[pdal-commits] [PDAL/PDAL] 8bb9d5: Isolate plugins and their dependencies, starting w...
GitHub noreply at github.com
Mon Oct 27 07:18:29 PDT 2014
  Branch: refs/heads/pcl-submodule
  Home:   https://github.com/PDAL/PDAL
  Commit: 8bb9d5a022b2e1b3f4da6f5d24f34c5a7cfa94c5
      https://github.com/PDAL/PDAL/commit/8bb9d5a022b2e1b3f4da6f5d24f34c5a7cfa94c5
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-10-27 (Mon, 27 Oct 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M apps/pdal.cpp
    M cmake/pdal_targets.cmake
    M include/pdal/Drivers.hpp
    M include/pdal/Filters.hpp
    R include/pdal/Kernel.hpp
    R include/pdal/PCLConversions.hpp
    M include/pdal/StageFactory.hpp
    R include/pdal/drivers/pcd/Common.hpp
    R include/pdal/drivers/pcd/Reader.hpp
    R include/pdal/drivers/pcd/Writer.hpp
    R include/pdal/drivers/pcd/point_types.hpp
    R include/pdal/drivers/pclvisualizer/PCLVisualizer.hpp
    M include/pdal/filters/Decimation.hpp
    R include/pdal/filters/PCLBlock.hpp
    M include/pdal/kernel/Delta.hpp
    M include/pdal/kernel/Diff.hpp
    R include/pdal/kernel/Ground.hpp
    M include/pdal/kernel/Info.hpp
    M include/pdal/kernel/Kernel.hpp
    A include/pdal/kernel/KernelFactory.hpp
    A include/pdal/kernel/KernelInfo.hpp
    A include/pdal/kernel/Kernels.hpp
    R include/pdal/kernel/PCL.hpp
    M include/pdal/kernel/Pipeline.hpp
    M include/pdal/kernel/Random.hpp
    M include/pdal/kernel/Translate.hpp
    R include/pdal/kernel/View.hpp
    M include/pdal/pdal_macros.hpp
    R include/stubs/pcl/console/print.h
    R include/stubs/pcl/filters/voxel_grid.h
    R include/stubs/pcl/for_each_type.h
    R include/stubs/pcl/io/impl/pcd_io.hpp
    R include/stubs/pcl/io/pcd_io.h
    R include/stubs/pcl/pcl_config.h
    R include/stubs/pcl/pipeline/pipeline.h
    R include/stubs/pcl/point_traits.h
    R include/stubs/pcl/point_types.h
    R include/stubs/pcl/visualization/pcl_visualizer.h
    R include/stubs/pcl/visualization/point_cloud_color_handlers.h
    M pdal_defines.h.in
    A plugins/CMakeLists.txt
    A plugins/pcl/CMakeLists.txt
    A plugins/pcl/PCLConversions.hpp
    A plugins/pcl/drivers/PCLVisualizer.cpp
    A plugins/pcl/drivers/PCLVisualizer.hpp
    A plugins/pcl/drivers/PcdCommon.cpp
    A plugins/pcl/drivers/PcdCommon.hpp
    A plugins/pcl/drivers/PcdReader.cpp
    A plugins/pcl/drivers/PcdReader.hpp
    A plugins/pcl/drivers/PcdWriter.cpp
    A plugins/pcl/drivers/PcdWriter.hpp
    A plugins/pcl/drivers/point_types.hpp
    A plugins/pcl/filters/PCLBlock.cpp
    A plugins/pcl/filters/PCLBlock.hpp
    A plugins/pcl/kernel/Ground.cpp
    A plugins/pcl/kernel/Ground.hpp
    A plugins/pcl/kernel/PCL.cpp
    A plugins/pcl/kernel/PCL.hpp
    A plugins/pcl/kernel/Smooth.cpp
    A plugins/pcl/kernel/Smooth.hpp
    A plugins/pcl/kernel/View.cpp
    A plugins/pcl/kernel/View.hpp
    A plugins/pcl/pipeline/PCLPipeline.cpp
    A plugins/pcl/pipeline/PCLPipeline.h
    A plugins/pcl/pipeline/PCLPipeline.hpp
    M src/CMakeLists.txt
    M src/FileUtils.cpp
    M src/StageFactory.cpp
    M src/drivers/oci/OciReader.cpp
    M src/drivers/oci/Writer.cpp
    R src/drivers/pcd/Common.cpp
    R src/drivers/pcd/Reader.cpp
    R src/drivers/pcd/Writer.cpp
    R src/drivers/pclvisualizer/PCLVisualizer.cpp
    M src/drivers/pgpointcloud/PgReader.cpp
    M src/drivers/pgpointcloud/Reader.cpp
    M src/drivers/pgpointcloud/Writer.cpp
    M src/drivers/sqlite/SQLiteReader.cpp
    M src/drivers/sqlite/SQLiteWriter.cpp
    M src/drivers/text/Writer.cpp
    M src/filters/Decimation.cpp
    R src/filters/PCLBlock.cpp
    R src/kernel/Application.cpp
    M src/kernel/Delta.cpp
    M src/kernel/Diff.cpp
    R src/kernel/Ground.cpp
    M src/kernel/Info.cpp
    A src/kernel/Kernel.cpp
    A src/kernel/KernelFactory.cpp
    A src/kernel/KernelInfo.cpp
    R src/kernel/PCL.cpp
    M src/kernel/Pipeline.cpp
    M src/kernel/Random.cpp
    M src/kernel/Translate.cpp
    R src/kernel/View.cpp
    R src/pclsupport/PCLPipeline.cpp
    R src/pclsupport/PCLPipeline.h
    R src/pclsupport/PCLPipeline.hpp
    M src/pdal_config.cpp
    M test/unit/CMakeLists.txt
    M test/unit/Support.cpp
    M test/unit/filters/PCLBlockFilterTest.cpp
  Log Message:
  Isolate plugins and their dependencies, starting with PCL. Create Kernel
class for kernel plugins.
