[pdal-commits] [PDAL/PDAL] 2b9cf8: Docker-based Travis build. Docker is now used to p...
GitHub noreply at github.com
Mon Dec 28 14:39:39 PST 2015
  Branch: refs/heads/python-extension-fixups
  Home:   https://github.com/PDAL/PDAL
  Commit: 2b9cf8aa855a5cf3dfecc07757aba033f808ae16
      https://github.com/PDAL/PDAL/commit/2b9cf8aa855a5cf3dfecc07757aba033f808ae16
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-12-02 (Wed, 02 Dec 2015)
  Changed paths:
    M .travis.yml
    A doc/docker.rst
    M doc/index.rst
    M scripts/ci/before_install.sh
    M scripts/ci/common.sh
    M scripts/ci/script.sh
    A scripts/docker/Dockerfile
    A scripts/docker/dependencies/Dockerfile
    A scripts/docker/packaging/Dockerfile
  Log Message:
  Docker-based Travis build. Docker is now used to provide Travis
dependencies. See https://hub.docker.com/r/pdal/dependencies/ for
the dependencies image. The Dockerfile to rebuild the configuration
is at ./scripts/docker/dependencies
  Commit: 7b12ccf183ce11c46e962b727a5e705d3eb2305a
      https://github.com/PDAL/PDAL/commit/7b12ccf183ce11c46e962b727a5e705d3eb2305a
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M include/pdal/util/Bounds.hpp
    M io/ilvis2/Ilvis2Reader.cpp
    M io/ilvis2/Ilvis2Reader.hpp
    M io/tindex/TIndexReader.cpp
    M io/tindex/TIndexReader.hpp
    M plugins/pgpointcloud/io/PgReader.cpp
  Log Message:
  Make sure we set a stage's spatial reference in the prepare() step.
  Commit: c85b6b3b2ade1ec182aa105e6111e72bde27c202
      https://github.com/PDAL/PDAL/commit/c85b6b3b2ade1ec182aa105e6111e72bde27c202
  Changed paths:
    M .travis.yml
    A doc/docker.rst
    M doc/download.rst
    M doc/index.rst
    M include/pdal/Geometry.hpp
    M kernels/tindex/TIndexKernel.cpp
    M kernels/tindex/TIndexKernel.hpp
    M plugins/hexbin/filters/HexBin.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: 9e5f511c8a4497fec9eb4e5b3ec81b437335e446
      https://github.com/PDAL/PDAL/commit/9e5f511c8a4497fec9eb4e5b3ec81b437335e446
  Changed paths:
  Log Message:
  be more careful about checking geometry fetches
  Commit: eb0e26f9b7637b7f1204eb09d2eb119809ac9d97
      https://github.com/PDAL/PDAL/commit/eb0e26f9b7637b7f1204eb09d2eb119809ac9d97
  Changed paths:
  Log Message:
  apply a default hole cull tolerance
  Commit: bb34dc4e8f98fa87bfdc8447a40d926e064d8112
      https://github.com/PDAL/PDAL/commit/bb34dc4e8f98fa87bfdc8447a40d926e064d8112
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-12-03 (Thu, 03 Dec 2015)
  Changed paths:
    M appveyor.yml
  Log Message:
  Try to force the 64-bit version of python
  Commit: 9360b576b97c8c3dfe5ed1be4d47f97c4d529ef6
      https://github.com/PDAL/PDAL/commit/9360b576b97c8c3dfe5ed1be4d47f97c4d529ef6
  Changed paths:
    M appveyor.yml
  Log Message:
  Set 64-bit python on path ahead of 32-bit for CMake to grab the correct one
  Commit: 2d76dc82f1b231e4bf5d98dbf82b9c0cbb32a3e0
      https://github.com/PDAL/PDAL/commit/2d76dc82f1b231e4bf5d98dbf82b9c0cbb32a3e0
  Author: pdal-docs <pdal at hobu.net>
  Changed paths:
    M appveyor.yml
  Log Message:
  Merge pull request #1061 from PDAL/specify-python-path-appveyor
Prepend path to 64-bit Python to make sure CMake detects it
  Commit: 7fa70528e1dec2fed09fa7eaac0884e4bee53ff2
