[pdal-commits] [PDAL/PDAL] a722d2: remove remaining refernces to boost standard integ...
GitHub noreply at github.com
Wed Dec 3 10:01:18 PST 2014
  Branch: refs/heads/remove-boost-cstdint
  Home:   https://github.com/PDAL/PDAL
  Commit: a722d2b88d448c5cc699a7a9237e5041d98045c1
      https://github.com/PDAL/PDAL/commit/a722d2b88d448c5cc699a7a9237e5041d98045c1
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-12-03 (Wed, 03 Dec 2014)
  Changed paths:
    M filters/chipper/ChipperFilter.cpp
    M filters/chipper/ChipperFilter.hpp
    M filters/colorization/ColorizationFilter.hpp
    M include/pdal/FileUtils.hpp
    M include/pdal/KDIndex.hpp
    M include/pdal/PipelineReader.hpp
    M include/pdal/Stage.hpp
    M include/pdal/StreamFactory.hpp
    M include/pdal/Utils.hpp
    M include/pdal/filters/Stats.hpp
    M include/pdal/pdal_internal.hpp
    M include/pdal/plang/Invocation.hpp
    M io/bpf/BpfReader.cpp
    M io/faux/FauxReader.cpp
    M io/las/LasReader.cpp
    M io/las/LasWriter.hpp
    M io/terrasolid/TerrasolidReader.cpp
    M io/text/TextWriter.cpp
    M kernels/Application.hpp
    M kernels/Kernel.cpp
    M kernels/Kernel.hpp
    M kernels/delta/DeltaKernel.cpp
    M kernels/delta/DeltaKernel.hpp
    M kernels/diff/DiffKernel.cpp
    M kernels/info/InfoKernel.cpp
    M kernels/info/InfoKernel.hpp
    M kernels/random/RandomKernel.cpp
    M kernels/random/RandomKernel.hpp
    M kernels/sort/SortKernel.cpp
    M kernels/translate/TranslateKernel.cpp
    M plugins/icebridge/io/Hdf5Handler.cpp
    M plugins/icebridge/io/Hdf5Handler.hpp
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/mrsid/io/MrsidReader.hpp
    M plugins/nitf/io/NitfFile.cpp
    M plugins/nitf/io/NitfFile.hpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/nitf/test/NitfWriterTest.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/oci/io/OciWriter.hpp
    M plugins/oci/test/OCITest.cpp
    M plugins/p2g/io/P2gWriter.cpp
    M plugins/p2g/io/P2gWriter.hpp
    M plugins/pcl/io/point_types.hpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/pgpointcloud/io/PgWriter.hpp
    M plugins/rxp/io/RxpReader.cpp
    M plugins/rxp/test/RxpReaderTest.cpp
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M plugins/sqlite/io/SQLiteWriter.hpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M src/FileUtils.cpp
    M src/KDIndex.cpp
    M src/PipelineReader.cpp
    M src/Stage.cpp
    M src/StageInfo.cpp
    M src/StreamFactory.cpp
    M src/Utils.cpp
    M src/XMLSchema.cpp
    M src/filters/Stats.cpp
    M src/pdal_config.cpp
    M src/plang/Invocation.cpp
    M test/unit/CompressionTest.cpp
    M test/unit/ConfigTest.cpp
    M test/unit/DimensionTest.cpp
    M test/unit/GDALUtilsTest.cpp
    M test/unit/LogTest.cpp
    M test/unit/OptionsTest.cpp
    M test/unit/PointBufferTest.cpp
    M test/unit/SchemaTest.cpp
    M test/unit/StageFactoryTest.cpp
    M test/unit/StreamFactoryTest.cpp
    M test/unit/Support.cpp
    M test/unit/Support.hpp
    M test/unit/SupportTest.cpp
    M test/unit/UtilsTest.cpp
    M test/unit/XMLSchemaTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
    M test/unit/io/terrasolid/TerraSolidReaderTest.cpp
    M test/unit/io/text/TextWriterTest.cpp
    M test/unit/plang/PLangTest.cpp
  Log Message:
  remove remaining refernces to boost standard integer types
  Commit: 45420d62e6c5c46f5d3bafa63a938a097963b63a
      https://github.com/PDAL/PDAL/commit/45420d62e6c5c46f5d3bafa63a938a097963b63a
  Changed paths:
    M scripts/ci/script.sh
  Log Message:
  sudo the ctest call to avoid segfault on travis
Compare: https://github.com/PDAL/PDAL/compare/43231105464e...45420d62e6c5
More information about the pdal-commits mailing list