    * A plugins folder has been created for PCL (and other) plugins. All
      plugins are now built via the existing plugin framework (i.e., as
      shared libs that are registered at runtime). Plugins will link
      against PDAL, but PDAL can be built independently of any plugin
      dependencies.
    * References to PDAL_HAVE_PCL have generally been removed, as
      PCL-dependent code should only be encountered within the PCL
      plugin directory, and only after PCL has been detected. Within
      PDAL, prior checks for PDAL_HAVE_PCL have been replaced by queries
      of getFilterCreator (also Reader, Writer, Kernel), which has been
      made public in StageFactory. These sections of code are only
      encountered when plugins have been determined to be present at
      runtime.
Remaining todos (these can be addressed post-merge)...
    * Visualization option only displays output buffer for now.
      Displaying the input and output buffers would force a PCL
      requirement on PDAL. Still need to think through how to pass
      multiple buffers to the existing PCLVisualizer driver (writers
      typically only have one buffer).
    * PCL unit tests pass with a warning if PCL plugins are not
      installed - though we should still move PCL tests to the plugin
      folder.
Other miscellaneous, but noteworthy changes include...
    * In FileUtils and StageFactory, assume that if the filename starts
      with http, we are passing a Greyhound url. This is independent of
      the plugins changes, but allows us to import data from Greyhound.
    * Remove stubs.
    * Remove Application class, it is now part of Kernel.
    * VoxelGrid removed from decimation filter, now called via PCLBlock
      (if available) in Translate kernel.
    * Unit tests binpath updated for APP_BUNDLE builds.
    * Add MovingLeastSquares to PCL pipeline and Smooth kernel.
    * Disable NormalEstimation and ConditionalRemoval in PCL pipeline
      (allows us to stick with POINT_XYZ types).
    * Remove PCL from getVersionString.
    * Remove references to USE_PDAL_PLUGIN_PCD.
  Commit: 9c399eb5870d7664f3aa268bc303fd936cf534a5
      https://github.com/PDAL/PDAL/commit/9c399eb5870d7664f3aa268bc303fd936cf534a5
  Changed paths:
    M plugins/pcl/kernel/Smooth.cpp
    M plugins/pcl/kernel/Smooth.hpp
  Log Message:
  addressing abell's comments
  Commit: 4b5f6eb1b5f59b1108c7e33947352a2ef8660a10
      https://github.com/PDAL/PDAL/commit/4b5f6eb1b5f59b1108c7e33947352a2ef8660a10
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M plugins/pcl/drivers/PcdCommon.cpp
  Log Message:
  include tweak #532
  Commit: e3786969f9f4ed4d0a5b86042c9d838177f73d6d
      https://github.com/PDAL/PDAL/commit/e3786969f9f4ed4d0a5b86042c9d838177f73d6d
  Changed paths:
    M src/kernel/Kernel.cpp
  Log Message:
  port over visualization fix from master
  Commit: 0cf44aeb07aa40f22cecb200ca8c3e265466d66f
      https://github.com/PDAL/PDAL/commit/0cf44aeb07aa40f22cecb200ca8c3e265466d66f
  Changed paths:
    M include/pdal/kernel/Kernels.hpp
  Log Message:
  Query is OBE
  Commit: 2192875f88b10163c1ce3b2c33bae352f41c7060
      https://github.com/PDAL/PDAL/commit/2192875f88b10163c1ce3b2c33bae352f41c7060
  Changed paths:
    M apps/pdal.cpp
    M include/pdal/kernel/Sort.hpp
    M src/kernel/Sort.cpp
  Log Message:
  update Sort from Application to Kernel
  Commit: 3e6209bbfce333910df5ae7f21bf560c7a866a50
      https://github.com/PDAL/PDAL/commit/3e6209bbfce333910df5ae7f21bf560c7a866a50
  Changed paths:
  Log Message:
  do the macro thing
  Commit: 85fe624537fcd6216e6dfe4c6eedc53796c2d430
      https://github.com/PDAL/PDAL/commit/85fe624537fcd6216e6dfe4c6eedc53796c2d430
  Changed paths:
    M apps/pdal.cpp
    M include/pdal/kernel/KernelFactory.hpp
    M src/kernel/KernelFactory.cpp
  Log Message:
  use unique_ptr with createKernel
Compare: https://github.com/PDAL/PDAL/compare/bf225a1b7f6c...85fe624537fc
More information about the pdal-commits mailing list
