[pdal-commits] [PDAL/PDAL] 2a9cbb: Squashed commit of the following:
GitHub noreply at github.com
Tue Nov 11 10:59:03 PST 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 2a9cbbf97ce1809628e262534a1683d151ada6e2
      https://github.com/PDAL/PDAL/commit/2a9cbbf97ce1809628e262534a1683d151ada6e2
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2014-11-11 (Tue, 11 Nov 2014)
  Changed paths:
    M CMakeLists.txt
    A doc/stages/drivers.rxp.reader.rst
    M doc/stages/index.rst
    M include/pdal/Dimension.hpp
    M pdal_defines.h.in
    M plugins/CMakeLists.txt
    A plugins/rxp/CMakeLists.txt
    A plugins/rxp/drivers/RxpReader.cpp
    A plugins/rxp/drivers/RxpReader.hpp
    A plugins/rxp/test/Config.hpp.in
    A plugins/rxp/test/RxpReaderTest.cpp
    A plugins/rxp/test/data/130501_232206_cut.rxp
    M src/StageFactory.cpp
  Log Message:
commit 810935058699f01b08cbbf64f3cb59679932e158
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date:   Thu Aug 14 19:19:31 2014 +0000
    Add the rxp reader
    RXP is the streaming file format used by RIEGL Laser Measurement Systems
    (http://www.riegl.com). Support for reading rxp
    files is provided by RiVLib, RIEGL's own library which they release for
    use by their customers.
    RiVLib only supports reading rxp files, not writing them.
More information about the pdal-commits mailing list
