[pdal-commits] [PDAL/PDAL] 540543: use smoothed_boundary metadata, and flip the optio...
GitHub noreply at github.com
Wed Dec 2 11:16:45 PST 2015
  Branch: refs/heads/docker-config
  Home:   https://github.com/PDAL/PDAL
  Commit: 54054304d0f9d8dda083b1ee62bfd029947aaf3d
      https://github.com/PDAL/PDAL/commit/54054304d0f9d8dda083b1ee62bfd029947aaf3d
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-11-30 (Mon, 30 Nov 2015)
  Changed paths:
    M kernels/tindex/TIndexKernel.cpp
  Log Message:
  use smoothed_boundary metadata, and flip the option so it can be correctly set
  Commit: 59ecfc18c89643f23a58f583ac2d2112a18595aa
      https://github.com/PDAL/PDAL/commit/59ecfc18c89643f23a58f583ac2d2112a18595aa
  Changed paths:
    M include/pdal/Geometry.hpp
  Log Message:
  cull interior rings that are less than 6*tolerance*tolerance for simplified geometry
  Commit: 291b8b09b6c1ee449138b1d41aa32513f65bdd92
      https://github.com/PDAL/PDAL/commit/291b8b09b6c1ee449138b1d41aa32513f65bdd92
  Date:   2015-12-01 (Tue, 01 Dec 2015)
  Changed paths:
  Log Message:
  fetch correct ring count when smoothing polygon
  Commit: edc2d67a97595fad61f0e63eb8e7ca1877c17eb7
      https://github.com/PDAL/PDAL/commit/edc2d67a97595fad61f0e63eb8e7ca1877c17eb7
  Changed paths:
    M plugins/hexbin/filters/HexBin.cpp
  Log Message:
  only output hex'ified boundary when requested -- otherwise default to simplified boundary
  Commit: 4139f120e7b91937f30adb53b8ccbaa9924ccdd3
      https://github.com/PDAL/PDAL/commit/4139f120e7b91937f30adb53b8ccbaa9924ccdd3
  Changed paths:
    M kernels/tindex/TIndexKernel.hpp
  Log Message:
  no need for smooth boundary option on tindex kernel anymore
  Commit: c4b9be95329f12c07a6b129aead48580d5e14e88
      https://github.com/PDAL/PDAL/commit/c4b9be95329f12c07a6b129aead48580d5e14e88
  Date:   2015-12-02 (Wed, 02 Dec 2015)
  Changed paths:
  Log Message:
  Merge branch 'master' into docker-config
  Commit: a81146e430e628f906f7964598c9b60c10fef504
      https://github.com/PDAL/PDAL/commit/a81146e430e628f906f7964598c9b60c10fef504
  Changed paths:
    A doc/docker.rst
    M doc/index.rst
  Log Message:
  start on docker tutorial
Compare: https://github.com/PDAL/PDAL/compare/863f859578c1...a81146e430e6
More information about the pdal-commits mailing list
