[pdal-commits] [PDAL/PDAL] 4272b3: First steps to write ints instead of doubles for D...
GitHub noreply at github.com
Fri Dec 12 18:55:06 PST 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 4272b386a306fca6121f1314cba532becd21fba3
      https://github.com/PDAL/PDAL/commit/4272b386a306fca6121f1314cba532becd21fba3
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2014-11-19 (Wed, 19 Nov 2014)
  Changed paths:
    A include/pdal/DbWriter.hpp
    M include/pdal/Dimension.hpp
    M include/pdal/PointBuffer.hpp
    M include/pdal/PointContext.hpp
    M include/pdal/XMLSchema.hpp
    M include/pdal/pdal_types.hpp
    M plugins/oci/drivers/OciWriter.cpp
    M plugins/oci/drivers/OciWriter.hpp
    M plugins/pgpointcloud/drivers/PgWriter.cpp
    M plugins/pgpointcloud/drivers/PgWriter.hpp
    M plugins/sqlite/drivers/SQLiteCommon.hpp
    M plugins/sqlite/drivers/SQLiteWriter.cpp
    M plugins/sqlite/drivers/SQLiteWriter.hpp
    M src/CMakeLists.txt
    A src/DbWriter.cpp
    M src/drivers/bpf/BpfHeader.cpp
  Log Message:
  First steps to write ints instead of doubles for DB drivers.
  Commit: de9390de04f053ba0c50462027402e18f3b801a5
      https://github.com/PDAL/PDAL/commit/de9390de04f053ba0c50462027402e18f3b801a5
  Changed paths:
    M .travis.yml
    M CMakeLists.txt
    M cmake/examples/pramsey-config.sh
    M cmake/pdal_targets.cmake
    M doc/api/cpp/bounds.rst
    M doc/api/cpp/dimension.rst
    M doc/api/cpp/index.rst
    M doc/api/cpp/metadata.rst
    A doc/api/cpp/pointcontext.rst
    M doc/api/cpp/reader.rst
    R doc/api/cpp/schema.rst
    M doc/doxygen/doxygen.conf
    R doc/stages/drivers.buffer.reader.rst
    R doc/stages/drivers.csar.reader.rst
    R doc/stages/drivers.csardb.reader.rst
    R doc/stages/drivers.qfit.reader.rst
    R doc/stages/drivers.sbet.reader.rst
    R doc/stages/drivers.text.writer.rst
    M doc/stages/index.rst
    A doc/stages/readers.buffer.rst
    A doc/stages/readers.qfit.rst
    A doc/stages/readers.sbet.rst
    A doc/stages/writers.text.rst
    M doc/tutorial/writing.rst
    M drivers/CMakeLists.txt
    A drivers/bpf/BpfHeader.cpp
    A drivers/bpf/BpfHeader.hpp
    A drivers/bpf/BpfReader.cpp
    A drivers/bpf/BpfReader.hpp
    A drivers/bpf/CMakeLists.txt
    A drivers/buffer/BufferReader.hpp
    M drivers/faux/CMakeLists.txt
    A drivers/qfit/CMakeLists.txt
    A drivers/qfit/QfitReader.cpp
    A drivers/qfit/QfitReader.hpp
    A drivers/sbet/CMakeLists.txt
    A drivers/sbet/SbetCommon.cpp
    A drivers/sbet/SbetCommon.hpp
    A drivers/sbet/SbetReader.cpp
    A drivers/sbet/SbetReader.hpp
    A drivers/sbet/SbetWriter.cpp
    A drivers/sbet/SbetWriter.hpp
    A drivers/text/CMakeLists.txt
    A drivers/text/TextWriter.cpp
    A drivers/text/TextWriter.hpp
    M include/pdal/Compression.hpp
    M include/pdal/Drivers.hpp
    M include/pdal/IStream.hpp
    M include/pdal/OStream.hpp
    R include/pdal/drivers/bpf/BpfHeader.hpp
    R include/pdal/drivers/bpf/BpfReader.hpp
    R include/pdal/drivers/buffer/BufferReader.hpp
    R include/pdal/drivers/caris/CloudReader.hpp
    M include/pdal/drivers/las/Header.hpp
    R include/pdal/drivers/qfit/Reader.hpp
    R include/pdal/drivers/sbet/Common.hpp
    R include/pdal/drivers/sbet/Reader.hpp
    R include/pdal/drivers/sbet/Writer.hpp
    R include/pdal/drivers/text/Writer.hpp
    M pdal_defines.h.in
    M plugins/pcl/kernel/Ground.cpp
    M plugins/pcl/kernel/PCL.cpp
    M plugins/pcl/kernel/Smooth.cpp
    M plugins/pgpointcloud/drivers/PgCommon.hpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M scripts/ci/script.sh
    M src/StageFactory.cpp
    R src/drivers/bpf/BpfHeader.cpp
    R src/drivers/bpf/BpfReader.cpp
    R src/drivers/caris/CloudIterator.cpp
    R src/drivers/caris/CloudReader.cpp
    R src/drivers/caris/Utils.cpp
    R src/drivers/caris/Utils.hpp
    R src/drivers/caris/caris/caris_pc_wrapper.c
    R src/drivers/caris/caris/caris_pc_wrapper.h
    R src/drivers/caris/config.h
    R src/drivers/caris/linkline.cpp
    R src/drivers/caris/pdal_csar.cpp
    R src/drivers/caris/pdal_csar.def
    M src/drivers/las/Header.cpp
    M src/drivers/las/Writer.cpp
    R src/drivers/qfit/Reader.cpp
    R src/drivers/sbet/Common.cpp
    R src/drivers/sbet/Reader.cpp
    R src/drivers/sbet/Writer.cpp
    R src/drivers/text/Writer.cpp
    M src/kernel/Kernel.cpp
    M src/kernel/Sort.cpp
    M src/kernel/Translate.cpp
    M src/pdal_config.cpp
    M test/data/bpf/bpf.xml
    M test/data/drivers/text-writer-csv.xml
    M test/data/drivers/text-writer-geojson.xml
    M test/data/drivers/text-writer-space-delimited.xml
    M test/data/filters/colorize-multi.xml
    M test/data/filters/decimate.xml
    M test/data/icebridge/pipeline.xml
    M test/data/oracle/qfit-write.xml
    M test/data/qfit/conversion.xml
    M test/data/qfit/little-endian-conversion.xml
    M test/data/qfit/pipeline.xml
    M test/data/qfit/reader.xml
    M test/data/sbet/pipeline.xml
    M test/unit/CMakeLists.txt
    M test/unit/CompressionTest.cpp
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/drivers/bpf/BPFTest.cpp
    M test/unit/drivers/buffer/BufferTest.cpp
    R test/unit/drivers/caris/CarisReaderTest.cpp
    M test/unit/drivers/las/LasReaderTest.cpp
    M test/unit/drivers/las/LasWriterTest.cpp
    M test/unit/drivers/qfit/QFITReaderTest.cpp
    M test/unit/drivers/sbet/SbetReaderTest.cpp
    M test/unit/drivers/sbet/SbetWriterTest.cpp
    M test/unit/drivers/text/TextWriterTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into dbintwriter
Conflicts:
  Commit: 3cddc00729251c1ac210ae4247ac58dcf803caab
      https://github.com/PDAL/PDAL/commit/3cddc00729251c1ac210ae4247ac58dcf803caab
  Date:   2014-11-21 (Fri, 21 Nov 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    R doc/stages/drivers.las.reader.rst
    R doc/stages/drivers.las.writer.rst
    A doc/stages/readers.las.rst
    A doc/stages/writers.las.rst
    A drivers/las/CMakeLists.txt
    A drivers/las/GeotiffSupport.cpp
    A drivers/las/GeotiffSupport.hpp
    A drivers/las/LasError.hpp
    A drivers/las/LasHeader.cpp
    A drivers/las/LasHeader.hpp
    A drivers/las/LasReader.cpp
    A drivers/las/LasReader.hpp
    A drivers/las/LasWriter.cpp
    A drivers/las/LasWriter.hpp
    A drivers/las/SummaryData.cpp
    A drivers/las/SummaryData.hpp
    A drivers/las/VariableLengthRecord.cpp
    A drivers/las/VariableLengthRecord.hpp
    A drivers/las/ZipPoint.cpp
    A drivers/las/ZipPoint.hpp
