[pdal-commits] [PDAL/PDAL] 925f48: Isolate plugins and their dependencies, starting w...
    GitHub
    noreply at github.com
    Wed Oct 22 19:41:31 PDT 2014
  Branch: refs/heads/pcl-submodule
  Home:   https://github.com/PDAL/PDAL
  Commit: 925f485f484b5615626b9409e7b815b5f211b970
      https://github.com/PDAL/PDAL/commit/925f485f484b5615626b9409e7b815b5f211b970
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-10-22 (Wed, 22 Oct 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M apps/pdal.cpp
    M cmake/pdal_targets.cmake
    M include/pdal/Drivers.hpp
    M include/pdal/Filters.hpp
    R include/pdal/Kernel.hpp
    R include/pdal/PCLConversions.hpp
    M include/pdal/StageFactory.hpp
    R include/pdal/drivers/pcd/Common.hpp
    R include/pdal/drivers/pcd/Reader.hpp
    R include/pdal/drivers/pcd/Writer.hpp
    R include/pdal/drivers/pcd/point_types.hpp
    R include/pdal/drivers/pclvisualizer/PCLVisualizer.hpp
    M include/pdal/filters/Decimation.hpp
    R include/pdal/filters/PCLBlock.hpp
    R include/pdal/kernel/Application.hpp
    M include/pdal/kernel/Delta.hpp
    M include/pdal/kernel/Diff.hpp
    R include/pdal/kernel/Ground.hpp
    M include/pdal/kernel/Info.hpp
    M include/pdal/kernel/Kernel.hpp
    A include/pdal/kernel/KernelFactory.hpp
    A include/pdal/kernel/KernelInfo.hpp
    A include/pdal/kernel/Kernels.hpp
    R include/pdal/kernel/PCL.hpp
    M include/pdal/kernel/Pipeline.hpp
    M include/pdal/kernel/Random.hpp
    M include/pdal/kernel/Translate.hpp
    R include/pdal/kernel/View.hpp
    M include/pdal/pdal_macros.hpp
    R include/stubs/pcl/console/print.h
    R include/stubs/pcl/filters/voxel_grid.h
    R include/stubs/pcl/for_each_type.h
    R include/stubs/pcl/io/impl/pcd_io.hpp
    R include/stubs/pcl/io/pcd_io.h
    R include/stubs/pcl/pcl_config.h
    R include/stubs/pcl/pipeline/pipeline.h
    R include/stubs/pcl/point_traits.h
    R include/stubs/pcl/point_types.h
    R include/stubs/pcl/visualization/pcl_visualizer.h
    R include/stubs/pcl/visualization/point_cloud_color_handlers.h
    M pdal_defines.h.in
    A plugins/CMakeLists.txt
    A plugins/pcl/CMakeLists.txt
    A plugins/pcl/PCLConversions.hpp
    A plugins/pcl/drivers/PCLVisualizer.cpp
    A plugins/pcl/drivers/PCLVisualizer.hpp
    A plugins/pcl/drivers/PcdCommon.cpp
    A plugins/pcl/drivers/PcdCommon.hpp
    A plugins/pcl/drivers/PcdReader.cpp
    A plugins/pcl/drivers/PcdReader.hpp
    A plugins/pcl/drivers/PcdWriter.cpp
    A plugins/pcl/drivers/PcdWriter.hpp
    A plugins/pcl/drivers/point_types.hpp
    A plugins/pcl/filters/PCLBlock.cpp
    A plugins/pcl/filters/PCLBlock.hpp
    A plugins/pcl/kernel/Ground.cpp
    A plugins/pcl/kernel/Ground.hpp
    A plugins/pcl/kernel/PCL.cpp
    A plugins/pcl/kernel/PCL.hpp
    A plugins/pcl/kernel/Smooth.cpp
    A plugins/pcl/kernel/Smooth.hpp
    A plugins/pcl/kernel/View.cpp
    A plugins/pcl/kernel/View.hpp
    A plugins/pcl/pipeline/PCLPipeline.cpp
    A plugins/pcl/pipeline/PCLPipeline.h
    A plugins/pcl/pipeline/PCLPipeline.hpp
    M src/CMakeLists.txt
    M src/FileUtils.cpp
    M src/StageFactory.cpp
    M src/drivers/oci/OciReader.cpp
    M src/drivers/oci/Writer.cpp
    R src/drivers/pcd/Common.cpp
    R src/drivers/pcd/Reader.cpp
    R src/drivers/pcd/Writer.cpp
    R src/drivers/pclvisualizer/PCLVisualizer.cpp
    M src/drivers/pgpointcloud/PgReader.cpp
    M src/drivers/pgpointcloud/Reader.cpp
    M src/drivers/pgpointcloud/Writer.cpp
    M src/drivers/sqlite/SQLiteReader.cpp
    M src/drivers/sqlite/SQLiteWriter.cpp
    M src/drivers/text/Writer.cpp
    M src/filters/Decimation.cpp
    R src/filters/PCLBlock.cpp
    R src/kernel/Application.cpp
    M src/kernel/Delta.cpp
    M src/kernel/Diff.cpp
    R src/kernel/Ground.cpp
    M src/kernel/Info.cpp
    A src/kernel/Kernel.cpp
    A src/kernel/KernelFactory.cpp
    A src/kernel/KernelInfo.cpp
    R src/kernel/PCL.cpp
    M src/kernel/Pipeline.cpp
    M src/kernel/Random.cpp
    M src/kernel/Translate.cpp
    R src/kernel/View.cpp
    R src/pclsupport/PCLPipeline.cpp
    R src/pclsupport/PCLPipeline.h
    R src/pclsupport/PCLPipeline.hpp
    M src/pdal_config.cpp
    M test/unit/CMakeLists.txt
    M test/unit/Support.cpp
    M test/unit/filters/PCLBlockFilterTest.cpp
  Log Message:
  Isolate plugins and their dependencies, starting with PCL. Create Kernel
class for kernel plugins.
