[pdal-commits] [PDAL/PDAL] 51b114: Add the rxp reader
GitHub noreply at github.com
Mon Sep 15 08:44:43 PDT 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 51b11498cdc4f11c765cf723625100d826aa4da6
      https://github.com/PDAL/PDAL/commit/51b11498cdc4f11c765cf723625100d826aa4da6
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Date:   2014-09-15 (Mon, 15 Sep 2014)
  Changed paths:
    M CMakeLists.txt
    A doc/stages/drivers.rxp.reader.rst
    M doc/stages/index.rst
    M include/pdal/Dimension.hpp
    M include/pdal/Drivers.hpp
    A include/pdal/drivers/rxp/RxpReader.hpp
    M pdal_defines.h.in
    M scripts/ci/script.sh
    M src/CMakeLists.txt
    M src/StageFactory.cpp
    A src/drivers/rxp/RxpReader.cpp
    M src/pdal_config.cpp
    A test/data/rxp/130501_232206_cut.rxp
    M test/unit/CMakeLists.txt
    A test/unit/drivers/rxp/RxpReaderTest.cpp
  Log Message:
  Add the rxp reader
RXP is the streaming file format used by RIEGL Laser Measurement Systems
(http://www.riegl.com). Support for reading rxp
files is provided by RiVLib, RIEGL's own library which they release for
use by their customers.
RiVLib only supports reading rxp files, not writing them.
  Commit: feab6d76dc8d1121a7c146348fbe9df88cdec0cb
      https://github.com/PDAL/PDAL/commit/feab6d76dc8d1121a7c146348fbe9df88cdec0cb
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M CMakeLists.txt
    M pdal_defines.h.in
  Log Message:
  Merge pull request #456 from gadomski/rxp-driver
Add the rxp reader
Compare: https://github.com/PDAL/PDAL/compare/06502f635e71...feab6d76dc8d
More information about the pdal-commits mailing list
