[pdal-commits] [PDAL/PDAL] 51c656: remove embedded boost #427
GitHub noreply at github.com
Thu Sep 4 07:22:47 PDT 2014
  Branch: refs/heads/issues/427-no-boost-embed
  Home:   https://github.com/PDAL/PDAL
  Commit: 51c6563e8af4cdb9f549fae7192b31772095ca3f
      https://github.com/PDAL/PDAL/commit/51c6563e8af4cdb9f549fae7192b31772095ca3f
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-09-04 (Thu, 04 Sep 2014)
  Changed paths:
    M CMakeLists.txt
    R boost/CMakeLists.txt
    R boost/INSTALL
    R boost/Jamroot
    R boost/LICENSE_1_0.txt
    R boost/boost-build.jam
    R boost/boost.css
    R boost/boost.png
    R boost/boost.png
    R boost/boost/accumulators/accumulators.hpp
    R boost/boost/accumulators/accumulators_fwd.hpp
    R boost/boost/accumulators/framework/accumulator_base.hpp
    R boost/boost/accumulators/framework/accumulator_concept.hpp
    R boost/boost/accumulators/framework/accumulator_set.hpp
    R boost/boost/accumulators/framework/accumulators/droppable_accumulator.hpp
    R boost/boost/accumulators/framework/accumulators/external_accumulator.hpp
    R boost/boost/accumulators/framework/accumulators/reference_accumulator.hpp
    R boost/boost/accumulators/framework/accumulators/value_accumulator.hpp
    R boost/boost/accumulators/framework/depends_on.hpp
    R boost/boost/accumulators/framework/external.hpp
    R boost/boost/accumulators/framework/extractor.hpp
    R boost/boost/accumulators/framework/features.hpp
    R boost/boost/accumulators/framework/parameters/accumulator.hpp
    R boost/boost/accumulators/framework/parameters/sample.hpp
    R boost/boost/accumulators/framework/parameters/weight.hpp
    R boost/boost/accumulators/framework/parameters/weights.hpp
    R boost/boost/accumulators/numeric/detail/function1.hpp
    R boost/boost/accumulators/numeric/detail/function2.hpp
    R boost/boost/accumulators/numeric/detail/function_n.hpp
    R boost/boost/accumulators/numeric/detail/pod_singleton.hpp
    R boost/boost/accumulators/numeric/functional.hpp
    R boost/boost/accumulators/numeric/functional/complex.hpp
    R boost/boost/accumulators/numeric/functional/valarray.hpp
    R boost/boost/accumulators/numeric/functional/vector.hpp
    R boost/boost/accumulators/numeric/functional_fwd.hpp
    R boost/boost/accumulators/statistics/count.hpp
    R boost/boost/accumulators/statistics/density.hpp
    R boost/boost/accumulators/statistics/max.hpp
    R boost/boost/accumulators/statistics/mean.hpp
    R boost/boost/accumulators/statistics/min.hpp
    R boost/boost/accumulators/statistics/moment.hpp
    R boost/boost/accumulators/statistics/stats.hpp
    R boost/boost/accumulators/statistics/sum.hpp
    R boost/boost/accumulators/statistics_fwd.hpp
    R boost/boost/algorithm/string.hpp
    R boost/boost/algorithm/string/case_conv.hpp
    R boost/boost/algorithm/string/classification.hpp
    R boost/boost/algorithm/string/compare.hpp
    R boost/boost/algorithm/string/concept.hpp
    R boost/boost/algorithm/string/config.hpp
    R boost/boost/algorithm/string/constants.hpp
    R boost/boost/algorithm/string/detail/case_conv.hpp
    R boost/boost/algorithm/string/detail/classification.hpp
    R boost/boost/algorithm/string/detail/find_format.hpp