    A drivers/terrasolid/CMakeLists.txt
    A drivers/terrasolid/TerrasolidReader.cpp
    A drivers/terrasolid/TerrasolidReader.hpp
    A filters/CMakeLists.txt
    A filters/chipper/CMakeLists.txt
    A filters/chipper/ChipperFilter.cpp
    A filters/chipper/ChipperFilter.hpp
    M include/pdal/Filters.hpp
    M include/pdal/Options.hpp
    M include/pdal/Utils.hpp
    R include/pdal/drivers/las/Header.hpp
    R include/pdal/drivers/las/Reader.hpp
    R include/pdal/drivers/las/SummaryData.hpp
    R include/pdal/drivers/las/VariableLengthRecord.hpp
    R include/pdal/drivers/las/Writer.hpp
    R include/pdal/drivers/las/ZipPoint.hpp
    R include/pdal/drivers/terrasolid/Reader.hpp
    R include/pdal/filters/Attribute.hpp
    R include/pdal/filters/ByteSwap.hpp
    R include/pdal/filters/Cache.hpp
    R include/pdal/filters/Chipper.hpp
    R include/pdal/filters/InPlaceReprojection.hpp
    R include/pdal/filters/Scaling.hpp
    R include/pdal/filters/Selector.hpp
    M include/pdal/kernel/Random.hpp
    M plugins/CMakeLists.txt
    A plugins/attribute/CMakeLists.txt
    A plugins/attribute/filters/AttributeFilter.cpp
    A plugins/attribute/filters/AttributeFilter.hpp
    M plugins/hexbin/CMakeLists.txt
    M plugins/hexbin/test/HexbinFilterTest.cpp
    M plugins/nitf/CMakeLists.txt
    M plugins/nitf/drivers/MetadataReader.cpp
    M plugins/nitf/drivers/MetadataReader.hpp
    M plugins/nitf/drivers/NitfFile.cpp
    M plugins/nitf/drivers/NitfFile.hpp
    M plugins/nitf/drivers/NitfReader.cpp
    M plugins/nitf/drivers/NitfReader.hpp
    M plugins/nitf/drivers/NitfWriter.cpp
    M plugins/nitf/drivers/NitfWriter.hpp
    M plugins/nitf/drivers/tre_plugins.cpp
    M plugins/nitf/drivers/tre_plugins.hpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/nitf/test/NitfWriterTest.cpp
    M plugins/oci/CMakeLists.txt
    M plugins/oci/test/OCITest.cpp
    M plugins/pcl/CMakeLists.txt
    M plugins/pcl/test/PCLBlockFilterTest.cpp
    M plugins/pgpointcloud/CMakeLists.txt
    M plugins/pgpointcloud/drivers/PgReader.cpp
    M plugins/pgpointcloud/drivers/PgReader.hpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M plugins/sqlite/CMakeLists.txt
    M src/Utils.cpp
    R src/drivers/las/GeotiffSupport.cpp
    R src/drivers/las/GeotiffSupport.hpp
    R src/drivers/las/Header.cpp
    R src/drivers/las/Reader.cpp
    R src/drivers/las/SummaryData.cpp
    R src/drivers/las/VariableLengthRecord.cpp
    R src/drivers/las/Writer.cpp
    R src/drivers/las/ZipPoint.cpp
    R src/drivers/terrasolid/Reader.cpp
    R src/filters/Attribute.cpp
    R src/filters/Chipper.cpp
    R src/filters/Color.cpp
    M test/data/apps/pdalinfo_point.txt
    M test/data/apps/pdalinfo_schema.txt
    M test/data/apps/pdalinfo_stage.txt
    M test/data/apps/pdalinfo_stage_nosrs.txt
    M test/data/drivers/p2g-writer.xml
    M test/data/drivers/sqlite-reader.xml
    M test/data/drivers/sqlite-writer.xml
    M test/data/filters/attribute.xml
    M test/data/filters/chip.xml
    M test/data/filters/chipper.xml
    M test/data/filters/colorize.xml
    M test/data/filters/crop_reproject.xml
    M test/data/filters/crop_wkt.xml
    M test/data/filters/crop_wkt_2d.xml
    M test/data/filters/crop_wkt_2d_classification.xml
    M test/data/filters/ferry.xml
    M test/data/filters/hexbin-info.xml
    M test/data/filters/hexbin.xml
    M test/data/filters/index.xml
    M test/data/filters/merge.xml
    M test/data/filters/pcl/passthrough.xml
    M test/data/filters/reproject.xml
    M test/data/filters/scaling.xml
    M test/data/filters/selector.xml
    M test/data/filters/sort.xml
    M test/data/filters/splitter.xml
    M test/data/filters/stats.xml
    M test/data/hole/crop.xml
    M test/data/nitf/chipper.xml
    M test/data/nitf/conversion.xml
    M test/data/nitf/las2nitf.xml
    M test/data/nitf/write_laz.xml
    M test/data/nitf/write_options.xml
    M test/data/oracle/big-read.xml
    M test/data/oracle/big-write.xml
    M test/data/oracle/read-colorize.xml
    M test/data/oracle/read.xml
    M test/data/oracle/view-read.xml
    M test/data/oracle/write.xml
    M test/data/pipeline/bad/pipeline_bad01.xml
    M test/data/pipeline/bad/pipeline_bad02.xml
    M test/data/pipeline/bad/pipeline_bad03.xml
    M test/data/pipeline/bad/pipeline_bad04.xml
    M test/data/pipeline/bad/pipeline_bad05.xml
    M test/data/pipeline/bad/pipeline_bad06.xml
    M test/data/pipeline/bad/pipeline_bad07.xml
    M test/data/pipeline/bad/pipeline_bad08.xml
    M test/data/pipeline/bad/pipeline_bad09.xml
    M test/data/pipeline/bad/pipeline_bad10.xml
    M test/data/pipeline/drop_color.xml
    M test/data/pipeline/pipeline_interpolate.xml
    M test/data/pipeline/pipeline_metadata_reader.xml
    M test/data/pipeline/pipeline_metadata_writer.xml
    M test/data/pipeline/pipeline_mississippi.xml
    M test/data/pipeline/pipeline_mississippi_reverse.xml
    M test/data/pipeline/pipeline_multioptions.xml
    M test/data/pipeline/pipeline_read.xml
    M test/data/pipeline/pipeline_readcomments.xml
    M test/data/pipeline/pipeline_write.xml
    M test/data/pipeline/pipeline_write2.xml
    M test/data/pipeline/pipeline_writecomments.xml
    M test/data/plang/from-module.xml
    M test/data/plang/predicate-embed.xml
    M test/data/plang/predicate-keep-ground-and-unclass.xml
    M test/data/plang/predicate-keep-last-return.xml
    M test/data/plang/predicate-keep-specified-returns.xml
    M test/data/plang/programmable-update-y-dims.xml
    M test/data/soci/read-cloud.xml
    M test/data/soci/read.xml
    M test/data/soci/sthelens-write.xml
    M test/data/soci/write-utm.xml
    M test/data/soci/write.xml
    M test/perf/chipper.xml
    M test/perf/chipper_nocache.xml
    M test/unit/MetadataTest.cpp
    M test/unit/PipelineManagerTest.cpp
    M test/unit/PointBufferTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/StageFactoryTest.cpp
    M test/unit/UtilsTest.cpp
    M test/unit/XMLSchemaTest.cpp
    M test/unit/apps/pcinfoTest.cpp
    M test/unit/drivers/oci/oracle_array.cpp
    M test/unit/drivers/terrasolid/TerraSolidReaderTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M test/unit/filters/SplitterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL into issues-599
  Commit: 26df92ad64d5fbb634c762c1734683efb6493683
      https://github.com/PDAL/PDAL/commit/26df92ad64d5fbb634c762c1734683efb6493683
  Changed paths:
  Log Message:
  Replace stuff I shouldn't have removed.
