[pdal-commits] [PDAL/PDAL] cf92c9: default my config to use the new BUILD_PLUGIN synt...
GitHub noreply at github.com
Wed Nov 12 13:53:02 PST 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: cf92c90c79ef256b4ce5d0c282fcc6610c57828c
      https://github.com/PDAL/PDAL/commit/cf92c90c79ef256b4ce5d0c282fcc6610c57828c
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-11-12 (Wed, 12 Nov 2014)
  Changed paths:
    M cmake/examples/hobu-config.sh
  Log Message:
  default my config to use the new BUILD_PLUGIN syntax
  Commit: dd81c835d3ee594a6a63618c59ad9985d12df416
      https://github.com/PDAL/PDAL/commit/dd81c835d3ee594a6a63618c59ad9985d12df416
  Changed paths:
    M CMakeLists.txt
  Log Message:
  _TESTS of corresponding _PLUGIN cmake_dependent_option should default to ON
  Commit: 1f67f5b998e253f41efafd650b8c2b8706cb913a
      https://github.com/PDAL/PDAL/commit/1f67f5b998e253f41efafd650b8c2b8706cb913a
  Changed paths:
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
  Log Message:
  pgpointcloud test cleanup
Compare: https://github.com/PDAL/PDAL/compare/2d16e2f846ef...1f67f5b998e2
More information about the pdal-commits mailing list
