[pdal-commits] [PDAL/PDAL] f55780: Clean up tests that invoked deprecated filters
GitHub noreply at github.com
Mon Dec 22 07:50:28 PST 2014
  Branch: refs/heads/update-tests-using-deprecated-filters
  Home:   https://github.com/PDAL/PDAL
  Commit: f55780539be72997c9929c21076fcabbcc9b577f
      https://github.com/PDAL/PDAL/commit/f55780539be72997c9929c21076fcabbcc9b577f
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-12-18 (Thu, 18 Dec 2014)
  Changed paths:
    M test/data/drivers/text-writer-geojson.xml
    M test/data/drivers/text-writer-space-delimited.xml
    M test/data/filters/chip.xml
    M test/data/filters/colorize-multi.xml
    M test/data/filters/crop_reproject.xml
    M test/data/filters/decimate.xml
    M test/data/filters/reproject.xml
    M test/data/oracle/big-read.xml
    M test/data/oracle/big-write.xml
    M test/data/oracle/qfit-write.xml
    M test/data/oracle/read.xml
    M test/data/oracle/view-read.xml
    M test/data/oracle/write.xml
    M test/data/pipeline/drop_color.xml
    M test/data/pipeline/pipeline_interpolate.xml
    M test/data/pipeline/pipeline_mississippi.xml
    M test/data/pipeline/pipeline_mississippi_reverse.xml
    M test/data/pipeline/pipeline_write2.xml
    M test/data/soci/sthelens-write.xml
    M test/data/soci/write-utm.xml
    M test/data/soci/write.xml
    M test/perf/chipper.xml
  Log Message:
  Commit: 2aacd644ff32ca544dab0de5de4cb97f255a6bda
      https://github.com/PDAL/PDAL/commit/2aacd644ff32ca544dab0de5de4cb97f255a6bda
  Date:   2014-12-22 (Mon, 22 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M plugins/nitf/test/NitfReaderTest.cpp
    R test/data/bpf/bpf.xml
    A test/data/bpf/bpf.xml.in
    R test/data/bpf/bpf2nitf.xml
    A test/data/bpf/bpf2nitf.xml.in
    R test/data/drivers/p2g-writer.xml
    R test/data/drivers/sqlite-reader.xml
    R test/data/drivers/sqlite-writer.xml
    R test/data/drivers/text-writer-csv.xml
    R test/data/drivers/text-writer-geojson.xml
    R test/data/drivers/text-writer-space-delimited.xml
    R test/data/filters/attribute.xml
    A test/data/filters/attribute.xml.in
    R test/data/filters/chip.xml
    A test/data/filters/chip.xml.in
    R test/data/filters/chipper.xml
    A test/data/filters/chipper.xml.in
    R test/data/filters/colorize-multi.xml
    A test/data/filters/colorize-multi.xml.in
    R test/data/filters/colorize.xml
    A test/data/filters/colorize.xml.in
    R test/data/filters/crop_reproject.xml
    A test/data/filters/crop_reproject.xml.in
    R test/data/filters/crop_wkt.xml
    A test/data/filters/crop_wkt.xml.in
    R test/data/filters/crop_wkt_2d.xml
    A test/data/filters/crop_wkt_2d.xml.in
    R test/data/filters/crop_wkt_2d_classification.xml
    A test/data/filters/crop_wkt_2d_classification.xml.in
    R test/data/filters/decimate.xml
    A test/data/filters/decimate.xml.in
    R test/data/filters/ferry.xml
    A test/data/filters/ferry.xml.in
    R test/data/filters/hexbin-info.xml
    A test/data/filters/hexbin-info.xml.in
    R test/data/filters/hexbin.xml
    A test/data/filters/hexbin.xml.in
    R test/data/filters/index.xml
    R test/data/filters/merge.xml
    A test/data/filters/merge.xml.in
    R test/data/filters/reproject.xml
    A test/data/filters/reproject.xml.in
    R test/data/filters/scaling.xml
    R test/data/filters/selector.xml
    R test/data/filters/sort.xml
    A test/data/filters/sort.xml.in
    R test/data/filters/splitter.xml
    A test/data/filters/splitter.xml.in
    R test/data/filters/stats.xml
    A test/data/filters/stats.xml.in
    R test/data/hole/crop.xml
