[pdal-commits] [PDAL/PDAL] d60dad: fix makeReader in Ground and PCL kernels
GitHub noreply at github.com
Mon Oct 20 13:32:33 PDT 2014
  Branch: refs/heads/las1.4
  Home:   https://github.com/PDAL/PDAL
  Commit: d60dada7130bee6fab9009907bdc4f1afc9fc174
      https://github.com/PDAL/PDAL/commit/d60dada7130bee6fab9009907bdc4f1afc9fc174
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-10-10 (Fri, 10 Oct 2014)
  Changed paths:
    M src/kernel/Ground.cpp
    M src/kernel/PCL.cpp
  Log Message:
  Commit: c1c2ce135ab6c046bb8694fa27934e7b404c3272
      https://github.com/PDAL/PDAL/commit/c1c2ce135ab6c046bb8694fa27934e7b404c3272
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-10-12 (Sun, 12 Oct 2014)
  Changed paths:
  Log Message:
  Merge pull request #522 from chambbj/fix-ground-pcl-kernels
  Commit: f0d97b12becbef840f3df380e013688e6a38e5f7
      https://github.com/PDAL/PDAL/commit/f0d97b12becbef840f3df380e013688e6a38e5f7
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2014-10-16 (Thu, 16 Oct 2014)
  Changed paths:
    M include/pdal/drivers/las/Header.hpp
  Log Message:
  Fix error in assertion.
  Commit: 982db50defad7780736839c7947bc2a83b1297bd
      https://github.com/PDAL/PDAL/commit/982db50defad7780736839c7947bc2a83b1297bd
  Author: Connor Manning <connor at hobu.co>
  Changed paths:
    M cmake/modules/FindJsoncpp.cmake
    M src/drivers/greyhound/Exchanges.hpp
    M src/drivers/greyhound/Reader.cpp
  Log Message:
  Update FindJsoncpp cmake file and Greyhound driver.
  Commit: 33b4a882e0058eaf7a6f051d26f78a5ca7af3441
      https://github.com/PDAL/PDAL/commit/33b4a882e0058eaf7a6f051d26f78a5ca7af3441
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
  Log Message:
  Merge pull request #526 from PDAL/greyhound
  Commit: d8fbcebca06e59b8bb2c9ae8d5af70ff8d9bc505
      https://github.com/PDAL/PDAL/commit/d8fbcebca06e59b8bb2c9ae8d5af70ff8d9bc505
  Author: Michael P. Gerlek <mpg at flaxen.com>
  Changed paths:
    M include/pdal/PointBuffer.hpp
  Log Message:
  constify the PointBuffer::append() functions
  Commit: 7e1934c82bb4c05aee73b9e8cc4f2b021c45311d
      https://github.com/PDAL/PDAL/commit/7e1934c82bb4c05aee73b9e8cc4f2b021c45311d
  Changed paths:
    M include/pdal/Options.hpp
    M include/pdal/drivers/nitf/Writer.hpp
    M src/Options.cpp
    M src/drivers/nitf/Writer.cpp
    M test/data/nitf/write_options.xml
  Log Message:
  Add support for NITF ACFTB and AIMIDB TREs
  Commit: 34b998ce8599d821ed5718eb5bbfe67d4f7779fb
      https://github.com/PDAL/PDAL/commit/34b998ce8599d821ed5718eb5bbfe67d4f7779fb
  Changed paths:
    M src/kernel/Random.cpp
  Log Message:
  random kernel needs to set options on the faux reader now
  Commit: 4c6f60e229ec052eeecd2ceccc520525c6adb631
      https://github.com/PDAL/PDAL/commit/4c6f60e229ec052eeecd2ceccc520525c6adb631
  Date:   2014-10-17 (Fri, 17 Oct 2014)
  Changed paths:
  Log Message:
  Merge branch 'PointBuffer-constness' into yosemite-lint
  Commit: 94cae779dbe9eac5438a0b20cc0a99feb4415265
      https://github.com/PDAL/PDAL/commit/94cae779dbe9eac5438a0b20cc0a99feb4415265
