[pdal-commits] [PDAL/PDAL] 36008d: fix default for dependent tests, also check for WI...
GitHub noreply at github.com
Fri Dec 12 08:11:17 PST 2014
  Branch: refs/heads/issues/653-dependent-tests
  Home:   https://github.com/PDAL/PDAL
  Commit: 36008de43b09ddce50ee4fcdef4b61591fbf27f3
      https://github.com/PDAL/PDAL/commit/36008de43b09ddce50ee4fcdef4b61591fbf27f3
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-12-12 (Fri, 12 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M plugins/hexbin/CMakeLists.txt
    M plugins/icebridge/CMakeLists.txt
    M plugins/nitf/CMakeLists.txt
    M plugins/pcl/CMakeLists.txt
  Log Message:
  fix default for dependent tests, also check for WITH_TESTS before adding plugin tests
More information about the pdal-commits mailing list