  Commit: 6c3a5e4ca4a859d486094f52f5e67f7e024528ff
      https://github.com/PDAL/PDAL/commit/6c3a5e4ca4a859d486094f52f5e67f7e024528ff
  Date:   2014-11-26 (Wed, 26 Nov 2014)
  Changed paths:
    M include/pdal/DbWriter.hpp
    M plugins/oci/drivers/OciReader.cpp
    M src/DbWriter.cpp
    M src/XMLSchema.cpp
  Log Message:
  Add support for writing int32's to DbWriter.  Schema mods still needed.
  Commit: 77a9d1fc91283b6f612b745f1b7f3686b6357097
      https://github.com/PDAL/PDAL/commit/77a9d1fc91283b6f612b745f1b7f3686b6357097
  Date:   2014-12-02 (Tue, 02 Dec 2014)
  Changed paths:
    M include/pdal/pdal_error.hpp
    M plugins/oci/drivers/OciCommon.cpp
    M plugins/oci/drivers/OciCommon.hpp
    M plugins/oci/drivers/OciReader.hpp
    M src/XMLSchema.cpp
  Log Message:
  Remove XML schema reader/writer.
Remove exceptions from XML schema.
Remove pointer wrappers.
Remove storage of DimTypes (use XMLDims instead)
  Commit: 6287a3a5bf6d79c86316993511fc89143416af9e
      https://github.com/PDAL/PDAL/commit/6287a3a5bf6d79c86316993511fc89143416af9e
  Changed paths:
  Log Message:
  Ignore float equality warning.
  Commit: d9dde0ab03e7cae5ce0f4a8a5c9425a57e2f7449
      https://github.com/PDAL/PDAL/commit/d9dde0ab03e7cae5ce0f4a8a5c9425a57e2f7449
  Changed paths:
    M src/XMLSchema.cpp
  Log Message:
  Remove PDAL_HAVE_LIBXML2 from XMLSchema files.  Use build system
instead.
  Commit: d6cfef8ca9003ab6ecc722fbdfc2b063170dea9a
      https://github.com/PDAL/PDAL/commit/d6cfef8ca9003ab6ecc722fbdfc2b063170dea9a
  Changed paths:
    M include/pdal/kernel/Info.hpp
  Log Message:
  Remove XMLSchema from Info.hpp.
  Commit: befe62cd5703844a123e1747ddcb88d16fa1560f
      https://github.com/PDAL/PDAL/commit/befe62cd5703844a123e1747ddcb88d16fa1560f
  Changed paths:
    A include/pdal/DbReader.hpp
    A src/DbReader.cpp
    M src/DbWriter.cpp
  Log Message:
  Make DbReader.  Hook to pgpointcloud.
  Commit: 64e34c0d7c1d6310cc7a507187c75ed25f46cd53
      https://github.com/PDAL/PDAL/commit/64e34c0d7c1d6310cc7a507187c75ed25f46cd53
  Date:   2014-12-03 (Wed, 03 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M cmake/examples/hobu-windows.bat
    M doc/apps.rst
    M doc/compilation/dependencies.rst
    M doc/metadata.rst
    M doc/pipeline.rst
    R doc/stages/drivers.nitf.reader.rst
    R doc/stages/drivers.nitf.writer.rst
    R doc/stages/drivers.oci.reader.rst
    R doc/stages/drivers.oci.writer.rst
    R doc/stages/drivers.p2g.writer.rst
    R doc/stages/drivers.pcd.reader.rst
    R doc/stages/drivers.pcd.writer.rst
    R doc/stages/drivers.pclvisualizer.writer.rst
    R doc/stages/drivers.pgpointcloud.reader.rst
    R doc/stages/drivers.pgpointcloud.writer.rst
    R doc/stages/drivers.rxp.reader.rst
    M doc/stages/filters.attribute.rst
    M doc/stages/filters.chipper.rst
    M doc/stages/filters.colorization.rst
    M doc/stages/filters.crop.rst
    M doc/stages/filters.decimation.rst
    M doc/stages/filters.ferry.rst
    M doc/stages/filters.hexbin.rst
    M doc/stages/filters.predicate.rst
    M doc/stages/filters.programmable.rst
    M doc/stages/filters.reprojection.rst
    M doc/stages/filters.sort.rst
    M doc/stages/readers.buffer.rst
    M doc/stages/readers.faux.rst
    M doc/stages/readers.las.rst
    A doc/stages/readers.nitf.rst
    A doc/stages/readers.oci.rst
    A doc/stages/readers.pcd.rst
    A doc/stages/readers.pgpointcloud.rst
    M doc/stages/readers.qfit.rst
    A doc/stages/readers.rxp.rst
    M doc/stages/readers.sbet.rst
    A doc/stages/writers.nitf.rst
    A doc/stages/writers.oci.rst
    A doc/stages/writers.p2g.rst
    A doc/stages/writers.pcd.rst
    A doc/stages/writers.pclvisualizer.rst
    A doc/stages/writers.pgpointcloud.rst
    M doc/stages/writers.text.rst
    M doc/tutorial/overview.rst
    M doc/tutorial/pcl_block_tutorial.rst
    M doc/tutorial/reading.rst
    M doc/vagrant.rst
    R drivers/CMakeLists.txt
    R drivers/bpf/BpfHeader.cpp
    R drivers/bpf/BpfHeader.hpp
    R drivers/bpf/BpfReader.cpp
    R drivers/bpf/BpfReader.hpp
    R drivers/bpf/CMakeLists.txt
    R drivers/buffer/BufferReader.hpp
    R drivers/faux/CMakeLists.txt
    R drivers/faux/FauxReader.cpp
    R drivers/faux/FauxReader.hpp
    R drivers/las/CMakeLists.txt
    R drivers/las/GeotiffSupport.cpp
    R drivers/las/GeotiffSupport.hpp
    R drivers/las/LasError.hpp
    R drivers/las/LasHeader.cpp
    R drivers/las/LasHeader.hpp
    R drivers/las/LasReader.cpp
    R drivers/las/LasReader.hpp
    R drivers/las/LasWriter.cpp
    R drivers/las/LasWriter.hpp
    R drivers/las/SummaryData.cpp
    R drivers/las/SummaryData.hpp
    R drivers/las/VariableLengthRecord.cpp