    R boost/boost/algorithm/string/detail/find_format_all.hpp
    R boost/boost/algorithm/string/detail/find_format_store.hpp
    R boost/boost/algorithm/string/detail/find_iterator.hpp
    R boost/boost/algorithm/string/detail/finder.hpp
    R boost/boost/algorithm/string/detail/formatter.hpp
    R boost/boost/algorithm/string/detail/predicate.hpp
    R boost/boost/algorithm/string/detail/replace_storage.hpp
    R boost/boost/algorithm/string/detail/sequence.hpp
    R boost/boost/algorithm/string/detail/trim.hpp
    R boost/boost/algorithm/string/detail/util.hpp
    R boost/boost/algorithm/string/erase.hpp
    R boost/boost/algorithm/string/find.hpp
    R boost/boost/algorithm/string/find_format.hpp
    R boost/boost/algorithm/string/find_iterator.hpp
    R boost/boost/algorithm/string/finder.hpp
    R boost/boost/algorithm/string/formatter.hpp
    R boost/boost/algorithm/string/iter_find.hpp
    R boost/boost/algorithm/string/join.hpp
    R boost/boost/algorithm/string/predicate.hpp
    R boost/boost/algorithm/string/predicate_facade.hpp
    R boost/boost/algorithm/string/replace.hpp
    R boost/boost/algorithm/string/sequence_traits.hpp
    R boost/boost/algorithm/string/split.hpp
    R boost/boost/algorithm/string/std/list_traits.hpp
    R boost/boost/algorithm/string/std/slist_traits.hpp
    R boost/boost/algorithm/string/std/string_traits.hpp
    R boost/boost/algorithm/string/std_containers_traits.hpp
    R boost/boost/algorithm/string/trim.hpp
    R boost/boost/algorithm/string/yes_no_type.hpp
    R boost/boost/aligned_storage.hpp
    R boost/boost/any.hpp
    R boost/boost/archive/add_facet.hpp
    R boost/boost/archive/archive_exception.hpp
    R boost/boost/archive/basic_archive.hpp
    R boost/boost/archive/basic_binary_iarchive.hpp
    R boost/boost/archive/basic_binary_iprimitive.hpp
    R boost/boost/archive/basic_binary_oarchive.hpp
    R boost/boost/archive/basic_binary_oprimitive.hpp
    R boost/boost/archive/basic_streambuf_locale_saver.hpp
    R boost/boost/archive/basic_text_iarchive.hpp
    R boost/boost/archive/basic_text_iprimitive.hpp
    R boost/boost/archive/basic_text_oarchive.hpp
    R boost/boost/archive/basic_text_oprimitive.hpp
    R boost/boost/archive/basic_xml_archive.hpp
    R boost/boost/archive/basic_xml_iarchive.hpp
    R boost/boost/archive/basic_xml_oarchive.hpp
    R boost/boost/archive/binary_iarchive.hpp
    R boost/boost/archive/binary_iarchive_impl.hpp
    R boost/boost/archive/binary_oarchive.hpp
    R boost/boost/archive/binary_oarchive_impl.hpp
    R boost/boost/archive/binary_wiarchive.hpp
    R boost/boost/archive/binary_woarchive.hpp
    R boost/boost/archive/codecvt_null.hpp
    R boost/boost/archive/detail/abi_prefix.hpp
    R boost/boost/archive/detail/abi_suffix.hpp
    R boost/boost/archive/detail/archive_serializer_map.hpp
    R boost/boost/archive/detail/auto_link_archive.hpp
    R boost/boost/archive/detail/auto_link_warchive.hpp
    R boost/boost/archive/detail/basic_iarchive.hpp
    R boost/boost/archive/detail/basic_iserializer.hpp
    R boost/boost/archive/detail/basic_oarchive.hpp
    R boost/boost/archive/detail/basic_oserializer.hpp
    R boost/boost/archive/detail/basic_pointer_iserializer.hpp
