[pdal-commits] [PDAL/PDAL] ba100b: rename .txt to .rst #430
GitHub noreply at github.com
Thu Sep 4 09:20:38 PDT 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: ba100bd65f10663f02512caa76ba585df37720b1
      https://github.com/PDAL/PDAL/commit/ba100bd65f10663f02512caa76ba585df37720b1
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-09-04 (Thu, 04 Sep 2014)
  Changed paths:
    A doc/api/cpp/bounds.rst
    R doc/api/cpp/bounds.txt
    A doc/api/cpp/dimension.rst
    R doc/api/cpp/dimension.txt
    A doc/api/cpp/index.rst
    R doc/api/cpp/index.txt
    A doc/api/cpp/log.rst
    R doc/api/cpp/log.txt
    A doc/api/cpp/metadata.rst
    R doc/api/cpp/metadata.txt
    A doc/api/cpp/option.rst
    R doc/api/cpp/option.txt
    A doc/api/cpp/options.rst
    R doc/api/cpp/options.txt
    A doc/api/cpp/pointbuffer.rst
    R doc/api/cpp/pointbuffer.txt
    A doc/api/cpp/reader.rst
    R doc/api/cpp/reader.txt
    A doc/api/cpp/schema.rst
    R doc/api/cpp/schema.txt
    A doc/api/cpp/stage.rst
    R doc/api/cpp/stage.txt
    A doc/api/cpp/writer.rst
    R doc/api/cpp/writer.txt
    A doc/api/index.rst
    R doc/api/index.txt
    A doc/apps.rst
    R doc/apps.txt
    A doc/community.rst
    R doc/community.txt
    A doc/compilation/dependencies.rst
    R doc/compilation/dependencies.txt
    A doc/compilation/index.rst
    R doc/compilation/index.txt
    A doc/compilation/unix.rst
    R doc/compilation/unix.txt
    A doc/compilation/windows.rst
    R doc/compilation/windows.txt
    M doc/conf.py
    A doc/copyright.rst
    R doc/copyright.txt
    A doc/development/conventions.rst
    R doc/development/conventions.txt
    A doc/development/docs.rst
    R doc/development/docs.txt
    A doc/development/errorhandling.rst
    R doc/development/errorhandling.txt
    A doc/development/goals.rst
    R doc/development/goals.txt
    A doc/development/index.rst
    R doc/development/index.txt
    A doc/development/testing.rst
    R doc/development/testing.txt
    A doc/development/usecases.rst
    R doc/development/usecases.txt
    A doc/docs.rst
    R doc/docs.txt
    A doc/download.rst
    R doc/download.txt
    A doc/faq.rst
    R doc/faq.txt
    A doc/index.rst
    R doc/index.txt
    A doc/metadata.rst
    R doc/metadata.txt
    A doc/pipeline.rst
    R doc/pipeline.txt
    A doc/stages/drivers.csar.reader.rst
    R doc/stages/drivers.csar.reader.txt
    A doc/stages/drivers.csardb.reader.rst
    R doc/stages/drivers.csardb.reader.txt
    A doc/stages/drivers.faux.reader.rst
    R doc/stages/drivers.faux.reader.txt
    A doc/stages/drivers.faux.writer.rst
    R doc/stages/drivers.faux.writer.txt
    A doc/stages/drivers.las.reader.rst
    R doc/stages/drivers.las.reader.txt
    A doc/stages/drivers.las.writer.rst
    R doc/stages/drivers.las.writer.txt
    A doc/stages/drivers.nitf.reader.rst
    R doc/stages/drivers.nitf.reader.txt
    A doc/stages/drivers.nitf.writer.rst
    R doc/stages/drivers.nitf.writer.txt
    A doc/stages/drivers.oci.reader.rst
    R doc/stages/drivers.oci.reader.txt
    A doc/stages/drivers.oci.writer.rst
    R doc/stages/drivers.oci.writer.txt
    A doc/stages/drivers.p2g.writer.rst
    R doc/stages/drivers.p2g.writer.txt
    A doc/stages/drivers.pgpointcloud.reader.rst
    R doc/stages/drivers.pgpointcloud.reader.txt
    A doc/stages/drivers.pgpointcloud.writer.rst
    R doc/stages/drivers.pgpointcloud.writer.txt
    A doc/stages/drivers.qfit.reader.rst
    R doc/stages/drivers.qfit.reader.txt
    A doc/stages/drivers.sbet.reader.rst
    R doc/stages/drivers.sbet.reader.txt
    A doc/stages/drivers.text.writer.rst
    R doc/stages/drivers.text.writer.txt
    A doc/stages/filters.byteswap.rst
    R doc/stages/filters.byteswap.txt
    A doc/stages/filters.cache.rst
    R doc/stages/filters.cache.txt
    A doc/stages/filters.chipper.rst
    R doc/stages/filters.chipper.txt
    A doc/stages/filters.color.rst
    R doc/stages/filters.color.txt
    A doc/stages/filters.colorization.rst
    R doc/stages/filters.colorization.txt
    A doc/stages/filters.crop.rst
    R doc/stages/filters.crop.txt
    A doc/stages/filters.decimation.rst
    R doc/stages/filters.decimation.txt
    A doc/stages/filters.hexbin.rst
    R doc/stages/filters.hexbin.txt
    A doc/stages/filters.inplacereprojection.rst
    R doc/stages/filters.inplacereprojection.txt
    A doc/stages/filters.pclblock.rst
    R doc/stages/filters.pclblock.txt
    A doc/stages/filters.predicate.rst
    R doc/stages/filters.predicate.txt
    A doc/stages/filters.programmable.rst
    R doc/stages/filters.programmable.txt
    A doc/stages/filters.scaling.rst
    R doc/stages/filters.scaling.txt
    A doc/stages/filters.selector.rst
    R doc/stages/filters.selector.txt
    A doc/stages/index.rst
    R doc/stages/index.txt
    A doc/tutorial/index.rst
    R doc/tutorial/index.txt
    A doc/tutorial/pcl_block_tutorial.rst
    R doc/tutorial/pcl_block_tutorial.txt
    A doc/tutorial/reading.rst
    R doc/tutorial/reading.txt
    A doc/tutorial/writing.rst
    R doc/tutorial/writing.txt
    A doc/vagrant.rst
    R doc/vagrant.txt
  Log Message:
  Commit: cf3eab65fbbd32913fae7fd67020919ecff75822
      https://github.com/PDAL/PDAL/commit/cf3eab65fbbd32913fae7fd67020919ecff75822
  Changed paths:
    A doc/api/index.rst
    R doc/api/index.txt
    A doc/apps.rst
    R doc/apps.txt
    A doc/community.rst
    R doc/community.txt
    M doc/conf.py
    A doc/copyright.rst
    R doc/copyright.txt
    A doc/docs.rst
    R doc/docs.txt
    A doc/download.rst
    R doc/download.txt
    A doc/faq.rst
    R doc/faq.txt
    A doc/index.rst
    R doc/index.txt
    A doc/metadata.rst
    R doc/metadata.txt
    A doc/pipeline.rst
    R doc/pipeline.txt
    A doc/vagrant.rst
    R doc/vagrant.txt
  Log Message:
  Merge pull request #430 from PDAL/issues/430-txt-to-rst-rename
Rename doc .txt to .rst
Compare: https://github.com/PDAL/PDAL/compare/6679d3249c82...cf3eab65fbbd
More information about the pdal-commits mailing list