    R drivers/las/VariableLengthRecord.hpp
    R drivers/las/ZipPoint.cpp
    R drivers/las/ZipPoint.hpp
    R drivers/qfit/CMakeLists.txt
    R drivers/qfit/QfitReader.cpp
    R drivers/qfit/QfitReader.hpp
    R drivers/sbet/CMakeLists.txt
    R drivers/sbet/SbetCommon.cpp
    R drivers/sbet/SbetCommon.hpp
    R drivers/sbet/SbetReader.cpp
    R drivers/sbet/SbetReader.hpp
    R drivers/sbet/SbetWriter.cpp
    R drivers/sbet/SbetWriter.hpp
    R drivers/terrasolid/CMakeLists.txt
    R drivers/terrasolid/TerrasolidReader.cpp
    R drivers/terrasolid/TerrasolidReader.hpp
    R drivers/text/CMakeLists.txt
    R drivers/text/TextWriter.cpp
    R drivers/text/TextWriter.hpp
    M filters/CMakeLists.txt
    A filters/decimation/CMakeLists.txt
    A filters/decimation/DecimationFilter.cpp
    A filters/decimation/DecimationFilter.hpp
    A filters/ferry/CMakeLists.txt
    A filters/ferry/FerryFilter.cpp
    A filters/ferry/FerryFilter.hpp
    A filters/mortonorder/CMakeLists.txt
    A filters/mortonorder/MortonOrderFilter.cpp
    A filters/mortonorder/MortonOrderFilter.hpp
    A filters/splitter/CMakeLists.txt
    A filters/splitter/SplitterFilter.cpp
    A filters/splitter/SplitterFilter.hpp
    M include/pdal/Filter.hpp
    M include/pdal/PointBufferIter.hpp
    M include/pdal/Reader.hpp
    R include/pdal/filters/Decimation.hpp
    R include/pdal/filters/Ferry.hpp
    R include/pdal/filters/MortonOrder.hpp
    R include/pdal/filters/Splitter.hpp
    M include/pdal/pdal_config.hpp
    A io/CMakeLists.txt
    A io/bpf/BpfHeader.cpp
    A io/bpf/BpfHeader.hpp
    A io/bpf/BpfReader.cpp
    A io/bpf/BpfReader.hpp
    A io/bpf/CMakeLists.txt
    A io/buffer/BufferReader.hpp
    A io/faux/CMakeLists.txt
    A io/faux/FauxReader.cpp
    A io/faux/FauxReader.hpp
    A io/las/CMakeLists.txt
    A io/las/GeotiffSupport.cpp
    A io/las/GeotiffSupport.hpp
    A io/las/LasError.hpp
    A io/las/LasHeader.cpp
    A io/las/LasHeader.hpp
    A io/las/LasReader.cpp
    A io/las/LasReader.hpp
    A io/las/LasWriter.cpp
    A io/las/LasWriter.hpp
    A io/las/SummaryData.cpp
    A io/las/SummaryData.hpp
    A io/las/VariableLengthRecord.cpp
    A io/las/VariableLengthRecord.hpp
    A io/las/ZipPoint.cpp
    A io/las/ZipPoint.hpp
    A io/qfit/CMakeLists.txt
    A io/qfit/QfitReader.cpp
    A io/qfit/QfitReader.hpp
    A io/sbet/CMakeLists.txt
    A io/sbet/SbetCommon.cpp
    A io/sbet/SbetCommon.hpp
    A io/sbet/SbetReader.cpp
    A io/sbet/SbetReader.hpp
    A io/sbet/SbetWriter.cpp
    A io/sbet/SbetWriter.hpp
    A io/terrasolid/CMakeLists.txt
    A io/terrasolid/TerrasolidReader.cpp
    A io/terrasolid/TerrasolidReader.hpp
    A io/text/CMakeLists.txt
    A io/text/TextWriter.cpp
    A io/text/TextWriter.hpp
    M plugins/greyhound/CMakeLists.txt
    R plugins/greyhound/drivers/Exchanges.hpp
    R plugins/greyhound/drivers/GreyhoundReader.cpp
    R plugins/greyhound/drivers/GreyhoundReader.hpp
    R plugins/greyhound/drivers/WebSocketClient.cpp
    R plugins/greyhound/drivers/WebSocketClient.hpp
    A plugins/greyhound/io/Exchanges.hpp
    A plugins/greyhound/io/GreyhoundReader.cpp
    A plugins/greyhound/io/GreyhoundReader.hpp
    A plugins/greyhound/io/WebSocketClient.cpp
    A plugins/greyhound/io/WebSocketClient.hpp
    M plugins/icebridge/CMakeLists.txt
    R plugins/icebridge/drivers/Hdf5Handler.cpp
    R plugins/icebridge/drivers/Hdf5Handler.hpp
    R plugins/icebridge/drivers/IcebridgeReader.cpp
    R plugins/icebridge/drivers/IcebridgeReader.hpp
    A plugins/icebridge/io/Hdf5Handler.cpp
    A plugins/icebridge/io/Hdf5Handler.hpp
    A plugins/icebridge/io/IcebridgeReader.cpp
    A plugins/icebridge/io/IcebridgeReader.hpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/mrsid/CMakeLists.txt
    R plugins/mrsid/drivers/MrsidReader.cpp
    R plugins/mrsid/drivers/MrsidReader.hpp
    A plugins/mrsid/io/MrsidReader.cpp
    A plugins/mrsid/io/MrsidReader.hpp
    R plugins/nitf/drivers/MetadataReader.cpp
    R plugins/nitf/drivers/MetadataReader.hpp
    R plugins/nitf/drivers/NitfFile.cpp
    R plugins/nitf/drivers/NitfFile.hpp
    R plugins/nitf/drivers/NitfReader.cpp
    R plugins/nitf/drivers/NitfReader.hpp
    R plugins/nitf/drivers/NitfWriter.cpp
    R plugins/nitf/drivers/NitfWriter.hpp
    R plugins/nitf/drivers/nitflib.h
    R plugins/nitf/drivers/tre_plugins.cpp
    R plugins/nitf/drivers/tre_plugins.hpp
    A plugins/nitf/io/MetadataReader.cpp
    A plugins/nitf/io/MetadataReader.hpp
    A plugins/nitf/io/NitfFile.cpp
    A plugins/nitf/io/NitfFile.hpp
    A plugins/nitf/io/NitfReader.cpp
    A plugins/nitf/io/NitfReader.hpp
    A plugins/nitf/io/NitfWriter.cpp
    A plugins/nitf/io/NitfWriter.hpp
