[pdal-commits] [PDAL/PDAL] 62ed48: fix up vector resize() to 0 so that we can push_ba...
GitHub noreply at github.com
Mon Jan 27 11:29:45 PST 2014
  Branch: refs/heads/issues/228-common-include
  Home:   https://github.com/PDAL/PDAL
  Commit: 62ed48701cdbdd0ea94a05135a90b6a026181e37
      https://github.com/PDAL/PDAL/commit/62ed48701cdbdd0ea94a05135a90b6a026181e37
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2014-01-26 (Sun, 26 Jan 2014)
  Changed paths:
    M src/drivers/pgpointcloud/Reader.cpp
  Log Message:
  fix up vector resize() to 0 so that we can push_back the new bytes as we decode them
  Commit: 1a37e0a3377e786ca6cac502f94da02289ad21a8
      https://github.com/PDAL/PDAL/commit/1a37e0a3377e786ca6cac502f94da02289ad21a8
  Changed paths:
    M include/pdal/drivers/pgpointcloud/Reader.hpp
  Log Message:
  don't alloc a new std::string copy of the patch's hex data
  Commit: 616c7858dbfc1e354395380d50033eaa9f775b88
      https://github.com/PDAL/PDAL/commit/616c7858dbfc1e354395380d50033eaa9f775b88
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-01-27 (Mon, 27 Jan 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    A cmake/pdal_options.cmake
    A cmake/pdal_targets.cmake
    M cmake/pdal_utils.cmake
    M src/CMakeLists.txt
    M test/unit/CMakeLists.txt
  Log Message:
  related to #234 and #235, CMake "improvements"
  - moved some options (e.g., PDAL_BUILD_STATIC) to pdal_options.cmake
  - created (really borrowed from PCL) macros for adding libraries and
    executables: PDAL_ADD_LIBRARY, PDAL_ADD_EXECUTABLE
  - library linkage (i.e., PUBLIC/PRIVATE) determined at the top level
    in pdal_options.cmake
  - embedded boost lib name does not need quotes, in fact, we lose the
    correct path on Windows if they're there
  - install commands (mostly) moved inside the PDAL_ADD_* macros
  Commit: c9052de97b57e5ef03646b41746c5349e095cf72
      https://github.com/PDAL/PDAL/commit/c9052de97b57e5ef03646b41746c5349e095cf72
  Changed paths:
  Log Message:
  tests don't fail locally, perhaps this has something to do with the unit
tests being installed, or linked with boost libraries multiple times,
let's try without the macro
  Commit: b3474b9e842e22ce625b8ac4326ae61632ead639
      https://github.com/PDAL/PDAL/commit/b3474b9e842e22ce625b8ac4326ae61632ead639
  Changed paths:
    M cmake/pdal_options.cmake
  Log Message:
  if (NOT PDAL_BUILD_STATIC) seemed a little confusing; also seeing if the boost linkage is the problem with the build
  Commit: 8fb52738ba9af52320e879af66077fd117d6a431
      https://github.com/PDAL/PDAL/commit/8fb52738ba9af52320e879af66077fd117d6a431
  Changed paths:
  Log Message:
  linking PDAL_UTILITY against Boost appears to have been the source of all the havoc
  Commit: e4b8f212b44546d62a08f9b5a60366c146382bae
      https://github.com/PDAL/PDAL/commit/e4b8f212b44546d62a08f9b5a60366c146382bae
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #237 from PDAL/tweaking-cmake-files
proposed CMake modifications
  Commit: c3062b510cfda722557b19934f0f8548914351ef
      https://github.com/PDAL/PDAL/commit/c3062b510cfda722557b19934f0f8548914351ef
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge branch 'master' into issues/228-common-include
  Commit: c0f498b5b0395c1a53ff807dc3e59eba2f1a3b59
      https://github.com/PDAL/PDAL/commit/c0f498b5b0395c1a53ff807dc3e59eba2f1a3b59
  Changed paths:
    M doc/tutorial/writing.txt
    M include/pdal/pdal.hpp
  Log Message:
  only include base stuff in <pdal/pdal.hpp>, not Drivers, Filters, and Kernel, which a user can include separately as needed
Compare: https://github.com/PDAL/PDAL/compare/21f759279039...c0f498b5b039
More information about the pdal-commits mailing list
