[pdal-commits] [PDAL/PDAL] 01d9e1: Support GDAL 2.0+, improve GDAL configuration dete...
GitHub noreply at github.com
Mon Dec 28 09:55:55 PST 2015
  Branch: refs/heads/gdal-20-support
  Home:   https://github.com/PDAL/PDAL
  Commit: 01d9e147fb0105fa5435065c78e12f422dd1e566
      https://github.com/PDAL/PDAL/commit/01d9e147fb0105fa5435065c78e12f422dd1e566
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-12-28 (Mon, 28 Dec 2015)
  Changed paths:
    M cmake/gdal.cmake
    M cmake/modules/FindGDAL.cmake
    M io/derivative/DerivativeWriter.cpp
    M test/unit/SpatialReferenceTest.cpp
  Log Message:
  Support GDAL 2.0+, improve GDAL configuration detection
  Commit: 692aa8079b2224f65b462e3c393f6c8fa9aa43b4
      https://github.com/PDAL/PDAL/commit/692aa8079b2224f65b462e3c393f6c8fa9aa43b4
  Changed paths:
    M apps/pdal.cpp
    M doc/apps.rst
    M doc/compilation/index.rst
    A doc/compilation/python.rst
    M filters/divider/DividerFilter.hpp
    R include/pdal/BufferReader.hpp
    M include/pdal/KernelFactory.hpp
    M include/pdal/PluginManager.hpp
    M include/pdal/StageFactory.hpp
    M include/pdal/pdal_types.hpp
    M include/pdal/plugin.hpp
    M include/pdal/util/IStream.hpp
    M io/CMakeLists.txt
    M io/bpf/BpfReader.cpp
    A io/buffer/BufferReader.hpp
    A io/buffer/CMakeLists.txt
    M io/gdal/GDALReader.cpp
    M io/gdal/GDALReader.hpp
    M io/ilvis2/Ilvis2Reader.cpp
    M io/ilvis2/Ilvis2Reader.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M io/tindex/TIndexReader.cpp
    M io/tindex/TIndexReader.hpp
    M kernels/sort/SortKernel.cpp
    M kernels/split/SplitKernel.cpp
    M plugins/nitf/io/NitfReader.hpp
    M plugins/nitf/test/NitfWriterTest.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M src/CMakeLists.txt
    M src/GDALUtils.cpp
    M src/Kernel.cpp
    M src/KernelFactory.cpp
    M src/PipelineReader.cpp
    M src/PluginManager.cpp
    M src/SpatialReference.cpp
    M src/StageFactory.cpp
    M test/data/ilvis2/ILVIS2_TEST_FILE.TXT
    A test/data/png/autzen-height.png
    R test/data/pointbuffer/metadata.txt
    M test/unit/CMakeLists.txt
    M test/unit/PointViewTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/buffer/BufferTest.cpp
    A test/unit/io/gdal/GDALReaderTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL into gdal-20-support
Compare: https://github.com/PDAL/PDAL/compare/01d9e147fb01^...692aa8079b22
More information about the pdal-commits mailing list
