[pdal-commits] [PDAL/PDAL] b50358: Port QFIT Reader
GitHub noreply at github.com
Wed Nov 19 08:47:29 PST 2014
  Branch: refs/heads/move-terrasolid-driver
  Home:   https://github.com/PDAL/PDAL
  Commit: b50358ec0c49f370c67121de584907187b51c1ea
      https://github.com/PDAL/PDAL/commit/b50358ec0c49f370c67121de584907187b51c1ea
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-11-18 (Tue, 18 Nov 2014)
  Changed paths:
    R doc/stages/drivers.qfit.reader.rst
    M doc/stages/index.rst
    A doc/stages/readers.qfit.rst
    M drivers/CMakeLists.txt
    A drivers/qfit/CMakeLists.txt
    A drivers/qfit/QfitReader.cpp
    A drivers/qfit/QfitReader.hpp
    M include/pdal/Drivers.hpp
    R include/pdal/drivers/qfit/Reader.hpp
    M src/CMakeLists.txt
    M src/StageFactory.cpp
    R src/drivers/qfit/Reader.cpp
    M test/data/oracle/qfit-write.xml
    M test/data/qfit/conversion.xml
    M test/data/qfit/little-endian-conversion.xml
    M test/data/qfit/pipeline.xml
    M test/data/qfit/reader.xml
    M test/unit/CMakeLists.txt
    M test/unit/drivers/qfit/QFITReaderTest.cpp
  Log Message:
  Port QFIT Reader
  Commit: 00cbb23ad9ac0cf50166c94b3092ce98f99695e2
      https://github.com/PDAL/PDAL/commit/00cbb23ad9ac0cf50166c94b3092ce98f99695e2
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M include/pdal/Compression.hpp
    M include/pdal/PointBuffer.hpp
    M plugins/sqlite/drivers/SQLiteCommon.hpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M test/unit/CompressionTest.cpp
  Log Message:
  Implement stream-based PointBuffer constructor and byte fetching #604
  Commit: 1c1c68942be5bc86692b7f4d504d8686d556904e
      https://github.com/PDAL/PDAL/commit/1c1c68942be5bc86692b7f4d504d8686d556904e
  Changed paths:
    A drivers/bpf/BpfHeader.cpp
    A drivers/bpf/BpfHeader.hpp
    A drivers/bpf/BpfReader.cpp
    A drivers/bpf/BpfReader.hpp
    A drivers/bpf/CMakeLists.txt
    R include/pdal/drivers/bpf/BpfHeader.hpp
    R include/pdal/drivers/bpf/BpfReader.hpp
    R src/drivers/bpf/BpfHeader.cpp
    R src/drivers/bpf/BpfReader.cpp
    M test/data/bpf/bpf.xml
    M test/unit/drivers/bpf/BPFTest.cpp
  Log Message:
  Port BPF driver
  Commit: ffb18c4041688ff6bc887682ae843c09d6ea1cc0
      https://github.com/PDAL/PDAL/commit/ffb18c4041688ff6bc887682ae843c09d6ea1cc0
  Changed paths:
    R doc/stages/drivers.text.writer.rst
    A doc/stages/writers.text.rst
    A drivers/text/CMakeLists.txt
    A drivers/text/TextWriter.cpp
    A drivers/text/TextWriter.hpp
    R include/pdal/drivers/text/Writer.hpp
    R src/drivers/text/Writer.cpp
    M test/data/drivers/text-writer-csv.xml
    M test/data/drivers/text-writer-geojson.xml
    M test/data/drivers/text-writer-space-delimited.xml
    M test/data/filters/colorize-multi.xml
    M test/data/filters/decimate.xml
    M test/data/icebridge/pipeline.xml
    M test/data/sbet/pipeline.xml
    M test/unit/drivers/text/TextWriterTest.cpp
  Log Message:
  Port Text Writer
  Commit: 5fd33654d291499e149e968c1769b93594cb330c
      https://github.com/PDAL/PDAL/commit/5fd33654d291499e149e968c1769b93594cb330c
  Date:   2014-11-19 (Wed, 19 Nov 2014)
  Changed paths:
  Log Message:
  Merge pull request #608 from PDAL/move-text-driver
Port Text Writer
