[pdal-commits] [PDAL/PDAL] b2f48d: Port SBET Reader and Writer
GitHub noreply at github.com
Mon Nov 17 18:22:04 PST 2014
  Branch: refs/heads/move-sbet-drivers
  Home:   https://github.com/PDAL/PDAL
  Commit: b2f48db7ffded26653910bead9d363c63f6ff7d9
      https://github.com/PDAL/PDAL/commit/b2f48db7ffded26653910bead9d363c63f6ff7d9
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-11-17 (Mon, 17 Nov 2014)
  Changed paths:
    M cmake/pdal_targets.cmake
    R doc/stages/drivers.sbet.reader.rst
    M doc/stages/index.rst
    A doc/stages/readers.sbet.rst
    M drivers/CMakeLists.txt
    M drivers/faux/CMakeLists.txt
    A drivers/sbet/CMakeLists.txt
    A drivers/sbet/SbetCommon.cpp
    A drivers/sbet/SbetCommon.hpp
    A drivers/sbet/SbetReader.cpp
    A drivers/sbet/SbetReader.hpp
    A drivers/sbet/SbetWriter.cpp
    A drivers/sbet/SbetWriter.hpp
    M include/pdal/Drivers.hpp
    R include/pdal/drivers/sbet/Common.hpp
    R include/pdal/drivers/sbet/Reader.hpp
    R include/pdal/drivers/sbet/Writer.hpp
    M src/CMakeLists.txt
    M src/StageFactory.cpp
    R src/drivers/sbet/Common.cpp
    R src/drivers/sbet/Reader.cpp
    R src/drivers/sbet/Writer.cpp
    M test/data/sbet/pipeline.xml
    M test/unit/CMakeLists.txt
    M test/unit/drivers/sbet/SbetReaderTest.cpp
    M test/unit/drivers/sbet/SbetWriterTest.cpp
  Log Message:
This changes PDAL_ADD_DRIVER slightly. Instead of propagating
PDAL_TARGET_OBJECTS to PARENT_SCOPE within the macro, we pass them back
to the driver CMakeLists, where they can be combined with other object
libraries and propagating to PARENT_SCOPE. This is necessary for drivers
that may have both a reader and a writer, in which case the final
library was the only one being passed back up to PARENT_SCOPE with the
original macro.
More information about the pdal-commits mailing list