    * A plugins folder has been created for PCL (and other) plugins. All
      plugins are now built via the existing plugin framework (i.e., as
      shared libs that are registered at runtime). Plugins will link
      against PDAL, but PDAL can be built independently of any plugin
      dependencies.
    * References to PDAL_HAVE_PCL have generally been removed, as
      PCL-dependent code should only be encountered within the PCL
      plugin directory, and only after PCL has been detected. Within
      PDAL, prior checks for PDAL_HAVE_PCL have been replaced by queries
      of getFilterCreator (also Reader, Writer, Kernel), which has been
      made public in StageFactory. These sections of code are only
      encountered when plugins have been determined to be present at
      runtime.
Remaining todos (these can be addressed post-merge)...
    * Visualization option only displays output buffer for now.
      Displaying the input and output buffers would force a PCL
      requirement on PDAL. Still need to think through how to pass
      multiple buffers to the existing PCLVisualizer driver (writers
      typically only have one buffer).
    * PCL unit tests pass with a warning if PCL plugins are not
      installed - though we should still move PCL tests to the plugin
      folder.
Other miscellaneous, but noteworthy changes include...
    * In FileUtils and StageFactory, assume that if the filename starts
      with http, we are passing a Greyhound url. This is independent of
      the plugins changes, but allows us to import data from Greyhound.
    * Remove stubs.
    * Remove Application class, it is now part of Kernel.
    * VoxelGrid removed from decimation filter, now called via PCLBlock
      (if available) in Translate kernel.
    * Unit tests binpath updated for APP_BUNDLE builds.
    * Add MovingLeastSquares to PCL pipeline and Smooth kernel.
    * Disable NormalEstimation and ConditionalRemoval in PCL pipeline
      (allows us to stick with POINT_XYZ types).
    * Remove PCL from getVersionString.
    * Remove references to USE_PDAL_PLUGIN_PCD.
  Commit: fafb4363b62904940432cef80c1b06ee1a780505
      https://github.com/PDAL/PDAL/commit/fafb4363b62904940432cef80c1b06ee1a780505
  Changed paths:
    M plugins/pcl/kernel/Smooth.cpp
    M plugins/pcl/kernel/Smooth.hpp
  Log Message:
  addressing abell's comments
  Commit: e267b63ac01c01c8e843bd71255f48291a5b1822
      https://github.com/PDAL/PDAL/commit/e267b63ac01c01c8e843bd71255f48291a5b1822
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M plugins/pcl/drivers/PcdCommon.cpp
  Log Message:
  include tweak #532
  Commit: d773362097d6b92441c22ba520f6f08e51e6dd84
      https://github.com/PDAL/PDAL/commit/d773362097d6b92441c22ba520f6f08e51e6dd84
  Changed paths:
    M plugins/pcl/kernel/Ground.cpp
    M plugins/pcl/kernel/PCL.cpp
    M src/kernel/Kernel.cpp
  Log Message:
  port over visualization fix from master
  Commit: c1ab17de37dca1af798a5ec1060deee0bdca9962
      https://github.com/PDAL/PDAL/commit/c1ab17de37dca1af798a5ec1060deee0bdca9962
  Changed paths:
    M include/pdal/kernel/Kernels.hpp
  Log Message:
  Query is OBE
  Commit: 8dc1841bd4fc7d55d952294f7e4aa97c1049cf14
      https://github.com/PDAL/PDAL/commit/8dc1841bd4fc7d55d952294f7e4aa97c1049cf14
  Changed paths:
    M apps/pdal.cpp
    M include/pdal/kernel/Sort.hpp
    M src/kernel/Sort.cpp
  Log Message:
  update Sort from Application to Kernel
  Commit: db57d1ab6e124b0c8cc64f7b6c847999eefc29fb
      https://github.com/PDAL/PDAL/commit/db57d1ab6e124b0c8cc64f7b6c847999eefc29fb
  Changed paths:
  Log Message:
  do the macro thing
  Commit: bf225a1b7f6c1bb5c6d343271c498e952f6324ab
      https://github.com/PDAL/PDAL/commit/bf225a1b7f6c1bb5c6d343271c498e952f6324ab
  Changed paths:
    M apps/pdal.cpp
    M include/pdal/kernel/KernelFactory.hpp
    M src/kernel/KernelFactory.cpp
  Log Message:
  use unique_ptr with createKernel
Compare: https://github.com/PDAL/PDAL/compare/91140b28d07b...bf225a1b7f6c
More information about the pdal-commits