    A plugins/nitf/io/nitflib.h
    A plugins/nitf/io/tre_plugins.cpp
    A plugins/nitf/io/tre_plugins.hpp
    R plugins/oci/drivers/OciCommon.cpp
    R plugins/oci/drivers/OciCommon.hpp
    R plugins/oci/drivers/OciReader.cpp
    R plugins/oci/drivers/OciReader.hpp
    R plugins/oci/drivers/OciWrapper.cpp
    R plugins/oci/drivers/OciWrapper.h
    R plugins/oci/drivers/OciWriter.cpp
    R plugins/oci/drivers/OciWriter.hpp
    A plugins/oci/io/OciCommon.cpp
    A plugins/oci/io/OciCommon.hpp
    A plugins/oci/io/OciReader.cpp
    A plugins/oci/io/OciReader.hpp
    A plugins/oci/io/OciWrapper.cpp
    A plugins/oci/io/OciWrapper.h
    A plugins/oci/io/OciWriter.cpp
    A plugins/oci/io/OciWriter.hpp
    M plugins/p2g/CMakeLists.txt
    R plugins/p2g/drivers/P2gWriter.cpp
    R plugins/p2g/drivers/P2gWriter.hpp
    A plugins/p2g/io/P2gWriter.cpp
    A plugins/p2g/io/P2gWriter.hpp
    R plugins/pcl/drivers/PCLVisualizer.cpp
    R plugins/pcl/drivers/PCLVisualizer.hpp
    R plugins/pcl/drivers/PcdCommon.cpp
    R plugins/pcl/drivers/PcdCommon.hpp
    R plugins/pcl/drivers/PcdReader.cpp
    R plugins/pcl/drivers/PcdReader.hpp
    R plugins/pcl/drivers/PcdWriter.cpp
    R plugins/pcl/drivers/PcdWriter.hpp
    R plugins/pcl/drivers/point_types.hpp
    A plugins/pcl/io/PCLVisualizer.cpp
    A plugins/pcl/io/PCLVisualizer.hpp
    A plugins/pcl/io/PcdCommon.cpp
    A plugins/pcl/io/PcdCommon.hpp
    A plugins/pcl/io/PcdReader.cpp
    A plugins/pcl/io/PcdReader.hpp
    A plugins/pcl/io/PcdWriter.cpp
    A plugins/pcl/io/PcdWriter.hpp
    A plugins/pcl/io/point_types.hpp
    M plugins/pcl/kernel/Ground.hpp
    M plugins/pcl/kernel/View.cpp
    M plugins/pcl/kernel/View.hpp
    R plugins/pgpointcloud/drivers/PgCommon.hpp
    R plugins/pgpointcloud/drivers/PgReader.cpp
    R plugins/pgpointcloud/drivers/PgReader.hpp
    R plugins/pgpointcloud/drivers/PgWriter.cpp
    R plugins/pgpointcloud/drivers/PgWriter.hpp
    A plugins/pgpointcloud/io/PgCommon.hpp
    A plugins/pgpointcloud/io/PgReader.cpp
    A plugins/pgpointcloud/io/PgReader.hpp
    A plugins/pgpointcloud/io/PgWriter.cpp
    A plugins/pgpointcloud/io/PgWriter.hpp
    M plugins/rxp/CMakeLists.txt
    R plugins/rxp/drivers/RxpReader.cpp
    R plugins/rxp/drivers/RxpReader.hpp
    A plugins/rxp/io/RxpReader.cpp
    A plugins/rxp/io/RxpReader.hpp
    M plugins/rxp/test/RxpReaderTest.cpp
    R plugins/sqlite/drivers/SQLiteCommon.hpp
    R plugins/sqlite/drivers/SQLiteReader.cpp
    R plugins/sqlite/drivers/SQLiteReader.hpp
    R plugins/sqlite/drivers/SQLiteWriter.cpp
    R plugins/sqlite/drivers/SQLiteWriter.hpp
    A plugins/sqlite/io/SQLiteCommon.hpp
    A plugins/sqlite/io/SQLiteReader.cpp
    A plugins/sqlite/io/SQLiteReader.hpp
    A plugins/sqlite/io/SQLiteWriter.cpp
    A plugins/sqlite/io/SQLiteWriter.hpp
    M python/pdal/pipeline_xml.py
    M python/pdal/test.py
    M schemas/8-dimension-schema.xml
    M scripts/ci/common.sh
    M scripts/vagrant/loadpgpointcloud.xml
    M scripts/vagrant/readpgpointcloud.xml
    M src/PipelineReader.cpp
    R src/filters/Decimation.cpp
    R src/filters/Ferry.cpp
    R src/filters/MortonOrder.cpp
    R src/filters/Splitter.cpp
    M test/data/bpf/bpf2nitf.xml
    M test/data/nitf/reader.xml
    M test/data/oracle/qfit-read.xml
    R test/unit/drivers/bpf/BPFTest.cpp
    R test/unit/drivers/buffer/BufferTest.cpp
    R test/unit/drivers/faux/FauxReaderTest.cpp
    R test/unit/drivers/las/LasReaderTest.cpp
    R test/unit/drivers/las/LasWriterTest.cpp
    R test/unit/drivers/oci/oracle_array.cpp
    R test/unit/drivers/qfit/QFITReaderTest.cpp
    R test/unit/drivers/sbet/SbetReaderTest.cpp
    R test/unit/drivers/sbet/SbetWriterTest.cpp
    R test/unit/drivers/terrasolid/TerraSolidReaderTest.cpp
    R test/unit/drivers/text/TextWriterTest.cpp
    M test/unit/filters/DecimationFilterTest.cpp
    A test/unit/io/bpf/BPFTest.cpp
    A test/unit/io/buffer/BufferTest.cpp
    A test/unit/io/faux/FauxReaderTest.cpp
    A test/unit/io/las/LasReaderTest.cpp
    A test/unit/io/las/LasWriterTest.cpp
    A test/unit/io/oci/oracle_array.cpp
    A test/unit/io/qfit/QFITReaderTest.cpp
    A test/unit/io/sbet/SbetReaderTest.cpp
    A test/unit/io/sbet/SbetWriterTest.cpp
    A test/unit/io/terrasolid/TerraSolidReaderTest.cpp
    A test/unit/io/text/TextWriterTest.cpp
  Log Message:
Conflicts:
  Commit: 079664f2dc1a3637373a8fc345992da25f15db6a
      https://github.com/PDAL/PDAL/commit/079664f2dc1a3637373a8fc345992da25f15db6a
  Changed paths:
    M plugins/oci/io/OciWriter.cpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M src/DbWriter.cpp
  Log Message:
  Writer support for scaled 32-bit ints in OCI.
