[pdal-commits] [PDAL/PDAL] 6f8d6b: Add range filter
GitHub noreply at github.com
Thu Feb 5 09:01:57 PST 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 6f8d6b20ae3e32fc5db25517033f2bb4cb3f0d31
      https://github.com/PDAL/PDAL/commit/6f8d6b20ae3e32fc5db25517033f2bb4cb3f0d31
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-02-05 (Thu, 05 Feb 2015)
  Changed paths:
    A doc/stages/filters.range.rst
    M doc/stages/index.rst
    M filters/CMakeLists.txt
    A filters/range/CMakeLists.txt
    A filters/range/RangeFilter.cpp
    A filters/range/RangeFilter.hpp
    M include/pdal/Filters.hpp
    M src/StageFactory.cpp
    A test/data/filters/range_classification.xml.in
    A test/data/filters/range_z.xml.in
    A test/data/filters/range_z_classification.xml.in
    M test/unit/CMakeLists.txt
    M test/unit/apps/pcpipelineTest.cpp
    A test/unit/filters/RangeFilterTest.cpp
  Log Message:
  Add range filter
This could obviously be more complicated, but as it is, I think it's a nice
alternative to the Python filters. The documentation, sample pipeline, and unit
tests should adequately explain the current feature set (basically
multi-dimensional, min/max/exact value criteria for passing points through to
the output buffer).
  Commit: 2fade5c05386c62f88db3e3d0629beaf52b4761a
      https://github.com/PDAL/PDAL/commit/2fade5c05386c62f88db3e3d0629beaf52b4761a
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
  Log Message:
  Merge pull request #743 from PDAL/add-passthrough-filter
Add passthrough filter
Compare: https://github.com/PDAL/PDAL/compare/a8240e4ce769...2fade5c05386
More information about the pdal-commits mailing list