      https://github.com/PDAL/PDAL/commit/7fa70528e1dec2fed09fa7eaac0884e4bee53ff2
  Changed paths:
    M scripts/docker/Dockerfile
  Log Message:
  force usage of clang for PDAL compilation in docker build
  Commit: 5a9f742b2f5d182a46fbeda92305b782def78940
      https://github.com/PDAL/PDAL/commit/5a9f742b2f5d182a46fbeda92305b782def78940
  Changed paths:
    M appveyor.yml
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: f54c96cf2bb8f8ecf11e6d9911fd223dc79c2c6e
      https://github.com/PDAL/PDAL/commit/f54c96cf2bb8f8ecf11e6d9911fd223dc79c2c6e
  Changed paths:
  Log Message:
  Merge branch '1.1-maintenance'
  Commit: 37896928b66b0e8f51d131c74ae97a68a6e9beff
      https://github.com/PDAL/PDAL/commit/37896928b66b0e8f51d131c74ae97a68a6e9beff
  Changed paths:
  Log Message:
  add Dockerfile for 1.1
  Commit: 3899850fd3f33d29965fd5217bc040f81c0a1dce
      https://github.com/PDAL/PDAL/commit/3899850fd3f33d29965fd5217bc040f81c0a1dce
  Author: Scott Lewis <scott.lewis at nsidc.org>
  Changed paths:
    A test/data/ilvis2/ILVIS2_TEST_FILE.TXT
    M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
  Log Message:
  Updated ILVIS Reader and test
Fixed the ILViS Reader to read longitude correctly, and added a
means to specify ALL, which will generate multiple points for a
shot if the HIGH and LOW elevation values differ.  Updated the
tests to use a smaller "dummy" file which tests the specific things
that the reader does.
  Commit: 9753dc71873a92129aea114c5a1b62c064e9f541
      https://github.com/PDAL/PDAL/commit/9753dc71873a92129aea114c5a1b62c064e9f541
  Changed paths:
    M .travis.yml
    M appveyor.yml
    A doc/docker.rst
    M doc/index.rst
  Log Message:
  Merge branch 'master' into 1.1-maintenance
  Commit: f646dfb73e95e2cab164a9c40fe40b46e6584da3
      https://github.com/PDAL/PDAL/commit/f646dfb73e95e2cab164a9c40fe40b46e6584da3
  Author: Connor Manning <connor at hobu.co>
  Date:   2015-12-07 (Mon, 07 Dec 2015)
  Changed paths:
    M filters/reprojection/ReprojectionFilter.cpp
  Log Message:
  If we're not inferring the input SRS to the reprojection filter, create the transform during initialize, allowing usage of the FilterWrapper.
  Commit: 67abd91080f0d9a3c792d354ddac56ac91c5ec88
      https://github.com/PDAL/PDAL/commit/67abd91080f0d9a3c792d354ddac56ac91c5ec88
  Changed paths:
  Log Message:
  Remove null view check and nullptr keyword usage, add braces.
  Commit: c443148f6b8db27abb27d568119dff86ddfa62d5
      https://github.com/PDAL/PDAL/commit/c443148f6b8db27abb27d568119dff86ddfa62d5
  Changed paths:
  Log Message:
  Describe the purpose behind creating the transform during initialize.
  Commit: f990e05c51fdb7fe88fa3b402b378668bd31ec06
      https://github.com/PDAL/PDAL/commit/f990e05c51fdb7fe88fa3b402b378668bd31ec06
  Author: Connor Manning <connormanning at users.noreply.github.com>
  Changed paths:
  Log Message:
  Merge pull request #1062 from PDAL/reprojection-srs-creation
Create transform for ReprojectionFilter as soon as necessary inputs are available.
  Commit: 7c38dae312c6bfa73d0f95350428c7503d2ccd23
      https://github.com/PDAL/PDAL/commit/7c38dae312c6bfa73d0f95350428c7503d2ccd23
  Changed paths:
    M io/las/LasWriter.hpp
  Log Message:
  Valid global_encoding values can go up to 31.
