-pointbuffer
Conflicts:
  Commit: 1c167cdf61da0c356e3d2753710174cef528abe3
      https://github.com/PDAL/PDAL/commit/1c167cdf61da0c356e3d2753710174cef528abe3
  Changed paths:
    M include/pdal/filters/Cache.hpp
    M src/drivers/buffer/Reader.cpp
  Log Message:
  put DimensionMap and PointBufferByteSize into a pointbuffer:: namespace
  Commit: 2224aa76d7543c18957d74f256ac21630a03acbe
      https://github.com/PDAL/PDAL/commit/2224aa76d7543c18957d74f256ac21630a03acbe
  Date:   2013-10-02 (Wed, 02 Oct 2013)
  Changed paths:
    M include/pdal/GlobalEnvironment.hpp
  Log Message:
  a map to keep track of globally allocated memory segments
  Commit: 760d3eca3f0b564421a88d0d8eb36fd679d846a5
      https://github.com/PDAL/PDAL/commit/760d3eca3f0b564421a88d0d8eb36fd679d846a5
  Changed paths:
    M CMakeLists.txt
  Log Message:
  quote path names for #182
  Commit: 68ae933c4637564a351191f17e7497fa48e2e918
      https://github.com/PDAL/PDAL/commit/68ae933c4637564a351191f17e7497fa48e2e918
  Changed paths:
    M CMakeLists.txt
  Log Message:
  include_directories can't have empty strings, so unquote those for now
  Commit: 08fbaf4d839c6a52014e3b12d8823a41922e737f
      https://github.com/PDAL/PDAL/commit/08fbaf4d839c6a52014e3b12d8823a41922e737f
  Changed paths:
    M include/pdal/drivers/pgpointcloud/Reader.hpp
  Log Message:
  fix pdal::poitncloud::DimensionMap member variable for rename in #181
  Commit: 1f9f4b99ec051454eafd2b2338ff4d558322e501
      https://github.com/PDAL/PDAL/commit/1f9f4b99ec051454eafd2b2338ff4d558322e501
  Changed paths:
  Log Message:
  typo'd 08fbaf4d839c6a52014e3b12d8823a41922e737f
  Commit: adab5211f12b15f5a359cd8f13c0758995067756
      https://github.com/PDAL/PDAL/commit/adab5211f12b15f5a359cd8f13c0758995067756
  Date:   2013-10-03 (Thu, 03 Oct 2013)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #182 from PDAL/issues/182-cmake-cleanup
Complete quoting for parameters of some CMake commands
  Commit: bce00e703e48c637a2b20100a90623d74e249338
      https://github.com/PDAL/PDAL/commit/bce00e703e48c637a2b20100a90623d74e249338
  Changed paths:
    M CMakeLists.txt
  Log Message:
Conflicts:
	src/CMakeLists.txt
  Commit: 5d962bd3785d73bfef17b4f180702ee6be3e624e
      https://github.com/PDAL/PDAL/commit/5d962bd3785d73bfef17b4f180702ee6be3e624e
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #180 from PDAL/issues/180-sqlite-driver
Update drivers.soci.writer to write into sqlite databases
  Commit: d37e7916e2e18041ba88ef658d7ccdfc5041364f
      https://github.com/PDAL/PDAL/commit/d37e7916e2e18041ba88ef658d7ccdfc5041364f
  Changed paths:
    M hobu-config.sh
    M test/unit/drivers/oci/OCITest.cpp
    M test/unit/drivers/soci/Writer.cpp
  Log Message:
  lingering sqlite writer fixups
  Commit: 986d4bad54fc7e93f4e5bf2e7048db0744e2f6d4
      https://github.com/PDAL/PDAL/commit/986d4bad54fc7e93f4e5bf2e7048db0744e2f6d4
  Changed paths:
    M CMakeLists.txt
  Log Message:
  make numpy required when WITH_PYTHON is selected #184
  Commit: 10d34a403e6141a347d2ce35556c40c13aa9b7cd
      https://github.com/PDAL/PDAL/commit/10d34a403e6141a347d2ce35556c40c13aa9b7cd
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #184 from PDAL/issues/184-required-numpy
CMake doesn't die when USE_PYTHON=ON and NumPy is not found
  Commit: 5c0d345b677d3cb6a54e91ddbea9a4e7e4777fdd
      https://github.com/PDAL/PDAL/commit/5c0d345b677d3cb6a54e91ddbea9a4e7e4777fdd
  Changed paths:
    M CMakeLists.txt
    M hobu-config.sh
    M src/Schema.cpp
    M src/Writer.cpp
  Log Message:
  Merge branch 'master' into issues/176-PointBuffer-index
Conflicts:
	src/PointBuffer.cpp
Compare: https://github.com/PDAL/PDAL/compare/fbffc84a7b96...5c0d345b677d
More information about the pdal-commits mailing list