    R boost/boost/archive/detail/basic_pointer_oserializer.hpp
    R boost/boost/archive/detail/basic_serializer.hpp
    R boost/boost/archive/detail/basic_serializer_map.hpp
    R boost/boost/archive/detail/check.hpp
    R boost/boost/archive/detail/common_iarchive.hpp
    R boost/boost/archive/detail/common_oarchive.hpp
    R boost/boost/archive/detail/decl.hpp
    R boost/boost/archive/detail/interface_iarchive.hpp
    R boost/boost/archive/detail/interface_oarchive.hpp
    R boost/boost/archive/detail/iserializer.hpp
    R boost/boost/archive/detail/oserializer.hpp
    R boost/boost/archive/detail/register_archive.hpp
    R boost/boost/archive/detail/utf8_codecvt_facet.hpp
    R boost/boost/archive/dinkumware.hpp
    R boost/boost/archive/impl/archive_serializer_map.ipp
    R boost/boost/archive/impl/basic_binary_iarchive.ipp
    R boost/boost/archive/impl/basic_binary_iprimitive.ipp
    R boost/boost/archive/impl/basic_binary_oarchive.ipp
    R boost/boost/archive/impl/basic_binary_oprimitive.ipp
    R boost/boost/archive/impl/basic_text_iarchive.ipp
    R boost/boost/archive/impl/basic_text_iprimitive.ipp
    R boost/boost/archive/impl/basic_text_oarchive.ipp
    R boost/boost/archive/impl/basic_text_oprimitive.ipp
    R boost/boost/archive/impl/basic_xml_grammar.hpp
    R boost/boost/archive/impl/basic_xml_iarchive.ipp
    R boost/boost/archive/impl/basic_xml_oarchive.ipp
    R boost/boost/archive/impl/text_iarchive_impl.ipp
    R boost/boost/archive/impl/text_oarchive_impl.ipp
    R boost/boost/archive/impl/text_wiarchive_impl.ipp
    R boost/boost/archive/impl/text_woarchive_impl.ipp
    R boost/boost/archive/impl/xml_iarchive_impl.ipp
    R boost/boost/archive/impl/xml_oarchive_impl.ipp
    R boost/boost/archive/impl/xml_wiarchive_impl.ipp
    R boost/boost/archive/impl/xml_woarchive_impl.ipp
    R boost/boost/archive/iterators/base64_from_binary.hpp
    R boost/boost/archive/iterators/binary_from_base64.hpp
    R boost/boost/archive/iterators/dataflow_exception.hpp
    R boost/boost/archive/iterators/escape.hpp
    R boost/boost/archive/iterators/insert_linebreaks.hpp
    R boost/boost/archive/iterators/istream_iterator.hpp
    R boost/boost/archive/iterators/mb_from_wchar.hpp
    R boost/boost/archive/iterators/ostream_iterator.hpp
    R boost/boost/archive/iterators/remove_whitespace.hpp
    R boost/boost/archive/iterators/transform_width.hpp
    R boost/boost/archive/iterators/unescape.hpp
    R boost/boost/archive/iterators/wchar_from_mb.hpp
    R boost/boost/archive/iterators/xml_escape.hpp
    R boost/boost/archive/iterators/xml_unescape.hpp
    R boost/boost/archive/polymorphic_iarchive.hpp
    R boost/boost/archive/polymorphic_oarchive.hpp
    R boost/boost/archive/shared_ptr_helper.hpp
    R boost/boost/archive/text_iarchive.hpp
    R boost/boost/archive/text_oarchive.hpp
    R boost/boost/archive/text_wiarchive.hpp
    R boost/boost/archive/text_woarchive.hpp
    R boost/boost/archive/wcslen.hpp
    R boost/boost/archive/xml_archive_exception.hpp
    R boost/boost/archive/xml_iarchive.hpp
    R boost/boost/archive/xml_oarchive.hpp
    R boost/boost/archive/xml_wiarchive.hpp
    R boost/boost/archive/xml_woarchive.hpp
    R boost/boost/array.hpp