Close #1064
  Commit: 5849ac3ba04492374449c17fa8b2f050579aa16f
      https://github.com/PDAL/PDAL/commit/5849ac3ba04492374449c17fa8b2f050579aa16f
  Changed paths:
    M include/pdal/Dimension.hpp
    M io/las/LasReader.cpp
    M io/las/LasWriter.cpp
    M test/unit/io/las/LasReaderTest.cpp
  Log Message:
  Handle LAS 1.4 classification flags as bitfield.
Close #1063
  Commit: 4c6b760fc00831407e256f96312c509b771d8415
      https://github.com/PDAL/PDAL/commit/4c6b760fc00831407e256f96312c509b771d8415
  Changed paths:
  Log Message:
  Format.
  Commit: 732a367ab337dd0916965ab3e4fb836a8ebe7c12
      https://github.com/PDAL/PDAL/commit/732a367ab337dd0916965ab3e4fb836a8ebe7c12
  Changed paths:
  Log Message:
  Handle metadata forwards to get version number before we fill the header
so version number info can be used correctly, etc.
Close #1065
  Commit: b6fc94059642d2d486a93226d59d25ed20ac33f5
      https://github.com/PDAL/PDAL/commit/b6fc94059642d2d486a93226d59d25ed20ac33f5
  Changed paths:
  Log Message:
  make branch a Dockerfile ARG
  Commit: 35f7887bd2206e579d3b73d988fe84f058ae5133
      https://github.com/PDAL/PDAL/commit/35f7887bd2206e579d3b73d988fe84f058ae5133
  Changed paths:
  Log Message:
  Commit: 52f266966d793174a86faaad0632779126c5e75f
      https://github.com/PDAL/PDAL/commit/52f266966d793174a86faaad0632779126c5e75f
  Date:   2015-12-08 (Tue, 08 Dec 2015)
  Changed paths:
    M io/bpf/BpfReader.cpp
    M test/unit/io/bpf/BPFTest.cpp
  Log Message:
  Put bundled files in a subnode from a node called "bundled_file".
Close #1066
  Commit: 8da451aedd4e2b2251b1528f0a4006182f9b3956
      https://github.com/PDAL/PDAL/commit/8da451aedd4e2b2251b1528f0a4006182f9b3956
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/1.1-maintenance' into 1.1-maintenance
  Commit: e03f93c9f97008a21c9a163513b51b76e58db389
      https://github.com/PDAL/PDAL/commit/e03f93c9f97008a21c9a163513b51b76e58db389
  Changed paths:
  Log Message:
  Commit: ee2da56d53b6eadc6271cf85e50f798f40fdbc7f
      https://github.com/PDAL/PDAL/commit/ee2da56d53b6eadc6271cf85e50f798f40fdbc7f
  Changed paths:
    A test/data/las/test1_4.las
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
  Tests for some 1063, 1064 and 1065.
  Commit: 692cb11170744af5750d1c331c5d574d6c4be99c
      https://github.com/PDAL/PDAL/commit/692cb11170744af5750d1c331c5d574d6c4be99c
  Changed paths:
  Log Message:
  Dockerfile cleanup and ENTRYPOINT
  Commit: 5a52bc69a6fd689c95a21cd8d5b21cadf232c19c
      https://github.com/PDAL/PDAL/commit/5a52bc69a6fd689c95a21cd8d5b21cadf232c19c
  Changed paths:
  Log Message:
  Commit: 781c8acfc5ea3680601619c982f451f0df652f28
      https://github.com/PDAL/PDAL/commit/781c8acfc5ea3680601619c982f451f0df652f28
  Changed paths:
  Log Message:
  remove ENTRYPOINT
  Commit: 5e96a28c42605127c2b948e634995121aaad3863
      https://github.com/PDAL/PDAL/commit/5e96a28c42605127c2b948e634995121aaad3863
  Changed paths:
  Log Message:
  remove ENTRYPOINT
  Commit: 6409766a18861a9c8defc50b32a4778c15ed8a8d
      https://github.com/PDAL/PDAL/commit/6409766a18861a9c8defc50b32a4778c15ed8a8d
  Changed paths:
    M cmake/geos.cmake
    M include/pdal/Compression.hpp
    M src/pdal_config.cpp
  Log Message:
  Compilation fixes for Ubuntu 14.04.