  Changed paths:
    M CMakeLists.txt
  Log Message:
  added "-isystem /usr/local/include"
This should serve to shut up all the warnings from system headers (of
which the yosemite clang causes a zillion new ones in boost)
  Commit: 490d97c594d8f751f28b3ddef18bb9cafb8ae6d5
      https://github.com/PDAL/PDAL/commit/490d97c594d8f751f28b3ddef18bb9cafb8ae6d5
  Changed paths:
    M test/unit/BoundsTest.cpp
    M test/unit/ConfigTest.cpp
    M test/unit/DimensionTest.cpp
    M test/unit/EnvironmentTest.cpp
    M test/unit/FileUtilsTest.cpp
    M test/unit/GDALUtilsTest.cpp
    M test/unit/LogTest.cpp
    M test/unit/MetadataTest.cpp
    M test/unit/OptionsTest.cpp
    M test/unit/PipelineManagerTest.cpp
    M test/unit/PointBufferTest.cpp
    M test/unit/SchemaLayoutTest.cpp
    M test/unit/SchemaTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/StageFactoryTest.cpp
    M test/unit/StreamFactoryTest.cpp
    M test/unit/Support.cpp
    M test/unit/SupportTest.cpp
    M test/unit/TestConfig.cpp
    A test/unit/UnitTest.hpp
    M test/unit/UserCallbackTest.cpp
    M test/unit/UtilsTest.cpp
    M test/unit/XMLSchemaTest.cpp
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/apps/pcinfoTest.cpp
    M test/unit/apps/pcpipelineTest.cpp
    M test/unit/drivers/bpf/BPFTest.cpp
    M test/unit/drivers/buffer/BufferTest.cpp
    M test/unit/drivers/caris/CarisReaderTest.cpp
    M test/unit/drivers/faux/FauxReaderTest.cpp
    M test/unit/drivers/icebridge/IcebridgeReaderTest.cpp
    M test/unit/drivers/las/LasReaderTest.cpp
    M test/unit/drivers/las/LasWriterTest.cpp
    M test/unit/drivers/nitf/NitfReaderTest.cpp
    M test/unit/drivers/nitf/NitfWriterTest.cpp
    M test/unit/drivers/oci/OCITest.cpp
    M test/unit/drivers/pgpointcloud/PgpointcloudWriterTest.cpp
    M test/unit/drivers/qfit/QFITReaderTest.cpp
    M test/unit/drivers/sbet/SbetReaderTest.cpp
    M test/unit/drivers/sbet/SbetWriterTest.cpp
    M test/unit/drivers/sqlite/SQLiteTest.cpp
    M test/unit/drivers/terrasolid/TerraSolidReaderTest.cpp
    M test/unit/drivers/text/TextWriterTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/DecimationFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/HexbinFilterTest.cpp
    M test/unit/filters/InPlaceReprojectionFilterTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/filters/PCLBlockFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M test/unit/filters/ScalingFilterTest.cpp
    M test/unit/filters/SelectorFilterTest.cpp
    M test/unit/filters/SplitterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
    M test/unit/main.cpp
    M test/unit/plang/PLangTest.cpp
    M test/unit/plang/PredicateFilterTest.cpp
    M test/unit/plang/ProgrammableFilterTest.cpp
  Log Message:
  added common header to all unit test files
  Commit: ad474735e990c8cfaa4e7fc3eaa0833068553e9b
      https://github.com/PDAL/PDAL/commit/ad474735e990c8cfaa4e7fc3eaa0833068553e9b
  Date:   2014-10-18 (Sat, 18 Oct 2014)
  Changed paths:
    M src/Options.cpp
  Log Message:
  Merge pull request #524 from PDAL/issues/524-aimidb-afctb-nitf-output
