[pdal-commits] [PDAL/PDAL] 0a0538: use KernelFactory and KernelInfo to display list o...
GitHub noreply at github.com
Tue Dec 23 12:08:47 PST 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 0a05387623e82305677da3a27aef0bb105483f14
      https://github.com/PDAL/PDAL/commit/0a05387623e82305677da3a27aef0bb105483f14
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-12-22 (Mon, 22 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M apps/pdal.cpp
    M kernels/KernelFactory.cpp
    M kernels/delta/DeltaKernel.hpp
    M kernels/diff/DiffKernel.hpp
    M kernels/info/InfoKernel.hpp
    M kernels/pipeline/PipelineKernel.hpp
    M kernels/random/RandomKernel.hpp
    M kernels/sort/SortKernel.hpp
    M kernels/translate/TranslateKernel.hpp
    M plugins/pcl/kernel/GroundKernel.hpp
    M plugins/pcl/kernel/PCLKernel.hpp
    M plugins/pcl/kernel/SmoothKernel.hpp
    M plugins/pcl/kernel/ViewKernel.hpp
    M test/unit/Support.cpp
  Log Message:
  use KernelFactory and KernelInfo to display list of available kernels and determine if the provided kernel is valid in PDAL application
  Commit: 70c66923c487250cff81ddf5e37868410f0a4f7b
      https://github.com/PDAL/PDAL/commit/70c66923c487250cff81ddf5e37868410f0a4f7b
  Changed paths:
    M test/unit/SupportTest.cpp
  Log Message:
  test binary directory may differ from the pdal app directory (if PDAL_BUNDLE=ON), test names may also change, so just use pdal app instead of a specific test
  Commit: fc36f47943b1659746918be74c2013761e67fe8d
      https://github.com/PDAL/PDAL/commit/fc36f47943b1659746918be74c2013761e67fe8d
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-12-23 (Tue, 23 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
  Log Message:
  Merge pull request #672 from PDAL/issues/666-kernel-plugins
Issues/666 kernel plugins
Compare: https://github.com/PDAL/PDAL/compare/5ad5cd112540...fc36f47943b1
More information about the pdal-commits mailing list
