[pdal-commits] [PDAL/PDAL] 35898f: Specify languages in cmake project
GitHub noreply at github.com
Wed Dec 3 18:14:56 PST 2014
  Branch: refs/heads/issues-599
  Home:   https://github.com/PDAL/PDAL
  Commit: 35898f989ce22570f28817581361266d544e54e9
      https://github.com/PDAL/PDAL/commit/35898f989ce22570f28817581361266d544e54e9
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Date:   2014-11-28 (Fri, 28 Nov 2014)
  Changed paths:
    M CMakeLists.txt
  Log Message:
If languages aren't specified, they *should* default to CXX and C, but
on a cmake 3.0.2 build on Red Hat the lack of explicit languages caused
cmake to not find my local gcc/g++ install and instead use the system
compilers. Very weird, I know, but this fixed the problem, I guess
there's no harm in explicitly stating the languages?
  Commit: 72513daeb7f44789fb5e56accdc2c379466bfcee
      https://github.com/PDAL/PDAL/commit/72513daeb7f44789fb5e56accdc2c379466bfcee
  Changed paths:
    M include/pdal/Metadata.hpp
  Log Message:
  Metadata.hpp needs a <memory> include
I'm not sure why this wasn't picked up by Travis, but build failed on
red hat due to missing <memory> include.
  Commit: 1089c5aeaa2785106d3f647486dc4fe943afb37c
      https://github.com/PDAL/PDAL/commit/1089c5aeaa2785106d3f647486dc4fe943afb37c
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-12-01 (Mon, 01 Dec 2014)
  Changed paths:
    M filters/CMakeLists.txt
    A filters/colorization/CMakeLists.txt
    A filters/colorization/ColorizationFilter.cpp
    A filters/colorization/ColorizationFilter.hpp
    M include/pdal/Filters.hpp
    R include/pdal/filters/Colorization.hpp
    M src/CMakeLists.txt
    M src/StageFactory.cpp
    R src/filters/Colorization.cpp
    M test/unit/CMakeLists.txt
    M test/unit/filters/ColorizationFilterTest.cpp
  Log Message:
  Port Colorization filter
  Commit: 6a4bf9dcb0b159cf737ad84e73fd12bf3d66309a
      https://github.com/PDAL/PDAL/commit/6a4bf9dcb0b159cf737ad84e73fd12bf3d66309a
  Date:   2014-12-02 (Tue, 02 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M apps/pdal.cpp
    M doc/tutorial/writing.rst
    A include/pdal/Kernels.hpp
    R include/pdal/kernel/Application.hpp
    R include/pdal/kernel/Delta.hpp
    R include/pdal/kernel/Diff.hpp
    R include/pdal/kernel/Info.hpp
    R include/pdal/kernel/Kernel.hpp
    R include/pdal/kernel/KernelFactory.hpp
    R include/pdal/kernel/KernelInfo.hpp
    R include/pdal/kernel/Kernels.hpp
    R include/pdal/kernel/Pipeline.hpp
    R include/pdal/kernel/Random.hpp
    R include/pdal/kernel/Sort.hpp
    R include/pdal/kernel/Support.hpp
    R include/pdal/kernel/Translate.hpp
    A kernels/Application.hpp
    A kernels/CMakeLists.txt
    A kernels/Kernel.cpp
    A kernels/Kernel.hpp
    A kernels/KernelFactory.cpp
    A kernels/KernelFactory.hpp
    A kernels/KernelInfo.cpp
    A kernels/KernelInfo.hpp
    A kernels/KernelSupport.cpp
    A kernels/KernelSupport.hpp
    A kernels/delta/CMakeLists.txt
    A kernels/delta/DeltaKernel.cpp
    A kernels/delta/DeltaKernel.hpp
    A kernels/diff/CMakeLists.txt
    A kernels/diff/DiffKernel.cpp
    A kernels/diff/DiffKernel.hpp
    A kernels/info/CMakeLists.txt
    A kernels/info/InfoKernel.cpp
    A kernels/info/InfoKernel.hpp
