[pdal-commits] [PDAL/PDAL] 38013a: Update crop filter documentation.
GitHub noreply at github.com
Fri Dec 18 10:04:20 PST 2015
  Branch: refs/heads/geos-refactor
  Home:   https://github.com/PDAL/PDAL
  Commit: 38013aa4f028a588130dde74d42c8ef912c3315f
      https://github.com/PDAL/PDAL/commit/38013aa4f028a588130dde74d42c8ef912c3315f
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-12-16 (Wed, 16 Dec 2015)
  Changed paths:
    M doc/stages/filters.crop.rst
  Log Message:
  Commit: 182b36bf177d1404f394cca3377bf4aac75ddc76
      https://github.com/PDAL/PDAL/commit/182b36bf177d1404f394cca3377bf4aac75ddc76
  Changed paths:
    M include/pdal/Dimension.hpp
    M io/ilvis2/Ilvis2Reader.cpp
    M io/ilvis2/Ilvis2Reader.hpp
    A test/data/ilvis2/ILVIS2_TEST_FILE.TXT
    M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: c6bf9c269a13ab33fa7da998049bad618de30409
      https://github.com/PDAL/PDAL/commit/c6bf9c269a13ab33fa7da998049bad618de30409
  Changed paths:
    M doc/stages/filters.decimation.rst
    M filters/CMakeLists.txt
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M filters/crop/CropFilter.cpp
    M filters/crop/CropFilter.hpp
    M filters/decimation/DecimationFilter.cpp
    M filters/decimation/DecimationFilter.hpp
    M filters/ferry/FerryFilter.cpp
    M filters/ferry/FerryFilter.hpp
    M filters/merge/MergeFilter.hpp
    M filters/range/RangeFilter.cpp
    M filters/range/RangeFilter.hpp
    M filters/reprojection/ReprojectionFilter.cpp
    M filters/reprojection/ReprojectionFilter.hpp
    M filters/sort/SortFilter.hpp
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    A filters/streamcallback/CMakeLists.txt
    A filters/streamcallback/StreamCallbackFilter.cpp
    A filters/streamcallback/StreamCallbackFilter.hpp
    M filters/transformation/TransformationFilter.cpp
    M filters/transformation/TransformationFilter.hpp
    M include/pdal/FlexWriter.hpp
    A include/pdal/PointContainer.hpp
    M include/pdal/PointLayout.hpp
    A include/pdal/PointRef.hpp
    M include/pdal/PointTable.hpp
    M include/pdal/PointView.hpp
    M include/pdal/PointViewIter.hpp
    M include/pdal/Stage.hpp
    M include/pdal/util/OStream.hpp
    M io/bpf/BpfReader.cpp
    M io/bpf/BpfReader.hpp
    M io/faux/FauxReader.cpp
    M io/faux/FauxReader.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M io/las/LasWriter.cpp
    M io/las/LasWriter.hpp
    M io/sbet/SbetReader.cpp
    M io/sbet/SbetReader.hpp
    M src/CMakeLists.txt
    M src/PointTable.cpp
    M src/PointView.cpp
    M src/Stage.cpp
    R test/data/logs/logtest.txt
    A test/data/sbet/autzen_trim.sbet
    M test/unit/CMakeLists.txt
    M test/unit/LogTest.cpp
    M test/unit/PointTableTest.cpp
    A test/unit/StreamingTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/DecimationFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/RangeFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
  Streaming support.
  Commit: 520e1397334c43dda4c2e8ee609738b8f6d57e59
      https://github.com/PDAL/PDAL/commit/520e1397334c43dda4c2e8ee609738b8f6d57e59
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-12-18 (Fri, 18 Dec 2015)
  Changed paths:
    M scripts/docker/dependencies/Dockerfile
  Log Message:
  add CPD, FGT, and armadillo6 to dependencies Dockerfile
  Commit: 5b4b95ef5e6d5a37d8021995fa23b5d0db4b7146
      https://github.com/PDAL/PDAL/commit/5b4b95ef5e6d5a37d8021995fa23b5d0db4b7146
  Changed paths:
    M src/PointView.cpp
    M src/Stage.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into geos-refactor
Compare: https://github.com/PDAL/PDAL/compare/eb73ec7b15e4...5b4b95ef5e6d
More information about the pdal-commits mailing list
