[pdal-commits] [PDAL/PDAL] 76a82b: Add lasdump and separate build dependencies.
GitHub noreply at github.com
Thu Jan 8 13:09:23 PST 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 76a82b61fdeadd8f16092873d67bc39168dcef45
      https://github.com/PDAL/PDAL/commit/76a82b61fdeadd8f16092873d67bc39168dcef45
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-01-08 (Thu, 08 Jan 2015)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    A cmake/boost.cmake
    A cmake/common.cmake
    A cmake/compiler_options.cmake
    A cmake/directories.cmake
    A cmake/gdal.cmake
    A cmake/geos.cmake
    A cmake/geotiff.cmake
    A cmake/hdf5.cmake
    A cmake/iconv.cmake
    A cmake/laszip.cmake
    A cmake/lazperf.cmake
    A cmake/libraries.cmake
    A cmake/libxml2.cmake
    A cmake/macros.cmake
    A cmake/modules.cmake
    M cmake/modules/FindLASzip.cmake
    A cmake/nitro.cmake
    R cmake/pdal_options.cmake
    R cmake/pdal_targets.cmake
    R cmake/pdal_utils.cmake
    A cmake/policies.cmake
    A cmake/postgres.cmake
    A cmake/python.cmake
    A cmake/sqlite.cmake
    A cmake/threads.cmake
    A cmake/unix_compiler_options.cmake
    A cmake/win32_compiler_options.cmake
    A cmake/zlib.cmake
    M filters/chipper/CMakeLists.txt
    M filters/chipper/ChipperFilter.cpp
    M filters/colorization/CMakeLists.txt
    M filters/colorization/ColorizationFilter.cpp
    M filters/crop/CMakeLists.txt
    M filters/decimation/CMakeLists.txt
    M filters/decimation/DecimationFilter.cpp
    M filters/ferry/CMakeLists.txt
    M filters/ferry/FerryFilter.cpp
    M filters/merge/CMakeLists.txt
    M filters/mortonorder/CMakeLists.txt
    M filters/mortonorder/MortonOrderFilter.cpp
    M filters/reprojection/CMakeLists.txt
    M filters/reprojection/ReprojectionFilter.cpp
    M filters/sort/CMakeLists.txt
    M filters/sort/SortFilter.hpp
    M filters/splitter/CMakeLists.txt
    M filters/splitter/SplitterFilter.cpp
    M filters/stats/CMakeLists.txt
    M filters/stats/StatsFilter.cpp
    R include/pdal/Bounds.hpp
    M include/pdal/Drivers.hpp
    M include/pdal/Filters.hpp
    M include/pdal/IStream.hpp
    M include/pdal/Kernels.hpp
    M include/pdal/Metadata.hpp
    M include/pdal/PointBuffer.hpp
    M include/pdal/pdal_export.hpp
    M include/pdal/plang/BufferedInvocation.hpp
    M include/pdal/plang/Invocation.hpp
    M include/pdal/plang/PythonEnvironment.hpp
    M include/pdal/plang/Script.hpp
    M io/bpf/BpfHeader.cpp
    M io/bpf/BpfReader.cpp
    M io/bpf/CMakeLists.txt
    M io/faux/CMakeLists.txt
    M io/faux/FauxReader.cpp
    M io/las/CMakeLists.txt
    M io/las/LasHeader.cpp
    M io/las/LasHeader.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M io/las/LasWriter.cpp
    M io/las/LasWriter.hpp
    M io/las/SummaryData.cpp
    M io/las/SummaryData.hpp
    M io/las/VariableLengthRecord.cpp
    M io/las/ZipPoint.cpp
    M io/qfit/CMakeLists.txt
    M io/qfit/QfitReader.cpp
    M io/sbet/CMakeLists.txt
    M io/sbet/SbetCommon.cpp
    M io/sbet/SbetReader.cpp
    M io/sbet/SbetReader.hpp
    M io/sbet/SbetWriter.cpp
    M io/sbet/SbetWriter.hpp
    M io/terrasolid/CMakeLists.txt
    M io/terrasolid/TerrasolidReader.cpp
    M io/text/CMakeLists.txt
    M io/text/TextWriter.cpp
    M kernels/CMakeLists.txt
    M kernels/Kernel.cpp
    M kernels/delta/CMakeLists.txt
    M kernels/diff/CMakeLists.txt
    M kernels/info/CMakeLists.txt
    M kernels/info/InfoKernel.cpp
    M kernels/pipeline/CMakeLists.txt
    M kernels/random/CMakeLists.txt
    M kernels/sort/CMakeLists.txt
    M kernels/sort/SortKernel.cpp
    M kernels/translate/CMakeLists.txt
    M kernels/translate/TranslateKernel.cpp
    M plugins/attribute/CMakeLists.txt
    M plugins/greyhound/CMakeLists.txt
    M plugins/hexbin/CMakeLists.txt
    M plugins/icebridge/CMakeLists.txt
    M plugins/mrsid/CMakeLists.txt
    M plugins/nitf/CMakeLists.txt
    M plugins/nitf/io/NitfReader.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/NitfWriter.hpp
    M plugins/oci/CMakeLists.txt
    M plugins/p2g/CMakeLists.txt
    M plugins/pcl/CMakeLists.txt
    M plugins/pgpointcloud/CMakeLists.txt
    M plugins/pgpointcloud/test/Pgtest-Support.hpp.in
    M plugins/python/CMakeLists.txt
    M plugins/python/test/PredicateFilterTest.cpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M plugins/rxp/CMakeLists.txt
    M plugins/sqlite/CMakeLists.txt
    R src/Bounds.cpp
    M src/CMakeLists.txt
    M src/plang/BufferedInvocation.cpp
    M src/plang/Invocation.cpp
    M src/plang/PythonEnvironment.cpp
    M src/plang/Redirector.cpp
    M src/plang/Redirector.hpp
    M src/plang/Script.cpp
    M test/unit/io/las/LasWriterTest.cpp
    R test/unit/runsingly.sh
    A tools/CMakeLists.txt
    A tools/lasdump/CMakeLists.txt
    A tools/lasdump/Dumper.cpp
    A tools/lasdump/Dumper.hpp
    A tools/lasdump/Header.cpp
    A tools/lasdump/Header.hpp
    A tools/lasdump/Lasdump.hpp
    A tools/lasdump/Vlr.hpp
    A util/Bounds.cpp
    A util/Bounds.hpp
    A util/CMakeLists.txt
    A util/README
    A util/pdal
    M vendor/gtest-1.7.0/include/gtest/internal/gtest-port.h
  Log Message:
More information about the pdal-commits mailing list