    A kernels/pipeline/CMakeLists.txt
    A kernels/pipeline/PipelineKernel.cpp
    A kernels/pipeline/PipelineKernel.hpp
    A kernels/random/CMakeLists.txt
    A kernels/random/RandomKernel.cpp
    A kernels/random/RandomKernel.hpp
    A kernels/sort/CMakeLists.txt
    A kernels/sort/SortKernel.cpp
    A kernels/sort/SortKernel.hpp
    A kernels/translate/CMakeLists.txt
    A kernels/translate/TranslateKernel.cpp
    A kernels/translate/TranslateKernel.hpp
    M plugins/pcl/CMakeLists.txt
    R plugins/pcl/kernel/Ground.cpp
    R plugins/pcl/kernel/Ground.hpp
    A plugins/pcl/kernel/GroundKernel.cpp
    A plugins/pcl/kernel/GroundKernel.hpp
    R plugins/pcl/kernel/PCL.cpp
    R plugins/pcl/kernel/PCL.hpp
    A plugins/pcl/kernel/PCLKernel.cpp
    A plugins/pcl/kernel/PCLKernel.hpp
    R plugins/pcl/kernel/Smooth.cpp
    R plugins/pcl/kernel/Smooth.hpp
    A plugins/pcl/kernel/SmoothKernel.cpp
    A plugins/pcl/kernel/SmoothKernel.hpp
    R plugins/pcl/kernel/View.cpp
    R plugins/pcl/kernel/View.hpp
    A plugins/pcl/kernel/ViewKernel.cpp
    A plugins/pcl/kernel/ViewKernel.hpp
    R src/kernel/Delta.cpp
    R src/kernel/Diff.cpp
    R src/kernel/Info.cpp
    R src/kernel/Kernel.cpp
    R src/kernel/KernelFactory.cpp
    R src/kernel/KernelInfo.cpp
    R src/kernel/Pipeline.cpp
    R src/kernel/Random.cpp
    R src/kernel/Sort.cpp
    R src/kernel/Support.cpp
    R src/kernel/Translate.cpp
  Log Message:
  Port ALL kernels
  Commit: 83b3d914f55940a28710e49313cec502091a20bf
      https://github.com/PDAL/PDAL/commit/83b3d914f55940a28710e49313cec502091a20bf
  Changed paths:
    M CMakeLists.txt
  Log Message:
  remove extraneous clearing of PDAL_TARGET_OBJECTS
  Commit: 2ac26c08e495052a3107bf4fa40fe466b88f98d5
      https://github.com/PDAL/PDAL/commit/2ac26c08e495052a3107bf4fa40fe466b88f98d5
  Changed paths:
    M kernels/translate/TranslateKernel.cpp
  Log Message:
  missed rename of Support to KernelSupport
  Commit: e3bb026419a248c18d57747994f39abbde5c294e
      https://github.com/PDAL/PDAL/commit/e3bb026419a248c18d57747994f39abbde5c294e
  Changed paths:
    M cmake/pdal_targets.cmake
    M kernels/CMakeLists.txt
  Log Message:
  remove cruft, fPIC seems to be required for Kernel common object library
  Commit: 02cb532cd5015ba2b053f21ff3ae93ac950b10b8
      https://github.com/PDAL/PDAL/commit/02cb532cd5015ba2b053f21ff3ae93ac950b10b8
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-12-03 (Wed, 03 Dec 2014)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #632 from gadomski/red-hat-build-fixes
Two small fixes accumulated during a Red Hat buildout
  Commit: 0c945da112d48085b703013fb6abffea42546064
      https://github.com/PDAL/PDAL/commit/0c945da112d48085b703013fb6abffea42546064
  Changed paths:
  Log Message:
  Merge pull request #635 from PDAL/move-colorization-filter
  Commit: eba599d16238104d7585add155ea517f90275a2d
      https://github.com/PDAL/PDAL/commit/eba599d16238104d7585add155ea517f90275a2d
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
  Log Message:
  Merge pull request #636 from PDAL/move-kernels
Move kernels
  Commit: 3312c142171ddf14bb1f0cc9635968f3f1e0b5a7
      https://github.com/PDAL/PDAL/commit/3312c142171ddf14bb1f0cc9635968f3f1e0b5a7
  Changed paths:
