[pdal-commits] [PDAL/PDAL] ee910e: start refactoring PDAL's GEOS usage
GitHub noreply at github.com
Fri Dec 18 10:02:50 PST 2015
  Branch: refs/heads/geos-refactor
  Home:   https://github.com/PDAL/PDAL
  Commit: ee910ed69940b18bb06682d92377ac080fd90a68
      https://github.com/PDAL/PDAL/commit/ee910ed69940b18bb06682d92377ac080fd90a68
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-11-21 (Sat, 21 Nov 2015)
  Changed paths:
    A include/pdal/GEOSUtils.hpp
    R include/pdal/Geometry.hpp
    M include/pdal/GlobalEnvironment.hpp
    M plugins/hexbin/filters/HexBin.cpp
    M src/CMakeLists.txt
    A src/GEOSUtils.cpp
    M src/GlobalEnvironment.cpp
  Log Message:
  Commit: 71af83acdf39114c5eb570c1be457349e0bc6684
      https://github.com/PDAL/PDAL/commit/71af83acdf39114c5eb570c1be457349e0bc6684
  Date:   2015-12-15 (Tue, 15 Dec 2015)
  Changed paths:
    M .travis.yml
    M CMakeLists.txt
    A ChangeLog
    A RELEASENOTES.txt
    M appveyor.yml
    M cmake/geos.cmake
    A doc/docker.rst
    M doc/download.rst
    M doc/index.rst
    M doc/stages/filters.hexbin.rst
    A doc/stages/readers.tindex.rst
    M doc/tutorial/writing-reader.rst
    M doc/tutorial/writing-writer.rst
    M examples/writing-reader/pipeline-myreader.xml
    M examples/writing-writer/MyWriter.cpp
    M examples/writing-writer/MyWriter.hpp
    A examples/writing-writer/pipeline-mywriter.xml
    M filters/merge/MergeFilter.cpp
    M filters/merge/MergeFilter.hpp
    M filters/reprojection/ReprojectionFilter.cpp
    M include/pdal/Compression.hpp
    M include/pdal/Dimension.hpp
    M include/pdal/GDALUtils.hpp
    M include/pdal/GEOSUtils.hpp
    M include/pdal/PointTable.hpp
    M include/pdal/PointView.hpp
    M include/pdal/SpatialReference.hpp
    M include/pdal/util/Bounds.hpp
    M include/pdal/util/Utils.hpp
    M io/CMakeLists.txt
    M io/bpf/BpfReader.cpp
    M io/ilvis2/Ilvis2Reader.cpp
    M io/ilvis2/Ilvis2Reader.hpp
    M io/las/LasHeader.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M io/las/LasWriter.cpp
    M io/las/LasWriter.hpp
    A io/tindex/CMakeLists.txt
    A io/tindex/TIndexReader.cpp
    A io/tindex/TIndexReader.hpp
    M kernels/tindex/TIndexKernel.cpp
    M kernels/tindex/TIndexKernel.hpp
    M plugins/pgpointcloud/io/PgReader.cpp
    M scripts/ci/before_install.sh
    M scripts/ci/common.sh
    M scripts/ci/script.sh
    A scripts/docker/Dockerfile
    A scripts/docker/dependencies/Dockerfile
    A scripts/docker/packaging/Dockerfile
    M src/PointTable.cpp
    M src/SpatialReference.cpp
    M src/StageFactory.cpp
    M src/pdal_config.cpp
    M src/plang/Environment.cpp
    A test/data/filters/merge2.xml.in
    A test/data/filters/merge3.xml.in
    A test/data/ilvis2/ILVIS2_TEST_FILE.TXT
    A test/data/las/test1_4.las
    A test/data/las/test_utm16.las
    A test/data/pipeline/tindex.xml
    A test/data/pipeline/tindex.xml.in
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
  Merge branch 'master' into geos-refactor
  Commit: 379d165d1791075ce93926bc7bf6d7bcec357996
      https://github.com/PDAL/PDAL/commit/379d165d1791075ce93926bc7bf6d7bcec357996
  Changed paths:
    M src/util/FileUtils.cpp
  Log Message:
  remove using namespace std
  Commit: 1d0701b00500f52470980f1bec20eadff408c2a0
      https://github.com/PDAL/PDAL/commit/1d0701b00500f52470980f1bec20eadff408c2a0
  Changed paths:
  Log Message:
  small cleanups
  Commit: 9ad1019497f462f5d9f6e47a51f61ceea0b50f41
      https://github.com/PDAL/PDAL/commit/9ad1019497f462f5d9f6e47a51f61ceea0b50f41
  Changed paths:
    M src/GEOSUtils.cpp
  Log Message:
  get GEOS refactor compiling
  Commit: eb73ec7b15e449a5224ab71f3eb876052a08e98f
      https://github.com/PDAL/PDAL/commit/eb73ec7b15e449a5224ab71f3eb876052a08e98f
  Date:   2015-12-18 (Fri, 18 Dec 2015)
  Changed paths:
    M src/GEOSUtils.cpp
  Log Message:
  more GEOS refactor
Compare: https://github.com/PDAL/PDAL/compare/ee910ed69940^...eb73ec7b15e4
More information about the pdal-commits mailing list
