[pdal-commits] [PDAL/PDAL] 70c411: Don't add empty fields to JSON output. Make escap...
GitHub noreply at github.com
Thu Sep 25 11:42:39 PDT 2014
  Branch: refs/heads/issues/435-ferry-filter
  Home:   https://github.com/PDAL/PDAL
  Commit: 70c4114b9d4fb5977f22ca5d9d88b4c13086706c
      https://github.com/PDAL/PDAL/commit/70c4114b9d4fb5977f22ca5d9d88b4c13086706c
  Author: Connor Manning <connor at hobu.co>
  Date:   2014-09-23 (Tue, 23 Sep 2014)
  Changed paths:
    M include/pdal/Utils.hpp
    M src/Metadata.cpp
    M src/Utils.cpp
  Log Message:
  Don't add empty fields to JSON output.  Make escapeJSON() not modify the input string.
  Commit: c29971359a33334a62f8a15de9df69392d08db78
      https://github.com/PDAL/PDAL/commit/c29971359a33334a62f8a15de9df69392d08db78
  Date:   2014-09-25 (Thu, 25 Sep 2014)
  Changed paths:
    M src/Metadata.cpp
    M src/Utils.cpp
  Log Message:
  Commit: 849a42e57e3fbc1528a8fc5e32cb28635a348823
      https://github.com/PDAL/PDAL/commit/849a42e57e3fbc1528a8fc5e32cb28635a348823
  Changed paths:
    M src/Metadata.cpp
  Log Message:
  Fix conflict with master.
  Commit: d6b1500151a5edc56574d79c2513aebb72ef7941
      https://github.com/PDAL/PDAL/commit/d6b1500151a5edc56574d79c2513aebb72ef7941
  Changed paths:
    M src/Metadata.cpp
  Log Message:
  Fix botched conflict fix.
  Commit: 05ef8a5155a2c261c22b880e6e0f5986dbe0a58a
      https://github.com/PDAL/PDAL/commit/05ef8a5155a2c261c22b880e6e0f5986dbe0a58a
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
    M test/unit/PointBufferTest.cpp
  Log Message:
  addressing multiple windows issues
  * #490 - use unique_ptr and roll our own swap
  * #491 - use C++11 random uniform distribution on the range of indices
  Commit: 8c5fb87e4d4ee0fbb148b106dec46ddaa89fff5a
      https://github.com/PDAL/PDAL/commit/8c5fb87e4d4ee0fbb148b106dec46ddaa89fff5a
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M src/Metadata.cpp
    M src/Utils.cpp
  Log Message:
  Merge pull request #486 from PDAL/json
  Commit: 19544d77e817a363d101dcde3fe75421ad3ca574
      https://github.com/PDAL/PDAL/commit/19544d77e817a363d101dcde3fe75421ad3ca574
  Changed paths:
  Log Message:
  Merge pull request #493 from chambbj/issues/490-win-constant-expression
  Commit: b221b33f4994da534d51409c1468ba8b0502755e
      https://github.com/PDAL/PDAL/commit/b221b33f4994da534d51409c1468ba8b0502755e
  Changed paths:
    M src/Metadata.cpp
    M src/Utils.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issues/435-ferry-filter
Compare: https://github.com/PDAL/PDAL/compare/6136a47482f6...b221b33f4994
More information about the pdal-commits mailing list