    A test/data/hole/crop.xml.in
    R test/data/icebridge/pipeline.xml
    A test/data/icebridge/pipeline.xml.in
    A test/data/io/p2g-writer.xml.in
    A test/data/io/sqlite-reader.xml.in
    A test/data/io/sqlite-writer.xml.in
    A test/data/io/text-writer-csv.xml.in
    A test/data/io/text-writer-geojson.xml.in
    A test/data/io/text-writer-space-delimited.xml.in
    R test/data/nitf/chipper.xml
    A test/data/nitf/chipper.xml.in
    R test/data/nitf/conversion.xml
    A test/data/nitf/conversion.xml.in
    R test/data/nitf/las2nitf.xml
    A test/data/nitf/las2nitf.xml.in
    R test/data/nitf/write_laz.xml
    A test/data/nitf/write_laz.xml.in
    R test/data/nitf/write_options.xml
    A test/data/nitf/write_options.xml.in
    R test/data/pipeline/drop_color.xml
    A test/data/pipeline/drop_color.xml.in
    R test/data/pipeline/pipeline_interpolate.xml
    A test/data/pipeline/pipeline_interpolate.xml.in
    R test/data/pipeline/pipeline_metadata_reader.xml
    A test/data/pipeline/pipeline_metadata_reader.xml.in
    R test/data/pipeline/pipeline_metadata_writer.xml
    A test/data/pipeline/pipeline_metadata_writer.xml.in
    R test/data/pipeline/pipeline_mississippi.xml
    A test/data/pipeline/pipeline_mississippi.xml.in
    R test/data/pipeline/pipeline_mississippi_reverse.xml
    A test/data/pipeline/pipeline_mississippi_reverse.xml.in
    R test/data/pipeline/pipeline_multioptions.xml
    A test/data/pipeline/pipeline_multioptions.xml.in
    R test/data/pipeline/pipeline_read.xml
    A test/data/pipeline/pipeline_read.xml.in
    R test/data/pipeline/pipeline_read_notype.xml
    A test/data/pipeline/pipeline_read_notype.xml.in
    R test/data/pipeline/pipeline_readcomments.xml
    A test/data/pipeline/pipeline_readcomments.xml.in
    R test/data/pipeline/pipeline_write.xml
    A test/data/pipeline/pipeline_write.xml.in
    R test/data/pipeline/pipeline_write2.xml
    A test/data/pipeline/pipeline_write2.xml.in
    R test/data/pipeline/pipeline_writecomments.xml
    A test/data/pipeline/pipeline_writecomments.xml.in
    R test/data/plang/from-module.xml
    A test/data/plang/from-module.xml.in
    R test/data/plang/predicate-embed.xml
    A test/data/plang/predicate-embed.xml.in
    R test/data/plang/predicate-keep-ground-and-unclass.xml
    A test/data/plang/predicate-keep-ground-and-unclass.xml.in
    R test/data/plang/predicate-keep-last-return.xml
    A test/data/plang/predicate-keep-last-return.xml.in
    R test/data/plang/predicate-keep-specified-returns.xml
    A test/data/plang/predicate-keep-specified-returns.xml.in
    R test/data/plang/programmable-update-y-dims.xml
    A test/data/plang/programmable-update-y-dims.xml.in
    R test/data/qfit/conversion.xml
    A test/data/qfit/conversion.xml.in
    R test/data/qfit/little-endian-conversion.xml
    A test/data/qfit/little-endian-conversion.xml.in
    R test/data/qfit/pipeline.xml
    A test/data/qfit/pipeline.xml.in
    R test/data/qfit/reader.xml
    A test/data/qfit/reader.xml.in
    R test/data/sbet/pipeline.xml
    A test/data/sbet/pipeline.xml.in
    M test/perf/chipper_nocache.xml
    M test/unit/CMakeLists.txt
    M test/unit/Support.cpp
    M test/unit/Support.hpp
    M test/unit/TestConfig.cpp
    M test/unit/TestConfig.hpp.in
    M test/unit/apps/pcpipelineTest.cpp
    M test/unit/filters/MergeTest.cpp
  Log Message:
  configure tests to more reliably locate test data, beef up pcpipelineTest to test the sample pipelines
Compare: https://github.com/PDAL/PDAL/compare/b0395841fa84...2aacd644ff32
More information about the pdal-commits mailing list