    R boost/boost/asio.hpp
    R boost/boost/asio/async_result.hpp
    R boost/boost/asio/basic_datagram_socket.hpp
    R boost/boost/asio/basic_deadline_timer.hpp
    R boost/boost/asio/basic_io_object.hpp
    R boost/boost/asio/basic_raw_socket.hpp
    R boost/boost/asio/basic_seq_packet_socket.hpp
    R boost/boost/asio/basic_serial_port.hpp
    R boost/boost/asio/basic_signal_set.hpp
    R boost/boost/asio/basic_socket.hpp
    R boost/boost/asio/basic_socket_acceptor.hpp
    R boost/boost/asio/basic_socket_iostream.hpp
    R boost/boost/asio/basic_socket_streambuf.hpp
    R boost/boost/asio/basic_stream_socket.hpp
    R boost/boost/asio/basic_streambuf.hpp
    R boost/boost/asio/basic_streambuf_fwd.hpp
    R boost/boost/asio/basic_waitable_timer.hpp
    R boost/boost/asio/buffer.hpp
    R boost/boost/asio/buffered_read_stream.hpp
    R boost/boost/asio/buffered_read_stream_fwd.hpp
    R boost/boost/asio/buffered_stream.hpp
    R boost/boost/asio/buffered_stream_fwd.hpp
    R boost/boost/asio/buffered_write_stream.hpp
    R boost/boost/asio/buffered_write_stream_fwd.hpp
    R boost/boost/asio/buffers_iterator.hpp
    R boost/boost/asio/completion_condition.hpp
    R boost/boost/asio/connect.hpp
    R boost/boost/asio/coroutine.hpp
    R boost/boost/asio/datagram_socket_service.hpp
    R boost/boost/asio/deadline_timer.hpp
    R boost/boost/asio/deadline_timer_service.hpp
    R boost/boost/asio/detail/addressof.hpp
    R boost/boost/asio/detail/array.hpp
    R boost/boost/asio/detail/array_fwd.hpp
    R boost/boost/asio/detail/assert.hpp
    R boost/boost/asio/detail/atomic_count.hpp
    R boost/boost/asio/detail/base_from_completion_cond.hpp
    R boost/boost/asio/detail/bind_handler.hpp
    R boost/boost/asio/detail/buffer_resize_guard.hpp
    R boost/boost/asio/detail/buffer_sequence_adapter.hpp
    R boost/boost/asio/detail/buffered_stream_storage.hpp
    R boost/boost/asio/detail/call_stack.hpp
    R boost/boost/asio/detail/chrono_time_traits.hpp
    R boost/boost/asio/detail/completion_handler.hpp
    R boost/boost/asio/detail/config.hpp
    R boost/boost/asio/detail/consuming_buffers.hpp
    R boost/boost/asio/detail/cstdint.hpp
    R boost/boost/asio/detail/date_time_fwd.hpp
    R boost/boost/asio/detail/deadline_timer_service.hpp
    R boost/boost/asio/detail/dependent_type.hpp
    R boost/boost/asio/detail/descriptor_ops.hpp
    R boost/boost/asio/detail/descriptor_read_op.hpp
    R boost/boost/asio/detail/descriptor_write_op.hpp
    R boost/boost/asio/detail/dev_poll_reactor.hpp
    R boost/boost/asio/detail/epoll_reactor.hpp
    R boost/boost/asio/detail/event.hpp
    R boost/boost/asio/detail/eventfd_select_interrupter.hpp
    R boost/boost/asio/detail/fd_set_adapter.hpp
    R boost/boost/asio/detail/fenced_block.hpp
    R boost/boost/asio/detail/function.hpp
    R boost/boost/asio/detail/gcc_arm_fenced_block.hpp
    R boost/boost/asio/detail/gcc_hppa_fenced_block.hpp
    R boost/boost/asio/detail/gcc_sync_fenced_block.hpp
    R boost/boost/asio/detail/gcc_x86_fenced_block.hpp
    R boost/boost/asio/detail/handler_alloc_helpers.hpp
    R boost/boost/asio/detail/handler_cont_helpers.hpp
    R boost/boost/asio/detail/handler_invoke_helpers.hpp