    M plugins/greyhound/io/Exchanges.hpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundReader.hpp
    M plugins/hexbin/filters/HexBin.cpp
    M plugins/hexbin/filters/HexBin.hpp
    M plugins/icebridge/io/IcebridgeReader.cpp
    M plugins/icebridge/io/IcebridgeReader.hpp
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/mrsid/io/MrsidReader.hpp
    M plugins/nitf/test/NitfWriterTest.cpp
    M plugins/oci/io/OciCommon.cpp
    M plugins/oci/io/OciCommon.hpp
    M plugins/oci/io/OciReader.cpp
    M plugins/oci/io/OciReader.hpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/oci/io/OciWriter.hpp
    M plugins/oci/test/OCITest.cpp
    M plugins/p2g/io/P2gWriter.cpp
    M plugins/p2g/io/P2gWriter.hpp
    M plugins/pcl/io/PCLVisualizer.cpp
    M plugins/pcl/io/PCLVisualizer.hpp
    M plugins/pcl/io/PcdCommon.cpp
    M plugins/pcl/io/PcdCommon.hpp
    M plugins/pcl/io/PcdReader.cpp
    M plugins/pcl/io/PcdReader.hpp
    M plugins/pcl/io/PcdWriter.cpp
    M plugins/pcl/io/PcdWriter.hpp
    M plugins/pgpointcloud/io/PgCommon.hpp
    M plugins/pgpointcloud/io/PgReader.cpp
    M plugins/pgpointcloud/io/PgReader.hpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/pgpointcloud/io/PgWriter.hpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M plugins/pgpointcloud/test/Pgtest-Support.hpp.in
    M plugins/rxp/CMakeLists.txt
    M plugins/rxp/io/RxpReader.cpp
    M plugins/rxp/io/RxpReader.hpp
    M plugins/rxp/test/Config.hpp.in
    M plugins/rxp/test/RxpReaderTest.cpp
    M plugins/sqlite/io/SQLiteCommon.hpp
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteReader.hpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M plugins/sqlite/io/SQLiteWriter.hpp
    M plugins/sqlite/test/SQLiteTest.cpp
  Log Message:
  Remove dangling references to drivers, mostly in the plugins
  Commit: 63a50243666d583438986a2cfe75edcfe35fca4e
      https://github.com/PDAL/PDAL/commit/63a50243666d583438986a2cfe75edcfe35fca4e
  Changed paths:
  Log Message:
  Merge pull request #637 from PDAL/plugin-renames
  Commit: a722d2b88d448c5cc699a7a9237e5041d98045c1
      https://github.com/PDAL/PDAL/commit/a722d2b88d448c5cc699a7a9237e5041d98045c1
  Changed paths:
    M filters/chipper/ChipperFilter.cpp
    M filters/chipper/ChipperFilter.hpp
    M filters/colorization/ColorizationFilter.hpp
    M include/pdal/FileUtils.hpp
    M include/pdal/KDIndex.hpp
    M include/pdal/PipelineReader.hpp
    M include/pdal/Stage.hpp
    M include/pdal/StreamFactory.hpp
    M include/pdal/Utils.hpp
    M include/pdal/filters/Stats.hpp
    M include/pdal/pdal_internal.hpp
    M include/pdal/plang/Invocation.hpp
    M io/bpf/BpfReader.cpp
    M io/faux/FauxReader.cpp
    M io/las/LasReader.cpp
    M io/las/LasWriter.hpp
    M io/terrasolid/TerrasolidReader.cpp
    M io/text/TextWriter.cpp
    M kernels/Application.hpp
    M kernels/Kernel.cpp
    M kernels/Kernel.hpp
    M kernels/delta/DeltaKernel.cpp
    M kernels/delta/DeltaKernel.hpp
    M kernels/diff/DiffKernel.cpp
    M kernels/info/InfoKernel.cpp
    M kernels/info/InfoKernel.hpp
    M kernels/random/RandomKernel.cpp
    M kernels/random/RandomKernel.hpp
    M kernels/sort/SortKernel.cpp
    M plugins/icebridge/io/Hdf5Handler.cpp
    M plugins/icebridge/io/Hdf5Handler.hpp
