[pdal-commits] [PDAL/PDAL] 69c3b5: use the buffer's context for SRS info if none is s...
GitHub noreply at github.com
Fri Sep 5 12:07:43 PDT 2014
  Branch: refs/heads/grid-1.3.3
  Home:   https://github.com/PDAL/PDAL
  Commit: 69c3b577880f3c2e734b9a4d588766b691e34092
      https://github.com/PDAL/PDAL/commit/69c3b577880f3c2e734b9a4d588766b691e34092
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-09-05 (Fri, 05 Sep 2014)
  Changed paths:
    M src/drivers/p2g/P2gWriter.cpp
  Log Message:
  use the buffer's context for SRS info if none is set on the writer
  Commit: 75bd7543093c8b95c54337ede00f1b1fb56d69f1
      https://github.com/PDAL/PDAL/commit/75bd7543093c8b95c54337ede00f1b1fb56d69f1
  Changed paths:
    M include/pdal/drivers/qfit/Reader.hpp
    M src/drivers/qfit/Reader.cpp
    M test/unit/CMakeLists.txt
    M test/unit/drivers/qfit/QFITReaderTest.cpp
  Log Message:
  Merge branch 'grid-1.3.3' of github.com:PDAL/PDAL into grid-1.3.3
Compare: https://github.com/PDAL/PDAL/compare/506ad55fda2e...75bd7543093c
More information about the pdal-commits mailing list