Add AIMIDB and AFCTB records to NITF writer output
  Commit: 893f858b5b65f66a0f7ca08b42b8648be1a40be8
      https://github.com/PDAL/PDAL/commit/893f858b5b65f66a0f7ca08b42b8648be1a40be8
  Changed paths:
    M CMakeLists.txt
    M include/pdal/Drivers.hpp
    M include/pdal/Filters.hpp
    M include/pdal/GDALUtils.hpp
    M include/pdal/PDALUtils.hpp
    M include/pdal/drivers/bpf/BpfReader.hpp
    M include/pdal/filters/Colorization.hpp
    M include/pdal/filters/Reprojection.hpp
    M pdal_defines.h.in
    M scripts/ci/before_install.sh
    M scripts/ci/script.sh
    M src/CMakeLists.txt
    M src/GDALUtils.cpp
    M src/GlobalEnvironment.cpp
    M src/SpatialReference.cpp
    M src/StageFactory.cpp
    M src/Utils.cpp
    M src/XMLSchema.cpp
    M src/drivers/bpf/BpfReader.cpp
    M src/drivers/las/GeotiffSupport.cpp
    M src/drivers/las/Reader.cpp
    M src/drivers/las/VariableLengthRecord.cpp
    M src/drivers/oci/Writer.cpp
    M src/drivers/sqlite/SQLiteWriter.cpp
    M src/filters/Colorization.cpp
    M src/filters/Crop.cpp
    M src/filters/Reprojection.cpp
    M src/pdal_config.cpp
  Log Message:
  Work to regularize PDAL's dependencies and clarify what is really
required vs. what is optional #523
  Commit: 7f96858e1b7fb4baafb98662565bbd4e4526078a
      https://github.com/PDAL/PDAL/commit/7f96858e1b7fb4baafb98662565bbd4e4526078a
  Changed paths:
  Log Message:
  Merge pull request #528 from PDAL/PointBuffer-constness
  Commit: 84d856db51fbee79cde6e1ed1a2a5e47597f44a3
      https://github.com/PDAL/PDAL/commit/84d856db51fbee79cde6e1ed1a2a5e47597f44a3
  Date:   2014-10-19 (Sun, 19 Oct 2014)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #529 from PDAL/yosemite-lint
Yosemite lint
  Commit: 63d389167b2971c6e5c1f1975d2c430f4eb06f08
      https://github.com/PDAL/PDAL/commit/63d389167b2971c6e5c1f1975d2c430f4eb06f08
  Changed paths:
  Log Message:
  Implement IGEOLO support #531
  Commit: 55666feda0a6b9b5b64a59bc4c0b2b966e9be387
      https://github.com/PDAL/PDAL/commit/55666feda0a6b9b5b64a59bc4c0b2b966e9be387
  Date:   2014-10-20 (Mon, 20 Oct 2014)
  Changed paths:
    M include/pdal/Writer.hpp
    M include/pdal/drivers/las/VariableLengthRecord.hpp
    M include/pdal/drivers/las/Writer.hpp
    M src/drivers/las/Header.cpp
    M src/drivers/las/Writer.cpp
    M test/unit/CMakeLists.txt
    M test/unit/StageTester.hpp
  Log Message:
  LAS auto-offset computation.
Fix record signature for 1.0 LAS VLRs.
  Commit: 7da8d04ffa37e45cfa069122304263ad50ea29d6
      https://github.com/PDAL/PDAL/commit/7da8d04ffa37e45cfa069122304263ad50ea29d6
  Changed paths:
    M CMakeLists.txt
    M pdal_defines.h.in
    M src/GDALUtils.cpp
    M src/Options.cpp
    M src/Utils.cpp
    M src/XMLSchema.cpp
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL into las1.4
Fix NULL spatial reference for NITF clipping.
Change PDAL_HAVE_SRS to PDAL_HAVE_LIBGEOTIFF
Conflicts:
Compare: https://github.com/PDAL/PDAL/compare/f415da5fc9e2...7da8d04ffa37
More information about the pdal-commits mailing list