    R boost/boost/asio/detail/handler_tracking.hpp
    R boost/boost/asio/detail/handler_type_requirements.hpp
    R boost/boost/asio/detail/hash_map.hpp
    R boost/boost/asio/detail/impl/buffer_sequence_adapter.ipp
    R boost/boost/asio/detail/impl/descriptor_ops.ipp
    R boost/boost/asio/detail/impl/dev_poll_reactor.hpp
    R boost/boost/asio/detail/impl/dev_poll_reactor.ipp
    R boost/boost/asio/detail/impl/epoll_reactor.hpp
    R boost/boost/asio/detail/impl/epoll_reactor.ipp
    R boost/boost/asio/detail/impl/eventfd_select_interrupter.ipp
    R boost/boost/asio/detail/impl/handler_tracking.ipp
    R boost/boost/asio/detail/impl/kqueue_reactor.hpp
    R boost/boost/asio/detail/impl/kqueue_reactor.ipp
    R boost/boost/asio/detail/impl/pipe_select_interrupter.ipp
    R boost/boost/asio/detail/impl/posix_event.ipp
    R boost/boost/asio/detail/impl/posix_mutex.ipp
    R boost/boost/asio/detail/impl/posix_thread.ipp
    R boost/boost/asio/detail/impl/posix_tss_ptr.ipp
    R boost/boost/asio/detail/impl/reactive_descriptor_service.ipp
    R boost/boost/asio/detail/impl/reactive_serial_port_service.ipp
    R boost/boost/asio/detail/impl/reactive_socket_service_base.ipp
    R boost/boost/asio/detail/impl/resolver_service_base.ipp
    R boost/boost/asio/detail/impl/select_reactor.hpp
    R boost/boost/asio/detail/impl/select_reactor.ipp
    R boost/boost/asio/detail/impl/service_registry.hpp
    R boost/boost/asio/detail/impl/service_registry.ipp
    R boost/boost/asio/detail/impl/signal_set_service.ipp
    R boost/boost/asio/detail/impl/socket_ops.ipp
    R boost/boost/asio/detail/impl/socket_select_interrupter.ipp
    R boost/boost/asio/detail/impl/strand_service.hpp
    R boost/boost/asio/detail/impl/strand_service.ipp
    R boost/boost/asio/detail/impl/task_io_service.hpp
    R boost/boost/asio/detail/impl/task_io_service.ipp
    R boost/boost/asio/detail/impl/throw_error.ipp
    R boost/boost/asio/detail/impl/timer_queue_ptime.ipp
    R boost/boost/asio/detail/impl/timer_queue_set.ipp
    R boost/boost/asio/detail/impl/win_event.ipp
    R boost/boost/asio/detail/impl/win_iocp_handle_service.ipp
    R boost/boost/asio/detail/impl/win_iocp_io_service.hpp
    R boost/boost/asio/detail/impl/win_iocp_io_service.ipp
    R boost/boost/asio/detail/impl/win_iocp_serial_port_service.ipp
    R boost/boost/asio/detail/impl/win_iocp_socket_service_base.ipp
    R boost/boost/asio/detail/impl/win_mutex.ipp
    R boost/boost/asio/detail/impl/win_object_handle_service.ipp
    R boost/boost/asio/detail/impl/win_static_mutex.ipp
    R boost/boost/asio/detail/impl/win_thread.ipp
    R boost/boost/asio/detail/impl/win_tss_ptr.ipp
    R boost/boost/asio/detail/impl/winrt_ssocket_service_base.ipp
    R boost/boost/asio/detail/impl/winrt_timer_scheduler.hpp
    R boost/boost/asio/detail/impl/winrt_timer_scheduler.ipp
    R boost/boost/asio/detail/impl/winsock_init.ipp
    R boost/boost/asio/detail/io_control.hpp
    R boost/boost/asio/detail/keyword_tss_ptr.hpp
    R boost/boost/asio/detail/kqueue_reactor.hpp
    R boost/boost/asio/detail/limits.hpp
    R boost/boost/asio/detail/local_free_on_block_exit.hpp
  Log Message:
More information about the pdal-commits mailing list