  Commit: c9ddd670284f215067036414c5893ceb5dd0b801
      https://github.com/PDAL/PDAL/commit/c9ddd670284f215067036414c5893ceb5dd0b801
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M filters/chipper/ChipperFilter.cpp
    M filters/chipper/ChipperFilter.hpp
    A filters/colorization/CMakeLists.txt
    A filters/colorization/ColorizationFilter.cpp
    A filters/colorization/ColorizationFilter.hpp
    M include/pdal/FileUtils.hpp
    M include/pdal/KDIndex.hpp
    A include/pdal/Kernels.hpp
    M include/pdal/Metadata.hpp
    M include/pdal/PipelineReader.hpp
    M include/pdal/Stage.hpp
    M include/pdal/StreamFactory.hpp
    R include/pdal/filters/Colorization.hpp
    M include/pdal/filters/Stats.hpp
    R include/pdal/kernel/Application.hpp
    R include/pdal/kernel/Delta.hpp
    R include/pdal/kernel/Diff.hpp
    R include/pdal/kernel/Info.hpp
    R include/pdal/kernel/Kernel.hpp
    R include/pdal/kernel/KernelFactory.hpp
    R include/pdal/kernel/KernelInfo.hpp
    R include/pdal/kernel/Kernels.hpp
    R include/pdal/kernel/Pipeline.hpp
    R include/pdal/kernel/Random.hpp
    R include/pdal/kernel/Sort.hpp
    R include/pdal/kernel/Support.hpp
    R include/pdal/kernel/Translate.hpp
    M include/pdal/pdal_internal.hpp
    M include/pdal/plang/Invocation.hpp
    M io/bpf/BpfReader.cpp
    M io/faux/FauxReader.cpp
    M io/las/LasReader.cpp
    M io/las/LasWriter.hpp
    M io/terrasolid/TerrasolidReader.cpp
    M io/text/TextWriter.cpp
    A kernels/Application.hpp
    A kernels/CMakeLists.txt
    A kernels/Kernel.cpp
    A kernels/Kernel.hpp
    A kernels/KernelFactory.cpp
    A kernels/KernelFactory.hpp
    A kernels/KernelInfo.cpp
    A kernels/KernelInfo.hpp
    A kernels/KernelSupport.cpp
    A kernels/KernelSupport.hpp
    A kernels/delta/CMakeLists.txt
    A kernels/delta/DeltaKernel.cpp
    A kernels/delta/DeltaKernel.hpp
    A kernels/diff/CMakeLists.txt
    A kernels/diff/DiffKernel.cpp
    A kernels/diff/DiffKernel.hpp
    A kernels/info/CMakeLists.txt
    A kernels/info/InfoKernel.cpp
    A kernels/info/InfoKernel.hpp
    A kernels/pipeline/CMakeLists.txt
    A kernels/pipeline/PipelineKernel.cpp
    A kernels/pipeline/PipelineKernel.hpp
    A kernels/random/CMakeLists.txt
    A kernels/random/RandomKernel.cpp
    A kernels/random/RandomKernel.hpp
    A kernels/sort/CMakeLists.txt
    A kernels/sort/SortKernel.cpp
    A kernels/sort/SortKernel.hpp
    A kernels/translate/CMakeLists.txt
    A kernels/translate/TranslateKernel.cpp
    A kernels/translate/TranslateKernel.hpp
    M plugins/greyhound/io/Exchanges.hpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundReader.hpp
    M plugins/hexbin/filters/HexBin.cpp
    M plugins/hexbin/filters/HexBin.hpp
    M plugins/icebridge/io/Hdf5Handler.cpp
    M plugins/icebridge/io/Hdf5Handler.hpp
    M plugins/icebridge/io/IcebridgeReader.cpp
    M plugins/icebridge/io/IcebridgeReader.hpp
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/mrsid/io/MrsidReader.hpp
    M plugins/nitf/io/NitfFile.cpp
    M plugins/nitf/io/NitfFile.hpp
    M plugins/oci/io/OciCommon.cpp
    M plugins/oci/io/OciCommon.hpp
    M plugins/oci/io/OciReader.cpp
    M plugins/oci/io/OciReader.hpp
    M plugins/oci/io/OciWriter.hpp
    M plugins/p2g/io/P2gWriter.cpp
    M plugins/p2g/io/P2gWriter.hpp
    M plugins/pcl/io/PCLVisualizer.cpp
    M plugins/pcl/io/PCLVisualizer.hpp
    M plugins/pcl/io/PcdCommon.cpp
    M plugins/pcl/io/PcdCommon.hpp
    M plugins/pcl/io/PcdReader.cpp
    M plugins/pcl/io/PcdReader.hpp
    M plugins/pcl/io/PcdWriter.cpp
    M plugins/pcl/io/PcdWriter.hpp
    M plugins/pcl/io/point_types.hpp
    R plugins/pcl/kernel/Ground.cpp
    R plugins/pcl/kernel/Ground.hpp
    A plugins/pcl/kernel/GroundKernel.cpp
    A plugins/pcl/kernel/GroundKernel.hpp
    R plugins/pcl/kernel/PCL.cpp
    R plugins/pcl/kernel/PCL.hpp
    A plugins/pcl/kernel/PCLKernel.cpp
    A plugins/pcl/kernel/PCLKernel.hpp
    R plugins/pcl/kernel/Smooth.cpp
    R plugins/pcl/kernel/Smooth.hpp
    A plugins/pcl/kernel/SmoothKernel.cpp
    A plugins/pcl/kernel/SmoothKernel.hpp
    R plugins/pcl/kernel/View.cpp
    R plugins/pcl/kernel/View.hpp
    A plugins/pcl/kernel/ViewKernel.cpp
    A plugins/pcl/kernel/ViewKernel.hpp
    M plugins/pgpointcloud/io/PgCommon.hpp
    M plugins/pgpointcloud/io/PgReader.cpp
    M plugins/pgpointcloud/io/PgReader.hpp
    M plugins/pgpointcloud/io/PgWriter.hpp
    M plugins/pgpointcloud/test/Pgtest-Support.hpp.in
    M plugins/rxp/io/RxpReader.cpp
    M plugins/rxp/io/RxpReader.hpp
    M plugins/rxp/test/Config.hpp.in
    M plugins/sqlite/io/SQLiteCommon.hpp
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteReader.hpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M plugins/sqlite/io/SQLiteWriter.hpp
    M src/FileUtils.cpp
    M src/KDIndex.cpp
    M src/Stage.cpp
    M src/StageInfo.cpp
    M src/StreamFactory.cpp
    M src/Utils.cpp
    R src/filters/Colorization.cpp
    M src/filters/Stats.cpp
    R src/kernel/Delta.cpp
    R src/kernel/Diff.cpp
    R src/kernel/Info.cpp
    R src/kernel/Kernel.cpp
    R src/kernel/KernelFactory.cpp
    R src/kernel/KernelInfo.cpp
    R src/kernel/Pipeline.cpp
    R src/kernel/Random.cpp
    R src/kernel/Sort.cpp
    R src/kernel/Support.cpp
    R src/kernel/Translate.cpp
    M src/plang/Invocation.cpp
    M test/unit/ConfigTest.cpp
    M test/unit/DimensionTest.cpp
    M test/unit/GDALUtilsTest.cpp
    M test/unit/LogTest.cpp
    M test/unit/OptionsTest.cpp
    M test/unit/SchemaTest.cpp
    M test/unit/StreamFactoryTest.cpp
    M test/unit/Support.cpp
    M test/unit/Support.hpp
    M test/unit/SupportTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
    M test/unit/io/terrasolid/TerraSolidReaderTest.cpp
    M test/unit/io/text/TextWriterTest.cpp
    M test/unit/plang/PLangTest.cpp
  Log Message:
Conflicts:
	src/CMakeLists.txt
	src/XMLSchema.cpp
  Commit: e52084bf303512e5e80e6e57f781c90d0dd13ed0
      https://github.com/PDAL/PDAL/commit/e52084bf303512e5e80e6e57f781c90d0dd13ed0
  Changed paths:
  Log Message:
Conflicts:
  Commit: c434970670f37f627d4147796928c8d64abaceae
      https://github.com/PDAL/PDAL/commit/c434970670f37f627d4147796928c8d64abaceae
  Date:   2014-12-04 (Thu, 04 Dec 2014)
  Changed paths:
    M include/pdal/DbReader.hpp
    M src/DbReader.cpp
  Log Message:
  DbReader for OCI.
  Commit: 9033b476794af94f61511ff512f0fa97d32caeab
      https://github.com/PDAL/PDAL/commit/9033b476794af94f61511ff512f0fa97d32caeab
  Date:   2014-12-08 (Mon, 08 Dec 2014)
  Changed paths:
    M src/DbReader.cpp
    M src/DbWriter.cpp
    M src/XMLSchema.cpp
  Log Message:
  SQLite checked with compression and integrated into int I/O.
  Commit: 41f0f9716c79305be5235ccccb51ad27994f29ce
      https://github.com/PDAL/PDAL/commit/41f0f9716c79305be5235ccccb51ad27994f29ce
  Date:   2014-12-09 (Tue, 09 Dec 2014)
  Changed paths:
    R src/Compression.cpp
    M src/DbReader.cpp
    M src/DbWriter.cpp
    M src/XMLSchema.cpp
  Log Message:
  Write scale into XMLSchema.
