[pdal-commits] [PDAL/PDAL] e6fe0b: Remove leftover embedded boost cruft
GitHub noreply at github.com
Sat Sep 13 08:50:43 PDT 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: e6fe0bc43e86f147c5ed272a0bea89547a32db36
      https://github.com/PDAL/PDAL/commit/e6fe0bc43e86f147c5ed272a0bea89547a32db36
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Date:   2014-09-12 (Fri, 12 Sep 2014)
  Changed paths:
    M include/pdal/pdal_config.hpp
    M src/pdal_config.cpp
    M test/unit/CMakeLists.txt
  Log Message:
Removes IsEmbeddedBoost() and calls, as well as embedded boost check in
test/unit/CMakeLists.txt.
  Commit: d86004dea5d3056d3bacee96d73cbebbdfd234dd
      https://github.com/PDAL/PDAL/commit/d86004dea5d3056d3bacee96d73cbebbdfd234dd
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-09-13 (Sat, 13 Sep 2014)
  Changed paths:
  Log Message:
  Merge pull request #453 from gadomski/remove-embedded-boost-cruft
Compare: https://github.com/PDAL/PDAL/compare/629060cbbb9c...d86004dea5d3
More information about the pdal-commits mailing list