  Commit: c40c7131ad97443480acf34fba0ec7d3d8f37f8f
      https://github.com/PDAL/PDAL/commit/c40c7131ad97443480acf34fba0ec7d3d8f37f8f
  Changed paths:
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL
  Commit: 220e398f0e4697419f23cc875a2e6a7f8bfdaec3
      https://github.com/PDAL/PDAL/commit/220e398f0e4697419f23cc875a2e6a7f8bfdaec3
  Date:   2015-12-09 (Wed, 09 Dec 2015)
  Changed paths:
    M cmake/geos.cmake
  Log Message:
  Commit: 0c36aa9db5b5cf5f8264621698bc8d176a3ff8a0
      https://github.com/PDAL/PDAL/commit/0c36aa9db5b5cf5f8264621698bc8d176a3ff8a0
  Changed paths:
    M src/plang/Environment.cpp
  Log Message:
  Remove debug.
  Commit: 9af82edff08809fc4b3c1880f9f0bd2998b69987
      https://github.com/PDAL/PDAL/commit/9af82edff08809fc4b3c1880f9f0bd2998b69987
  Changed paths:
  Log Message:
  Fix path for pdal in test.
  Commit: 8f3095b24dc4cea2d8e865bfd6f9ef5fc0fe5191
      https://github.com/PDAL/PDAL/commit/8f3095b24dc4cea2d8e865bfd6f9ef5fc0fe5191
  Changed paths:
    M scripts/docker/dependencies/Dockerfile
  Log Message:
  manually install current geotiff after package has installed for pdal/dependencies Dockerfile
  Commit: e1c08043d853004ddfd59f776028ddcf13ceccef
      https://github.com/PDAL/PDAL/commit/e1c08043d853004ddfd59f776028ddcf13ceccef
  Changed paths:
    M cmake/geos.cmake
  Log Message:
  Commit: 8a85f2dc597cc0aa525d4eb32a28487243379c59
      https://github.com/PDAL/PDAL/commit/8a85f2dc597cc0aa525d4eb32a28487243379c59
  Date:   2015-12-10 (Thu, 10 Dec 2015)
  Changed paths:
    M plugins/hexbin/filters/HexBin.hpp
  Log Message:
  Use densePointCount() to calculate density.
  Commit: f5f4c6e11db9a3547885260871daa0495574b05b
      https://github.com/PDAL/PDAL/commit/f5f4c6e11db9a3547885260871daa0495574b05b
  Changed paths:
  Log Message:
  Commit: f53f4a39912d639edfef9d3d0d2a7da7e82826f6
      https://github.com/PDAL/PDAL/commit/f53f4a39912d639edfef9d3d0d2a7da7e82826f6
  Changed paths:
  Log Message:
  Use old method of point count for density for now.
