[pdal-commits] [PDAL/PDAL] c7d4a1: Python 1.1.0 extension fixups
GitHub noreply at github.com
Mon Dec 28 18:04:07 PST 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: c7d4a163a2e969ef5f343ce7693edf4b080d9015
      https://github.com/PDAL/PDAL/commit/c7d4a163a2e969ef5f343ce7693edf4b080d9015
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-12-02 (Wed, 02 Dec 2015)
  Changed paths:
    M python/VERSION.txt
    M python/pdal/libpdalpython.pyx
  Log Message:
  Commit: 76549ffff8ea9cbe1e2aa0ce3d9925d963f0e664
      https://github.com/PDAL/PDAL/commit/76549ffff8ea9cbe1e2aa0ce3d9925d963f0e664
  Changed paths:
    M python/pdal/__init__.py
  Log Message:
  version bump
  Commit: 41b9647af6cf943a7308ae802877af5d43f8bbc0
      https://github.com/PDAL/PDAL/commit/41b9647af6cf943a7308ae802877af5d43f8bbc0
  Changed paths:
    M python/MANIFEST.in
    M python/setup.py
  Log Message:
  more python fixups for PyPI
  Commit: 604c7e028acb7b262049d3b2c4d206bd74251877
      https://github.com/PDAL/PDAL/commit/604c7e028acb7b262049d3b2c4d206bd74251877
  Date:   2015-12-28 (Mon, 28 Dec 2015)
  Changed paths:
    M .travis.yml
    M apps/pdal.cpp
    M appveyor.yml
    M cmake/gdal.cmake
    M cmake/geos.cmake
    M cmake/modules/FindGDAL.cmake
    M doc/apps.rst
    M doc/compilation/index.rst
    A doc/compilation/python.rst
    A doc/docker.rst
    M doc/index.rst
    M doc/stages/filters.crop.rst
    M doc/stages/filters.decimation.rst
    M doc/stages/writers.las.rst
    M filters/CMakeLists.txt
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M filters/crop/CropFilter.cpp
    M filters/crop/CropFilter.hpp
    M filters/decimation/DecimationFilter.cpp
    M filters/decimation/DecimationFilter.hpp
    M filters/divider/DividerFilter.hpp
    M filters/ferry/FerryFilter.cpp
    M filters/ferry/FerryFilter.hpp
    M filters/merge/MergeFilter.hpp
    M filters/range/RangeFilter.cpp
    M filters/range/RangeFilter.hpp
    M filters/reprojection/ReprojectionFilter.cpp
    M filters/reprojection/ReprojectionFilter.hpp
    M filters/sort/SortFilter.hpp
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    A filters/streamcallback/CMakeLists.txt
    A filters/streamcallback/StreamCallbackFilter.cpp
    A filters/streamcallback/StreamCallbackFilter.hpp
    M filters/transformation/TransformationFilter.cpp
    M filters/transformation/TransformationFilter.hpp
    R include/pdal/BufferReader.hpp
    M include/pdal/Compression.hpp
    M include/pdal/Dimension.hpp
    M include/pdal/FlexWriter.hpp
    M include/pdal/GDALUtils.hpp
    M include/pdal/Geometry.hpp
    M include/pdal/KernelFactory.hpp
    M include/pdal/PluginManager.hpp
    A include/pdal/PointContainer.hpp
    M include/pdal/PointLayout.hpp
    A include/pdal/PointRef.hpp
    M include/pdal/PointTable.hpp
    M include/pdal/PointView.hpp
    M include/pdal/PointViewIter.hpp
    M include/pdal/Stage.hpp
    M include/pdal/StageFactory.hpp
    M include/pdal/pdal_types.hpp
    M include/pdal/plugin.hpp
    M include/pdal/util/Bounds.hpp
    M include/pdal/util/IStream.hpp
    M include/pdal/util/OStream.hpp
    M io/CMakeLists.txt
    M io/bpf/BpfReader.cpp
    M io/bpf/BpfReader.hpp
    A io/buffer/BufferReader.hpp
    A io/buffer/CMakeLists.txt
    M io/derivative/DerivativeWriter.cpp
    M io/faux/FauxReader.cpp
    M io/faux/FauxReader.hpp
    M io/gdal/GDALReader.cpp
    M io/gdal/GDALReader.hpp
    M io/ilvis2/Ilvis2Reader.cpp
    M io/ilvis2/Ilvis2Reader.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M io/las/LasWriter.cpp
    M io/las/LasWriter.hpp
    M io/sbet/SbetReader.cpp
    M io/sbet/SbetReader.hpp
    M io/tindex/TIndexReader.cpp
    M io/tindex/TIndexReader.hpp
    M kernels/random/RandomKernel.cpp
    M kernels/sort/SortKernel.cpp
    M kernels/split/SplitKernel.cpp
    M plugins/hexbin/filters/HexBin.cpp
    M plugins/nitf/io/NitfReader.hpp
    M plugins/nitf/test/NitfWriterTest.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M plugins/pgpointcloud/io/PgReader.cpp
    M scripts/ci/before_install.sh
    M scripts/ci/common.sh
    M scripts/ci/script.sh
    A scripts/docker/Dockerfile
    A scripts/docker/dependencies/Dockerfile
    A scripts/docker/packaging/Dockerfile
    M src/CMakeLists.txt
    M src/GDALUtils.cpp
    M src/Kernel.cpp
    M src/KernelFactory.cpp
    M src/PipelineReader.cpp
    M src/PluginManager.cpp
    M src/PointTable.cpp
    M src/PointView.cpp
    M src/SpatialReference.cpp
    M src/Stage.cpp
    M src/StageFactory.cpp
    M src/pdal_config.cpp
    M src/plang/Environment.cpp
    A test/data/ilvis2/ILVIS2_TEST_FILE.TXT
    A test/data/las/test1_4.las
    R test/data/logs/logtest.txt
    A test/data/png/autzen-height.png
    R test/data/pointbuffer/metadata.txt
    A test/data/sbet/autzen_trim.sbet
    M test/unit/CMakeLists.txt
    M test/unit/LogTest.cpp
    M test/unit/PointTableTest.cpp
    M test/unit/PointViewTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    A test/unit/StreamingTest.cpp
    A test/unit/apps/RandomTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/DecimationFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/RangeFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/buffer/BufferTest.cpp
    A test/unit/io/gdal/GDALReaderTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin' into python-extension-fixups
  Commit: 1e6d077bf5b97c3d33e456ac694cc81e67ded35f
      https://github.com/PDAL/PDAL/commit/1e6d077bf5b97c3d33e456ac694cc81e67ded35f
  Changed paths:
    M python/setup.py
  Log Message:
  Merge pull request #1059 from PDAL/python-extension-fixups
Compare: https://github.com/PDAL/PDAL/compare/00ed45211eca...1e6d077bf5b9
More information about the pdal-commits mailing list