    M plugins/nitf/io/NitfFile.cpp
    M plugins/nitf/io/NitfFile.hpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/pcl/io/point_types.hpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M src/FileUtils.cpp
    M src/KDIndex.cpp
    M src/PipelineReader.cpp
    M src/Stage.cpp
    M src/StageInfo.cpp
    M src/StreamFactory.cpp
    M src/Utils.cpp
    M src/XMLSchema.cpp
    M src/filters/Stats.cpp
    M src/pdal_config.cpp
    M src/plang/Invocation.cpp
    M test/unit/CompressionTest.cpp
    M test/unit/ConfigTest.cpp
    M test/unit/DimensionTest.cpp
    M test/unit/GDALUtilsTest.cpp
    M test/unit/LogTest.cpp
    M test/unit/OptionsTest.cpp
    M test/unit/PointBufferTest.cpp
    M test/unit/SchemaTest.cpp
    M test/unit/StageFactoryTest.cpp
    M test/unit/StreamFactoryTest.cpp
    M test/unit/Support.cpp
    M test/unit/Support.hpp
    M test/unit/SupportTest.cpp
    M test/unit/UtilsTest.cpp
    M test/unit/XMLSchemaTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
    M test/unit/io/terrasolid/TerraSolidReaderTest.cpp
    M test/unit/io/text/TextWriterTest.cpp
    M test/unit/plang/PLangTest.cpp
  Log Message:
  remove remaining refernces to boost standard integer types
  Commit: 45420d62e6c5c46f5d3bafa63a938a097963b63a
      https://github.com/PDAL/PDAL/commit/45420d62e6c5c46f5d3bafa63a938a097963b63a
  Changed paths:
    M scripts/ci/script.sh
  Log Message:
  sudo the ctest call to avoid segfault on travis
  Commit: 0f7513500fb7cd684f3bd1313161b07f72488771
      https://github.com/PDAL/PDAL/commit/0f7513500fb7cd684f3bd1313161b07f72488771
  Changed paths:
  Log Message:
  still need sudo for make install though
  Commit: 6e5c5f4d870644bdb8643038e6d4446a103f2d17
      https://github.com/PDAL/PDAL/commit/6e5c5f4d870644bdb8643038e6d4446a103f2d17
  Changed paths:
    M src/FileUtils.cpp
    M src/KDIndex.cpp
    M src/Stage.cpp
    M src/StageInfo.cpp
    M src/Utils.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge pull request #638 from PDAL/remove-boost-cstdint
  Commit: 30d03fef88850add653d0886bd0d375c007be003
      https://github.com/PDAL/PDAL/commit/30d03fef88850add653d0886bd0d375c007be003
  Changed paths:
  Log Message:
  cleanups related to #637
  Commit: feb61fa61ffc1abac8435e719432b90cc6747e75
      https://github.com/PDAL/PDAL/commit/feb61fa61ffc1abac8435e719432b90cc6747e75
  Changed paths:
    M src/FileUtils.cpp
    M src/KDIndex.cpp
    M src/Stage.cpp
    M src/StageInfo.cpp
    M src/Utils.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: c9ddd670284f215067036414c5893ceb5dd0b801
      https://github.com/PDAL/PDAL/commit/c9ddd670284f215067036414c5893ceb5dd0b801
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M include/pdal/DbWriter.hpp
    M src/FileUtils.cpp
    M src/KDIndex.cpp
    M src/Stage.cpp
    M src/StageInfo.cpp
    M src/Utils.cpp
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL into issues-599
Conflicts:
	src/CMakeLists.txt
	src/XMLSchema.cpp
  Commit: e52084bf303512e5e80e6e57f781c90d0dd13ed0
      https://github.com/PDAL/PDAL/commit/e52084bf303512e5e80e6e57f781c90d0dd13ed0
  Changed paths:
  Log Message:
Conflicts:
Compare: https://github.com/PDAL/PDAL/compare/079664f2dc1a...e52084bf3035
More information about the pdal-commits mailing list
