[pdal-commits] [PDAL/PDAL] 534729: Charbuf uses std::ios::pos_type, not Charbuf::pos_...
GitHub noreply at github.com
Fri Nov 14 08:30:22 PST 2014
  Branch: refs/heads/lasdump
  Home:   https://github.com/PDAL/PDAL
  Commit: 53472963c58331ed6e16833fb6afd6f78612f038
      https://github.com/PDAL/PDAL/commit/53472963c58331ed6e16833fb6afd6f78612f038
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-11-12 (Wed, 12 Nov 2014)
  Changed paths:
    M include/pdal/Charbuf.hpp
    M src/Charbuf.cpp
  Log Message:
  Charbuf uses std::ios::pos_type, not Charbuf::pos_type #512
  Commit: 1f23750a718eba5d9626026b7d78187961b744ce
      https://github.com/PDAL/PDAL/commit/1f23750a718eba5d9626026b7d78187961b744ce
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M src/Charbuf.cpp
  Log Message:
  Merge pull request #514 from PDAL/issues/514-charbuf-export
Closes #514
  Commit: 36c2c1a01d91f30dcffc537e60ae3a7a410aae46
      https://github.com/PDAL/PDAL/commit/36c2c1a01d91f30dcffc537e60ae3a7a410aae46
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Changed paths:
    M CMakeLists.txt
    M plugins/nitf/CMakeLists.txt
  Log Message:
  Turn off NITF by default
Don't build NITF support by default. If NITF support is requested, error
if we can't find Nitro.
  Commit: b05b029ac827be7fb8df75a598338cdcb7860465
      https://github.com/PDAL/PDAL/commit/b05b029ac827be7fb8df75a598338cdcb7860465
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #582 from gadomski/nitf-default-off
  Commit: 09e498565583ec1e6500d81314f1e440f60d7e02
      https://github.com/PDAL/PDAL/commit/09e498565583ec1e6500d81314f1e440f60d7e02
  Changed paths:
    M CMakeLists.txt
    M cmake/examples/hobu-config.sh
    A cmake/modules/FindLazperf.cmake
    A include/pdal/Compression.hpp
    M include/pdal/PointBuffer.hpp
    M include/pdal/PointContext.hpp
    M include/pdal/XMLSchema.hpp
    M pdal_defines.h.in
    M plugins/pcl/CMakeLists.txt
    M plugins/pgpointcloud/drivers/PgCommon.hpp
    M plugins/pgpointcloud/drivers/PgWriter.cpp
    M plugins/pgpointcloud/drivers/PgWriter.hpp
    M plugins/sqlite/drivers/SQLiteCommon.hpp
    M plugins/sqlite/drivers/SQLiteReader.cpp
    M plugins/sqlite/drivers/SQLiteWriter.cpp
    M plugins/sqlite/drivers/SQLiteWriter.hpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M src/CMakeLists.txt
    A src/Compression.cpp
    M src/PointBuffer.cpp
    M src/XMLSchema.cpp
    M test/unit/CMakeLists.txt
    A test/unit/CompressionTest.cpp
  Log Message:
  Implement laz-perf compression #562
SQLite driver is done, but others to follow
  Commit: 2d16e2f846effcda3e4bb71371aecb567ec36056
      https://github.com/PDAL/PDAL/commit/2d16e2f846effcda3e4bb71371aecb567ec36056
  Changed paths:
    M CMakeLists.txt
    M include/pdal/Compression.hpp
  Log Message:
  un-break master due to #562 compression stuff
  Commit: cf92c90c79ef256b4ce5d0c282fcc6610c57828c
      https://github.com/PDAL/PDAL/commit/cf92c90c79ef256b4ce5d0c282fcc6610c57828c
  Changed paths:
  Log Message:
  default my config to use the new BUILD_PLUGIN syntax
  Commit: dd81c835d3ee594a6a63618c59ad9985d12df416
      https://github.com/PDAL/PDAL/commit/dd81c835d3ee594a6a63618c59ad9985d12df416
  Changed paths:
    M CMakeLists.txt
  Log Message:
  _TESTS of corresponding _PLUGIN cmake_dependent_option should default to ON
  Commit: 1f67f5b998e253f41efafd650b8c2b8706cb913a
      https://github.com/PDAL/PDAL/commit/1f67f5b998e253f41efafd650b8c2b8706cb913a
  Changed paths:
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
  Log Message:
  pgpointcloud test cleanup
  Commit: 04715e1e712a9ef857822a5ff18c1172233495d7
      https://github.com/PDAL/PDAL/commit/04715e1e712a9ef857822a5ff18c1172233495d7
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M include/pdal/drivers/las/VariableLengthRecord.hpp
  Log Message:
  Add non-const data()
  Commit: e952c38f8c455d1ce75dc11c526a755272996dbd
      https://github.com/PDAL/PDAL/commit/e952c38f8c455d1ce75dc11c526a755272996dbd
  Date:   2014-11-13 (Thu, 13 Nov 2014)
  Changed paths:
    M scripts/ci/before_install.sh
  Log Message:
  Revert cmake 3.0 stuff.
  Commit: ec397127819fc8ad71fbf102dd41af5ad3574c70
      https://github.com/PDAL/PDAL/commit/ec397127819fc8ad71fbf102dd41af5ad3574c70
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
  Log Message:
  install cmake 2.8.12 from PPA
  Commit: 455d1a45e4e936eeac0e05126bd14fd8c22c4bca
      https://github.com/PDAL/PDAL/commit/455d1a45e4e936eeac0e05126bd14fd8c22c4bca
  Changed paths:
    M plugins/pgpointcloud/CMakeLists.txt
  Log Message:
  include pgpointcloud bin directory
  Commit: ba61ca4aa727767d4f6a76e41db7fd35dbbde7b6
      https://github.com/PDAL/PDAL/commit/ba61ca4aa727767d4f6a76e41db7fd35dbbde7b6
  Changed paths:
  Log Message:
  Merge pull request #585 from PDAL/issues/583-pgpointcloud-include
closes #583
  Commit: f9ae6140974e9a802507387f688d6e128295578c
      https://github.com/PDAL/PDAL/commit/f9ae6140974e9a802507387f688d6e128295578c
  Changed paths:
  Log Message:
  Merge pull request #584 from PDAL/cmake-2.8.12-on-travis
  Commit: 50136962eb6d672355cb71161a7608e643f8dc42
      https://github.com/PDAL/PDAL/commit/50136962eb6d672355cb71161a7608e643f8dc42
  Date:   2014-11-14 (Fri, 14 Nov 2014)
  Changed paths:
    M CMakeLists.txt
    M pdal_defines.h.in
    M src/Charbuf.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into lasdump
Conflicts:
	CMakeLists.txt
Compare: https://github.com/PDAL/PDAL/compare/c214065d0f3f...50136962eb6d
More information about the pdal-commits mailing list