  Commit: 59e5acfa1f83146a8c8ea164d7e357151ff29bc9
      https://github.com/PDAL/PDAL/commit/59e5acfa1f83146a8c8ea164d7e357151ff29bc9
  Changed paths:
    M CMakeLists.txt
    A filters/merge/CMakeLists.txt
    A filters/merge/MergeFilter.hpp
    A filters/reprojection/CMakeLists.txt
    A filters/reprojection/ReprojectionFilter.cpp
    A filters/reprojection/ReprojectionFilter.hpp
    A filters/sort/CMakeLists.txt
    A filters/sort/SortFilter.hpp
    R include/pdal/filters/Merge.hpp
    R include/pdal/filters/Reprojection.hpp
    R include/pdal/filters/Sort.hpp
    M kernels/translate/CMakeLists.txt
    M kernels/translate/TranslateKernel.cpp
    R src/filters/Reprojection.cpp
    M test/unit/filters/SortFilterTest.cpp
  Log Message:
  Commit: 81491751d98ea820fe49f93a5d7566772f3f3144
      https://github.com/PDAL/PDAL/commit/81491751d98ea820fe49f93a5d7566772f3f3144
  Date:   2014-12-12 (Fri, 12 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M doc/development/testing.rst
    A filters/crop/CMakeLists.txt
    A filters/crop/CropFilter.cpp
    A filters/crop/CropFilter.hpp
    A filters/stats/CMakeLists.txt
    A filters/stats/StatsFilter.cpp
    A filters/stats/StatsFilter.hpp
    R include/pdal/filters/Crop.hpp
    R include/pdal/filters/Stats.hpp
    M kernels/KernelFactory.cpp
    M kernels/info/InfoKernel.hpp
    R src/filters/Crop.cpp
    R src/filters/Stats.cpp
    M test/unit/BoundsTest.cpp
    M test/unit/EnvironmentTest.cpp
    M test/unit/FileUtilsTest.cpp
    M test/unit/PointContextTest.cpp
    M test/unit/TestConfig.cpp
    M test/unit/TestConfig.hpp.in
    R test/unit/UnitTest.hpp
    M test/unit/UserCallbackTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/buffer/BufferTest.cpp
    M test/unit/io/faux/FauxReaderTest.cpp
    M test/unit/io/qfit/QFITReaderTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
    M test/unit/io/sbet/SbetWriterTest.cpp
    M test/unit/plang/PredicateFilterTest.cpp
    M test/unit/plang/ProgrammableFilterTest.cpp
    A vendor/gtest-1.7.0/CHANGES
    A vendor/gtest-1.7.0/CMakeLists.txt
    A vendor/gtest-1.7.0/CONTRIBUTORS
    A vendor/gtest-1.7.0/LICENSE
    A vendor/gtest-1.7.0/Makefile.am
    A vendor/gtest-1.7.0/Makefile.in
    A vendor/gtest-1.7.0/README
    A vendor/gtest-1.7.0/aclocal.m4
    A vendor/gtest-1.7.0/build-aux/config.guess
    A vendor/gtest-1.7.0/build-aux/config.h.in
    A vendor/gtest-1.7.0/build-aux/config.sub
    A vendor/gtest-1.7.0/build-aux/depcomp
    A vendor/gtest-1.7.0/build-aux/install-sh
    A vendor/gtest-1.7.0/build-aux/ltmain.sh
    A vendor/gtest-1.7.0/build-aux/missing
    A vendor/gtest-1.7.0/cmake/internal_utils.cmake
    A vendor/gtest-1.7.0/codegear/gtest.cbproj
    A vendor/gtest-1.7.0/codegear/gtest.groupproj
    A vendor/gtest-1.7.0/codegear/gtest_all.cc
    A vendor/gtest-1.7.0/codegear/gtest_link.cc
    A vendor/gtest-1.7.0/codegear/gtest_main.cbproj
    A vendor/gtest-1.7.0/codegear/gtest_unittest.cbproj
    A vendor/gtest-1.7.0/configure
    A vendor/gtest-1.7.0/configure.ac
    A vendor/gtest-1.7.0/fused-src/gtest/gtest-all.cc
    A vendor/gtest-1.7.0/fused-src/gtest/gtest.h
    A vendor/gtest-1.7.0/fused-src/gtest/gtest_main.cc
    A vendor/gtest-1.7.0/include/gtest/gtest-death-test.h
    A vendor/gtest-1.7.0/include/gtest/gtest-message.h
    A vendor/gtest-1.7.0/include/gtest/gtest-param-test.h
    A vendor/gtest-1.7.0/include/gtest/gtest-param-test.h.pump
    A vendor/gtest-1.7.0/include/gtest/gtest-printers.h
    A vendor/gtest-1.7.0/include/gtest/gtest-spi.h
    A vendor/gtest-1.7.0/include/gtest/gtest-test-part.h
    A vendor/gtest-1.7.0/include/gtest/gtest-typed-test.h
    A vendor/gtest-1.7.0/include/gtest/gtest.h
    A vendor/gtest-1.7.0/include/gtest/gtest_pred_impl.h
    A vendor/gtest-1.7.0/include/gtest/gtest_prod.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-death-test-internal.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-filepath.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-internal.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-linked_ptr.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-param-util-generated.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-param-util-generated.h.pump
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-param-util.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-port.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-string.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-tuple.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-tuple.h.pump
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-type-util.h
    A vendor/gtest-1.7.0/include/gtest/internal/gtest-type-util.h.pump
    A vendor/gtest-1.7.0/m4/acx_pthread.m4
    A vendor/gtest-1.7.0/m4/gtest.m4
    A vendor/gtest-1.7.0/m4/libtool.m4
    A vendor/gtest-1.7.0/m4/ltoptions.m4
    A vendor/gtest-1.7.0/m4/ltsugar.m4
    A vendor/gtest-1.7.0/m4/ltversion.m4
    A vendor/gtest-1.7.0/m4/lt~obsolete.m4
    A vendor/gtest-1.7.0/msvc/gtest-md.vcproj
    A vendor/gtest-1.7.0/msvc/gtest.vcproj
    A vendor/gtest-1.7.0/msvc/gtest_main-md.vcproj
    A vendor/gtest-1.7.0/msvc/gtest_main.vcproj
    A vendor/gtest-1.7.0/msvc/gtest_prod_test-md.vcproj
    A vendor/gtest-1.7.0/msvc/gtest_prod_test.vcproj
    A vendor/gtest-1.7.0/msvc/gtest_unittest-md.vcproj
    A vendor/gtest-1.7.0/msvc/gtest_unittest.vcproj
    A vendor/gtest-1.7.0/samples/prime_tables.h
    A vendor/gtest-1.7.0/samples/sample1.cc
    A vendor/gtest-1.7.0/samples/sample1.h
    A vendor/gtest-1.7.0/samples/sample10_unittest.cc
    A vendor/gtest-1.7.0/samples/sample1_unittest.cc
    A vendor/gtest-1.7.0/samples/sample2.cc
    A vendor/gtest-1.7.0/samples/sample2.h
    A vendor/gtest-1.7.0/samples/sample2_unittest.cc
    A vendor/gtest-1.7.0/samples/sample3-inl.h
    A vendor/gtest-1.7.0/samples/sample3_unittest.cc
    A vendor/gtest-1.7.0/samples/sample4.cc
    A vendor/gtest-1.7.0/samples/sample4.h
