[pdal-commits] [PDAL/PDAL] 36008d: fix default for dependent tests, also check for WI...
GitHub noreply at github.com
Fri Dec 12 12:22:09 PST 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 36008de43b09ddce50ee4fcdef4b61591fbf27f3
      https://github.com/PDAL/PDAL/commit/36008de43b09ddce50ee4fcdef4b61591fbf27f3
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-12-12 (Fri, 12 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M plugins/hexbin/CMakeLists.txt
    M plugins/icebridge/CMakeLists.txt
    M plugins/nitf/CMakeLists.txt
    M plugins/pcl/CMakeLists.txt
  Log Message:
  fix default for dependent tests, also check for WITH_TESTS before adding plugin tests
  Commit: ec0bf2599240fe0331e6e9da007a73d656f4c4fd
      https://github.com/PDAL/PDAL/commit/ec0bf2599240fe0331e6e9da007a73d656f4c4fd
  Author: Connor Manning <connormanning at users.noreply.github.com>
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #656 from PDAL/issues/653-dependent-tests
Compare: https://github.com/PDAL/PDAL/compare/644075825d55...ec0bf2599240
More information about the pdal-commits mailing list