  Commit: dd3ec7a508c7910b3ffae11bbd8e255ea7c045cb
      https://github.com/PDAL/PDAL/commit/dd3ec7a508c7910b3ffae11bbd8e255ea7c045cb
  Changed paths:
    M .travis.yml
    M CMakeLists.txt
    A ChangeLog
    A RELEASENOTES.txt
    M appveyor.yml
    M cmake/geos.cmake
    M doc/development/conventions.rst
    M doc/development/errorhandling.rst
    M doc/development/goals.rst
    M doc/development/index.rst
    M doc/development/testing.rst
    R doc/development/usecases.rst
    A doc/docker.rst
    M doc/download.rst
    M doc/index.rst
    M doc/stages/filters.hexbin.rst
    M doc/stages/ranges.rst
    M doc/stages/readers.las.rst
    A doc/stages/readers.tindex.rst
    M doc/tutorial/writing-reader.rst
    M doc/tutorial/writing-writer.rst
    M examples/writing-reader/pipeline-myreader.xml
    M examples/writing-writer/MyWriter.cpp
    M examples/writing-writer/MyWriter.hpp
    A examples/writing-writer/pipeline-mywriter.xml
    M filters/crop/CropFilter.cpp
    M filters/crop/CropFilter.hpp
    M filters/merge/MergeFilter.cpp
    M filters/merge/MergeFilter.hpp
    M filters/reprojection/ReprojectionFilter.hpp
    M include/pdal/FlexWriter.hpp
    M include/pdal/GDALUtils.hpp
    M include/pdal/Metadata.hpp
    M include/pdal/PointTable.hpp
    M include/pdal/PointView.hpp
    M include/pdal/SpatialReference.hpp
    M include/pdal/Stage.hpp
    M include/pdal/StageWrapper.hpp
    M include/pdal/util/Algorithm.hpp
    M include/pdal/util/Utils.hpp
    M io/CMakeLists.txt
    M io/bpf/BpfWriter.cpp
    M io/bpf/BpfWriter.hpp
    M io/derivative/DerivativeWriter.cpp
    M io/derivative/DerivativeWriter.hpp
    M io/las/LasError.hpp
    M io/las/LasHeader.hpp
    M io/las/LasReader.hpp
    M io/text/TextWriter.cpp
    A io/tindex/CMakeLists.txt
    A io/tindex/TIndexReader.cpp
    A io/tindex/TIndexReader.hpp
    M pdal_defines.h.in
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/NitfWriter.hpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/p2g/io/P2gWriter.cpp
    M plugins/p2g/io/P2gWriter.hpp
    M plugins/pcl/dartsample/dart_sample.h
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M plugins/python/filters/ProgrammableFilter.cpp
    R plugins/python/plang/CMakeLists.txt
    R plugins/python/plang/Plang.cpp
    R plugins/python/plang/Plang.hpp
    M src/PointLayout.cpp
    M src/PointTable.cpp
    M src/PointView.cpp
    M src/SpatialReference.cpp
    M src/Stage.cpp
    M src/StageFactory.cpp
    A test/data/filters/merge2.xml.in
    A test/data/filters/merge3.xml.in
    A test/data/las/test_epsg_4047.las
    A test/data/las/test_epsg_4326.las
    A test/data/las/test_epsg_4326x3.las
    A test/data/las/test_utm16.las
    A test/data/las/test_utm17.las
    A test/data/pipeline/tindex.xml
    A test/data/pipeline/tindex.xml.in
    M test/unit/CMakeLists.txt
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/Support.cpp
    M test/unit/Support.hpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/MergeTest.cpp
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL into ilvis2-reader-update
  Commit: c6829c07bc3c044b0c958a452eb2957664f62be6
      https://github.com/PDAL/PDAL/commit/c6829c07bc3c044b0c958a452eb2957664f62be6
  Changed paths:
  Log Message:
  Using an enum for mapping, allowing lowercase
  Commit: 0bc306df8f5986f0c50da7f7d6944a33148242b1
      https://github.com/PDAL/PDAL/commit/0bc306df8f5986f0c50da7f7d6944a33148242b1
  Changed paths:
  Log Message:
  Changing ILVIS proprietary dims to regular dims
  Commit: 30a7555099aede40cbc0c112be5efa1b817bd654
      https://github.com/PDAL/PDAL/commit/30a7555099aede40cbc0c112be5efa1b817bd654
  Date:   2015-12-11 (Fri, 11 Dec 2015)
  Changed paths:
  Log Message:
  Merge pull request #1068 from scott-lewis-nsidc/ilvis2-reader-update
Ilvis2 reader update
  Commit: 38013aa4f028a588130dde74d42c8ef912c3315f
      https://github.com/PDAL/PDAL/commit/38013aa4f028a588130dde74d42c8ef912c3315f
  Date:   2015-12-16 (Wed, 16 Dec 2015)
  Changed paths:
    M doc/stages/filters.crop.rst
  Log Message:
  Update crop filter documentation.
