[pdal-commits] [PDAL/PDAL] db90c5: changed parameter m_RADIUS_SQ to m_RADIUS then pas...
GitHub noreply at github.com
Wed Feb 18 12:36:04 PST 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: db90c56260c524b1800fd3f79ab71f2dedeee440
      https://github.com/PDAL/PDAL/commit/db90c56260c524b1800fd3f79ab71f2dedeee440
  Author: Matthew Hanson <mhanson at appliedgeosolutions.com>
  Date:   2015-02-18 (Wed, 18 Feb 2015)
  Changed paths:
    M plugins/p2g/io/P2gWriter.cpp
    M plugins/p2g/io/P2gWriter.hpp
  Log Message:
  changed parameter m_RADIUS_SQ to m_RADIUS then pass in the square to OutCoreInterp
  Commit: 1c6683b7598f7a55cfb9be3866c2dbfe6cb2f3fb
      https://github.com/PDAL/PDAL/commit/1c6683b7598f7a55cfb9be3866c2dbfe6cb2f3fb
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
  Log Message:
  Merge pull request #766 from matthewhanson/fix_p2g_radius
changed parameter m_RADIUS_SQ to m_RADIUS then pass in the square to Out...
Compare: https://github.com/PDAL/PDAL/compare/7421cf6aa681...1c6683b7598f
More information about the pdal-commits mailing list