  Commit: 2dec7e4cc38c0c446a21b70630871a9197a320ac
      https://github.com/PDAL/PDAL/commit/2dec7e4cc38c0c446a21b70630871a9197a320ac
  Changed paths:
  Log Message:
  Merge pull request #607 from PDAL/move-bpf-driver
Port BPF driver
  Commit: c1c28795827c66f699957c438e803744cfeb9cd8
      https://github.com/PDAL/PDAL/commit/c1c28795827c66f699957c438e803744cfeb9cd8
  Changed paths:
  Log Message:
  Merge pull request #606 from PDAL/move-qfit-driver
Port QFIT Reader
  Commit: aa1371b4fe6410c463c1edcd93698cb5a9e75cdd
      https://github.com/PDAL/PDAL/commit/aa1371b4fe6410c463c1edcd93698cb5a9e75cdd
  Changed paths:
    R doc/stages/drivers.buffer.reader.rst
    A doc/stages/readers.buffer.rst
    A drivers/buffer/BufferReader.hpp
    R include/pdal/drivers/buffer/BufferReader.hpp
    M src/kernel/Kernel.cpp
    M src/kernel/Sort.cpp
    M src/kernel/Translate.cpp
    M test/unit/drivers/buffer/BufferTest.cpp
  Log Message:
  Port Buffer driver
  Commit: 04bfcf3acef79dbf65874a0436f70a376dac0d8a
      https://github.com/PDAL/PDAL/commit/04bfcf3acef79dbf65874a0436f70a376dac0d8a
  Changed paths:
    M doc/tutorial/writing.rst
  Log Message:
  update tutorial that uses BufferReader
  Commit: 339c96fe8a23ef55c2d674213e9c581f84e9e165
      https://github.com/PDAL/PDAL/commit/339c96fe8a23ef55c2d674213e9c581f84e9e165
  Changed paths:
  Log Message:
  Merge pull request #611 from PDAL/move-buffer-driver
Move buffer driver
  Commit: 7944e67ccb56cea6fe7925f75dc01660486a2e6c
      https://github.com/PDAL/PDAL/commit/7944e67ccb56cea6fe7925f75dc01660486a2e6c
  Changed paths:
    M CMakeLists.txt
    R doc/stages/drivers.csar.reader.rst
    R doc/stages/drivers.csardb.reader.rst
    R include/pdal/drivers/caris/CloudReader.hpp
    M pdal_defines.h.in
    R src/drivers/caris/CloudIterator.cpp
    R src/drivers/caris/CloudReader.cpp
    R src/drivers/caris/Utils.cpp
    R src/drivers/caris/Utils.hpp
    R src/drivers/caris/caris/caris_pc_wrapper.c
    R src/drivers/caris/caris/caris_pc_wrapper.h
    R src/drivers/caris/config.h
    R src/drivers/caris/linkline.cpp
    R src/drivers/caris/pdal_csar.cpp
    R src/drivers/caris/pdal_csar.def
    M src/pdal_config.cpp
    R test/unit/drivers/caris/CarisReaderTest.cpp
  Log Message:
  remove caris driver (it will be posted to PDAL/Caris)
  Commit: 1ad557f41f7db466bcbab98f4d081dda9e74b546
      https://github.com/PDAL/PDAL/commit/1ad557f41f7db466bcbab98f4d081dda9e74b546
  Changed paths:
    M pdal_defines.h.in
  Log Message:
  remove unused definitions from pdal_defines
  Commit: ede2fe6e57fb100b99810d0e974457b9a6331c44
      https://github.com/PDAL/PDAL/commit/ede2fe6e57fb100b99810d0e974457b9a6331c44
  Changed paths:
    M plugins/pcl/kernel/Ground.cpp
    M plugins/pcl/kernel/PCL.cpp
    M plugins/pcl/kernel/Smooth.cpp
  Log Message:
  update PCL plugin to deal with BufferReader rename
  Commit: 44c57dfaac9f59de79eab1ce13e95b3110783284
      https://github.com/PDAL/PDAL/commit/44c57dfaac9f59de79eab1ce13e95b3110783284
  Changed paths:
    M CMakeLists.txt
    M pdal_defines.h.in
  Log Message:
  Catch up TerraSolid PR to current master
Compare: https://github.com/PDAL/PDAL/compare/5f733d55f812...44c57dfaac9f
More information about the pdal-commits mailing list