  Commit: 182b36bf177d1404f394cca3377bf4aac75ddc76
      https://github.com/PDAL/PDAL/commit/182b36bf177d1404f394cca3377bf4aac75ddc76
  Changed paths:
  Log Message:
  Commit: c6bf9c269a13ab33fa7da998049bad618de30409
      https://github.com/PDAL/PDAL/commit/c6bf9c269a13ab33fa7da998049bad618de30409
  Changed paths:
    M doc/stages/filters.decimation.rst
    M filters/CMakeLists.txt
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M filters/decimation/DecimationFilter.cpp
    M filters/decimation/DecimationFilter.hpp
    M filters/ferry/FerryFilter.cpp
    M filters/ferry/FerryFilter.hpp
    M filters/range/RangeFilter.cpp
    M filters/range/RangeFilter.hpp
    M filters/sort/SortFilter.hpp
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    A filters/streamcallback/CMakeLists.txt
    A filters/streamcallback/StreamCallbackFilter.cpp
    A filters/streamcallback/StreamCallbackFilter.hpp
    M filters/transformation/TransformationFilter.cpp
    M filters/transformation/TransformationFilter.hpp
    A include/pdal/PointContainer.hpp
    M include/pdal/PointLayout.hpp
    A include/pdal/PointRef.hpp
    M include/pdal/PointViewIter.hpp
    M include/pdal/util/OStream.hpp
    M io/bpf/BpfReader.hpp
    M io/faux/FauxReader.cpp
    M io/faux/FauxReader.hpp
    M io/sbet/SbetReader.cpp
    M io/sbet/SbetReader.hpp
    M src/CMakeLists.txt
    M src/PointView.cpp
    M src/Stage.cpp
    R test/data/logs/logtest.txt
    A test/data/sbet/autzen_trim.sbet
    M test/unit/LogTest.cpp
    M test/unit/PointTableTest.cpp
    A test/unit/StreamingTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/DecimationFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/RangeFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
  Log Message:
  Streaming support.
  Commit: 520e1397334c43dda4c2e8ee609738b8f6d57e59
      https://github.com/PDAL/PDAL/commit/520e1397334c43dda4c2e8ee609738b8f6d57e59
  Date:   2015-12-18 (Fri, 18 Dec 2015)
  Changed paths:
  Log Message:
  add CPD, FGT, and armadillo6 to dependencies Dockerfile
  Commit: c5763c75afc07acbb14b2bae9960c66e7f9f85cc
      https://github.com/PDAL/PDAL/commit/c5763c75afc07acbb14b2bae9960c66e7f9f85cc
  Changed paths:
    M src/GDALUtils.cpp
  Log Message:
  Allow error return from Raster without necessarily throwing an exception.
  Commit: 13695469961b465fd6d3b64bc628b76b0b05b8bd
      https://github.com/PDAL/PDAL/commit/13695469961b465fd6d3b64bc628b76b0b05b8bd
  Changed paths:
    M src/GDALUtils.cpp
  Log Message:
  MS still doesn't do initialization lists in ctors.
  Commit: e0e53e6c4ff70cd239ff188bde331c23f47d411f
      https://github.com/PDAL/PDAL/commit/e0e53e6c4ff70cd239ff188bde331c23f47d411f
  Date:   2015-12-21 (Mon, 21 Dec 2015)
  Changed paths:
  Log Message:
  catch up Docker config for CPD
  Commit: adbf3ba11e9248f4b98e1dc2a1eda21f2b9eb5c8
      https://github.com/PDAL/PDAL/commit/adbf3ba11e9248f4b98e1dc2a1eda21f2b9eb5c8
  Changed paths:
    M doc/stages/writers.las.rst
  Log Message:
  Fix default minor version of LAS file in documentation.
  Commit: e105dcdc753933ea910f06371f9a88c3cb658c9f
      https://github.com/PDAL/PDAL/commit/e105dcdc753933ea910f06371f9a88c3cb658c9f
  Changed paths:
  Log Message:
  Commit: 277b2a20f0690ba0ee7f0ec6920e0af215d70beb
      https://github.com/PDAL/PDAL/commit/277b2a20f0690ba0ee7f0ec6920e0af215d70beb
  Changed paths:
    M kernels/random/RandomKernel.cpp
    A test/unit/apps/RandomTest.cpp
  Log Message:
  Add support for stage-specific options on random kernel.