    A vendor/gtest-1.7.0/samples/sample4_unittest.cc
    A vendor/gtest-1.7.0/samples/sample5_unittest.cc
    A vendor/gtest-1.7.0/samples/sample6_unittest.cc
    A vendor/gtest-1.7.0/samples/sample7_unittest.cc
    A vendor/gtest-1.7.0/samples/sample8_unittest.cc
    A vendor/gtest-1.7.0/samples/sample9_unittest.cc
    A vendor/gtest-1.7.0/scripts/fuse_gtest_files.py
    A vendor/gtest-1.7.0/scripts/gen_gtest_pred_impl.py
    A vendor/gtest-1.7.0/scripts/gtest-config.in
    A vendor/gtest-1.7.0/scripts/pump.py
    A vendor/gtest-1.7.0/src/gtest-all.cc
    A vendor/gtest-1.7.0/src/gtest-death-test.cc
    A vendor/gtest-1.7.0/src/gtest-filepath.cc
    A vendor/gtest-1.7.0/src/gtest-internal-inl.h
    A vendor/gtest-1.7.0/src/gtest-port.cc
    A vendor/gtest-1.7.0/src/gtest-printers.cc
    A vendor/gtest-1.7.0/src/gtest-test-part.cc
    A vendor/gtest-1.7.0/src/gtest-typed-test.cc
    A vendor/gtest-1.7.0/src/gtest.cc
    A vendor/gtest-1.7.0/src/gtest_main.cc
    A vendor/gtest-1.7.0/test/gtest-death-test_ex_test.cc
    A vendor/gtest-1.7.0/test/gtest-death-test_test.cc
    A vendor/gtest-1.7.0/test/gtest-filepath_test.cc
    A vendor/gtest-1.7.0/test/gtest-linked_ptr_test.cc
    A vendor/gtest-1.7.0/test/gtest-listener_test.cc
    A vendor/gtest-1.7.0/test/gtest-message_test.cc
    A vendor/gtest-1.7.0/test/gtest-options_test.cc
    A vendor/gtest-1.7.0/test/gtest-param-test2_test.cc
    A vendor/gtest-1.7.0/test/gtest-param-test_test.cc
    A vendor/gtest-1.7.0/test/gtest-param-test_test.h
    A vendor/gtest-1.7.0/test/gtest-port_test.cc
    A vendor/gtest-1.7.0/test/gtest-printers_test.cc
    A vendor/gtest-1.7.0/test/gtest-test-part_test.cc
    A vendor/gtest-1.7.0/test/gtest-tuple_test.cc
    A vendor/gtest-1.7.0/test/gtest-typed-test2_test.cc
    A vendor/gtest-1.7.0/test/gtest-typed-test_test.cc
    A vendor/gtest-1.7.0/test/gtest-typed-test_test.h
    A vendor/gtest-1.7.0/test/gtest-unittest-api_test.cc
    A vendor/gtest-1.7.0/test/gtest_all_test.cc
    A vendor/gtest-1.7.0/test/gtest_break_on_failure_unittest.py
    A vendor/gtest-1.7.0/test/gtest_break_on_failure_unittest_.cc
    A vendor/gtest-1.7.0/test/gtest_catch_exceptions_test.py
    A vendor/gtest-1.7.0/test/gtest_catch_exceptions_test_.cc
    A vendor/gtest-1.7.0/test/gtest_color_test.py
    A vendor/gtest-1.7.0/test/gtest_color_test_.cc
    A vendor/gtest-1.7.0/test/gtest_env_var_test.py
    A vendor/gtest-1.7.0/test/gtest_env_var_test_.cc
    A vendor/gtest-1.7.0/test/gtest_environment_test.cc
    A vendor/gtest-1.7.0/test/gtest_filter_unittest.py
    A vendor/gtest-1.7.0/test/gtest_filter_unittest_.cc
    A vendor/gtest-1.7.0/test/gtest_help_test.py
    A vendor/gtest-1.7.0/test/gtest_help_test_.cc
    A vendor/gtest-1.7.0/test/gtest_list_tests_unittest.py
    A vendor/gtest-1.7.0/test/gtest_list_tests_unittest_.cc
    A vendor/gtest-1.7.0/test/gtest_main_unittest.cc
    A vendor/gtest-1.7.0/test/gtest_no_test_unittest.cc
    A vendor/gtest-1.7.0/test/gtest_output_test.py
    A vendor/gtest-1.7.0/test/gtest_output_test_.cc
    A vendor/gtest-1.7.0/test/gtest_output_test_golden_lin.txt
    A vendor/gtest-1.7.0/test/gtest_pred_impl_unittest.cc
    A vendor/gtest-1.7.0/test/gtest_premature_exit_test.cc
    A vendor/gtest-1.7.0/test/gtest_prod_test.cc
    A vendor/gtest-1.7.0/test/gtest_repeat_test.cc
    A vendor/gtest-1.7.0/test/gtest_shuffle_test.py
    A vendor/gtest-1.7.0/test/gtest_shuffle_test_.cc
    A vendor/gtest-1.7.0/test/gtest_sole_header_test.cc
    A vendor/gtest-1.7.0/test/gtest_stress_test.cc
    A vendor/gtest-1.7.0/test/gtest_test_utils.py
    A vendor/gtest-1.7.0/test/gtest_throw_on_failure_ex_test.cc
    A vendor/gtest-1.7.0/test/gtest_throw_on_failure_test.py
    A vendor/gtest-1.7.0/test/gtest_throw_on_failure_test_.cc
    A vendor/gtest-1.7.0/test/gtest_uninitialized_test.py
    A vendor/gtest-1.7.0/test/gtest_uninitialized_test_.cc
    A vendor/gtest-1.7.0/test/gtest_unittest.cc
    A vendor/gtest-1.7.0/test/gtest_xml_outfile1_test_.cc
    A vendor/gtest-1.7.0/test/gtest_xml_outfile2_test_.cc
    A vendor/gtest-1.7.0/test/gtest_xml_outfiles_test.py
    A vendor/gtest-1.7.0/test/gtest_xml_output_unittest.py
    A vendor/gtest-1.7.0/test/gtest_xml_output_unittest_.cc
    A vendor/gtest-1.7.0/test/gtest_xml_test_utils.py
    A vendor/gtest-1.7.0/test/production.cc
    A vendor/gtest-1.7.0/test/production.h
    A vendor/gtest-1.7.0/xcode/Config/DebugProject.xcconfig
    A vendor/gtest-1.7.0/xcode/Config/FrameworkTarget.xcconfig
    A vendor/gtest-1.7.0/xcode/Config/General.xcconfig
    A vendor/gtest-1.7.0/xcode/Config/ReleaseProject.xcconfig
    A vendor/gtest-1.7.0/xcode/Config/StaticLibraryTarget.xcconfig
    A vendor/gtest-1.7.0/xcode/Config/TestTarget.xcconfig
    A vendor/gtest-1.7.0/xcode/Resources/Info.plist
    A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/Info.plist
    A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/WidgetFramework.xcodeproj/project.pbxproj
    A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/runtests.sh
    A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/widget.cc
    A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/widget.h
    A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/widget_test.cc
    A vendor/gtest-1.7.0/xcode/Scripts/runtests.sh
    A vendor/gtest-1.7.0/xcode/Scripts/versiongenerate.py
    A vendor/gtest-1.7.0/xcode/gtest.xcodeproj/project.pbxproj
  Log Message:
Conflicts:
  Commit: beb7d3176da8a7b141171686dcc9717549e3c141
      https://github.com/PDAL/PDAL/commit/beb7d3176da8a7b141171686dcc9717549e3c141
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M io/bpf/BpfHeader.cpp
    A src/DbReader.cpp
    A src/DbWriter.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge pull request #645 from PDAL/issues-599
Issues 599
Compare: https://github.com/PDAL/PDAL/compare/ec0bf2599240...beb7d3176da8
More information about the pdal-commits mailing list
