[pdal-commits] [PDAL/PDAL] a4fdb8: Fix stubs for new PCD driver.
GitHub noreply at github.com
Mon Sep 8 14:01:50 PDT 2014
  Branch: refs/heads/issues/441-clean-up-test-data
  Home:   https://github.com/PDAL/PDAL
  Commit: a4fdb8dab930e40505c3755cf3c89a86fb392db4
      https://github.com/PDAL/PDAL/commit/a4fdb8dab930e40505c3755cf3c89a86fb392db4
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2014-09-08 (Mon, 08 Sep 2014)
  Changed paths:
    A include/stubs/pcl/io/impl/pcd_io.hpp
    M include/stubs/pcl/point_traits.h
    M include/stubs/pcl/point_types.h
    M src/CMakeLists.txt
  Log Message:
  Commit: c158509057e3ed2416d93ede66a9426718f9c0de
      https://github.com/PDAL/PDAL/commit/c158509057e3ed2416d93ede66a9426718f9c0de
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
  Log Message:
  Merge pull request #440 from chambbj/issues/428-stubs-on-rebased
  Commit: 638e22b9f514942b7e8893048497b0c5249d774a
      https://github.com/PDAL/PDAL/commit/638e22b9f514942b7e8893048497b0c5249d774a
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
  Log Message:
  group pcd driver files for msvc
  Commit: 53c674405289aeda957f387ccc4ace2c8b329979
      https://github.com/PDAL/PDAL/commit/53c674405289aeda957f387ccc4ace2c8b329979
  Changed paths:
    A test/data/drivers/text-writer-csv.xml
    A test/data/drivers/text-writer-geojson.xml
    A test/data/drivers/text-writer-space-delimited.xml
    A test/data/filters/merge.xml
    R test/data/pipeline/merge.xml
    R test/data/pipeline/mosaic.xml
    R test/data/pipeline/pipeline_asc.xml
    R test/data/pipeline/pipeline_csv.xml
    R test/data/pipeline/pipeline_geojson.xml
    M test/unit/filters/MergeTest.cpp
  Log Message:
  more reorganization #441
  Commit: e271a2585f92c425f7ce64567b0653e2329ec4b2
      https://github.com/PDAL/PDAL/commit/e271a2585f92c425f7ce64567b0653e2329ec4b2
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin' into issues/441-clean-up-test-data
Compare: https://github.com/PDAL/PDAL/compare/5ec922162be4...e271a2585f92
More information about the pdal-commits mailing list