Close #1072
  Commit: 93d8b8539cb402711a7f37fa0be5d1384cff646a
      https://github.com/PDAL/PDAL/commit/93d8b8539cb402711a7f37fa0be5d1384cff646a
  Changed paths:
  Log Message:
  clean up Docker-built stuff when making dependencies image
  Commit: 2a29b07cd411c4f9bf98f34c6510f7125b62d140
      https://github.com/PDAL/PDAL/commit/2a29b07cd411c4f9bf98f34c6510f7125b62d140
  Date:   2015-12-22 (Tue, 22 Dec 2015)
  Changed paths:
    M include/pdal/util/IStream.hpp
    M io/gdal/GDALReader.cpp
    M io/gdal/GDALReader.hpp
    M plugins/nitf/io/NitfReader.hpp
    M src/GDALUtils.cpp
    M test/data/ilvis2/ILVIS2_TEST_FILE.TXT
    A test/data/png/autzen-height.png
    R test/data/pointbuffer/metadata.txt
    M test/unit/PointViewTest.cpp
    A test/unit/io/gdal/GDALReaderTest.cpp
  Log Message:
  Make sure files at the end of the prepare() step.
NOTE: Note done for greyhound and MrSid.
Close #1017
  Commit: dcc11deebeb6df33cdc448028da42610cecb8465
      https://github.com/PDAL/PDAL/commit/dcc11deebeb6df33cdc448028da42610cecb8465
  Changed paths:
    R include/pdal/BufferReader.hpp
    M io/CMakeLists.txt
    A io/buffer/BufferReader.hpp
  Log Message:
  Move BufferReader to io directory.
Close #1070
  Commit: 2d6f343dfb5e976c5eba2853494225702974bac7
      https://github.com/PDAL/PDAL/commit/2d6f343dfb5e976c5eba2853494225702974bac7
  Changed paths:
    A io/buffer/CMakeLists.txt
  Log Message:
  Add forgotten file.
  Commit: 419624967f7d185730e52740ce52fdf7f318124f
      https://github.com/PDAL/PDAL/commit/419624967f7d185730e52740ce52fdf7f318124f
  Changed paths:
    M kernels/sort/SortKernel.cpp
    M kernels/split/SplitKernel.cpp
    M plugins/nitf/test/NitfWriterTest.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M src/Kernel.cpp
    M test/unit/io/buffer/BufferTest.cpp
  Log Message:
  Fix directory location of BufferReader.
Fix bug in non-initialized m_resample variable in ilvis2 reader.
  Commit: df8991f74769f2fd7e0b48ff15fb4c6e12aec808
      https://github.com/PDAL/PDAL/commit/df8991f74769f2fd7e0b48ff15fb4c6e12aec808
  Changed paths:
    M filters/divider/DividerFilter.hpp
  Log Message:
  Fix a typo and register the divider filter.
  Commit: c06d198e9c700613f04b003e64ea4a0cd8c5d0e0
      https://github.com/PDAL/PDAL/commit/c06d198e9c700613f04b003e64ea4a0cd8c5d0e0
  Changed paths:
    M io/buffer/CMakeLists.txt
  Log Message:
  Install BufferReader header.
  Commit: bf4a6a77dd3a6315542c6585c7b5cdd4daf5559b
      https://github.com/PDAL/PDAL/commit/bf4a6a77dd3a6315542c6585c7b5cdd4daf5559b
  Changed paths:
  Log Message:
  Install BufferReader header explicitly since there are no compiled files.
  Commit: b870a93a5c5a47c761fbf0beb34ffdc8c9085a12
      https://github.com/PDAL/PDAL/commit/b870a93a5c5a47c761fbf0beb34ffdc8c9085a12
  Author: Luca Delucchi <lucadeluge at gmail.com>
  Date:   2015-12-28 (Mon, 28 Dec 2015)
  Changed paths:
    M doc/compilation/index.rst
    A doc/compilation/python.rst
  Log Message:
  added documentation about PDAL python installation
  Commit: 837565722f71981a21ab9d51ee79acbe370e5d81
      https://github.com/PDAL/PDAL/commit/837565722f71981a21ab9d51ee79acbe370e5d81
  Changed paths:
  Log Message:
  Merge pull request #1073 from lucadelu/python_installation
  Commit: 75f7ed21e97e5197fefee9d8244adbc1a2abf166
      https://github.com/PDAL/PDAL/commit/75f7ed21e97e5197fefee9d8244adbc1a2abf166
  Changed paths:
    M apps/pdal.cpp
    M include/pdal/KernelFactory.hpp
    M include/pdal/PluginManager.hpp
    M include/pdal/StageFactory.hpp
    M include/pdal/pdal_types.hpp
    M include/pdal/plugin.hpp
    M src/KernelFactory.cpp
    M src/PipelineReader.cpp
    M src/PluginManager.cpp
  Log Message:
  Provide thread-safety for PluginManger, KernelManager, StageManager
Close #1048
commit 7036617cddf37c68a0ff91d96cc644b55c577e3d
Date:   Mon Dec 28 10:10:29 2015 -0600
    Don't provide access to PluginManager.
  Commit: af950c6e6944621fadf042ffd1de34d660dd9074
      https://github.com/PDAL/PDAL/commit/af950c6e6944621fadf042ffd1de34d660dd9074
  Changed paths:
  Log Message:
  Add mutex header.
  Commit: 6811c62179611d008c93fdd5ffc79730dfb74228
      https://github.com/PDAL/PDAL/commit/6811c62179611d008c93fdd5ffc79730dfb74228
  Changed paths:
    M doc/apps.rst
  Log Message:
  Add documentation for the merge kernel.
Close #1035
  Commit: 01d9e147fb0105fa5435065c78e12f422dd1e566
      https://github.com/PDAL/PDAL/commit/01d9e147fb0105fa5435065c78e12f422dd1e566
  Changed paths:
    M cmake/gdal.cmake
    M cmake/modules/FindGDAL.cmake
  Log Message:
  Support GDAL 2.0+, improve GDAL configuration detection
  Commit: 692aa8079b2224f65b462e3c393f6c8fa9aa43b4
      https://github.com/PDAL/PDAL/commit/692aa8079b2224f65b462e3c393f6c8fa9aa43b4
  Changed paths:
    M apps/pdal.cpp
    M doc/apps.rst
    M io/CMakeLists.txt
    M src/GDALUtils.cpp
    M src/Kernel.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL into gdal-20-support
  Commit: 5fd0ac548c185443443fa5614ffd615f499de456
      https://github.com/PDAL/PDAL/commit/5fd0ac548c185443443fa5614ffd615f499de456
  Changed paths:
  Log Message:
  remove debug lint
  Commit: 00ed45211eca299337f2cf6d748a3f569b0e3570
      https://github.com/PDAL/PDAL/commit/00ed45211eca299337f2cf6d748a3f569b0e3570
  Changed paths:
    M cmake/gdal.cmake
  Log Message:
  Merge pull request #1075 from PDAL/gdal-20-support
  Commit: 604c7e028acb7b262049d3b2c4d206bd74251877
      https://github.com/PDAL/PDAL/commit/604c7e028acb7b262049d3b2c4d206bd74251877
  Changed paths:
    M .travis.yml
    M apps/pdal.cpp
    M appveyor.yml
    M cmake/gdal.cmake
    M cmake/geos.cmake
    M doc/apps.rst
    A doc/docker.rst
    M doc/index.rst
    M io/CMakeLists.txt
    M src/GDALUtils.cpp
    M src/Kernel.cpp
    M src/PointView.cpp
    M src/Stage.cpp
  Log Message:
  Merge remote-tracking branch 'origin' into python-extension-fixups
Compare: https://github.com/PDAL/PDAL/compare/41b9647af6cf...604c7e028acb
More information about the pdal-commits mailing list
