[pdal-commits] [PDAL/PDAL] e83f8c: Reorg library files
GitHub noreply at github.com
Fri Jan 23 11:09:26 PST 2015
  Branch: refs/heads/mimic-llvm-and-clang
  Home:   https://github.com/PDAL/PDAL
  Commit: e83f8c13f852687f13bb12ce6d3839e3990c56d5
      https://github.com/PDAL/PDAL/commit/e83f8c13f852687f13bb12ce6d3839e3990c56d5
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-01-23 (Fri, 23 Jan 2015)
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M cmake/directories.cmake
    R filters/CMakeLists.txt
    R filters/chipper/CMakeLists.txt
    R filters/chipper/ChipperFilter.cpp
    R filters/chipper/ChipperFilter.hpp
    R filters/colorization/CMakeLists.txt
    R filters/colorization/ColorizationFilter.cpp
    R filters/colorization/ColorizationFilter.hpp
    R filters/crop/CMakeLists.txt
    R filters/crop/CropFilter.cpp
    R filters/crop/CropFilter.hpp
    R filters/decimation/CMakeLists.txt
    R filters/decimation/DecimationFilter.cpp
    R filters/decimation/DecimationFilter.hpp
    R filters/ferry/CMakeLists.txt
    R filters/ferry/FerryFilter.cpp
    R filters/ferry/FerryFilter.hpp
    R filters/merge/CMakeLists.txt
    R filters/merge/MergeFilter.hpp
    R filters/mortonorder/CMakeLists.txt
    R filters/mortonorder/MortonOrderFilter.cpp
    R filters/mortonorder/MortonOrderFilter.hpp
    R filters/reprojection/CMakeLists.txt
    R filters/reprojection/ReprojectionFilter.cpp
    R filters/reprojection/ReprojectionFilter.hpp
    R filters/sort/CMakeLists.txt
    R filters/sort/SortFilter.hpp
    R filters/splitter/CMakeLists.txt
    R filters/splitter/SplitterFilter.cpp
    R filters/splitter/SplitterFilter.hpp
    R filters/stats/CMakeLists.txt
    R filters/stats/StatsFilter.cpp
    R filters/stats/StatsFilter.hpp
    R filters/transformation/CMakeLists.txt
    R filters/transformation/TransformationFilter.cpp
    R filters/transformation/TransformationFilter.hpp
    A include/pdal/Kernel.hpp
    A include/pdal/KernelFactory.hpp
    A include/pdal/KernelInfo.hpp
    A include/pdal/KernelSupport.hpp
    M include/pdal/PDALUtils.hpp
    R io/CMakeLists.txt
    R io/bpf/BpfCompressor.cpp
    R io/bpf/BpfCompressor.hpp
    R io/bpf/BpfHeader.cpp
    R io/bpf/BpfHeader.hpp
    R io/bpf/BpfReader.cpp
    R io/bpf/BpfReader.hpp
    R io/bpf/BpfWriter.cpp
    R io/bpf/BpfWriter.hpp
    R io/bpf/CMakeLists.txt
    R io/faux/CMakeLists.txt
    R io/faux/FauxReader.cpp
    R io/faux/FauxReader.hpp
    R io/las/CMakeLists.txt
    R io/las/GeotiffSupport.cpp
    R io/las/GeotiffSupport.hpp
    R io/las/LasError.hpp
    R io/las/LasHeader.cpp
    R io/las/LasHeader.hpp
    R io/las/LasReader.cpp
    R io/las/LasReader.hpp
    R io/las/LasWriter.cpp
    R io/las/LasWriter.hpp
    R io/las/SummaryData.cpp
    R io/las/SummaryData.hpp
    R io/las/VariableLengthRecord.cpp
    R io/las/VariableLengthRecord.hpp
    R io/las/ZipPoint.cpp
    R io/las/ZipPoint.hpp
    R io/qfit/CMakeLists.txt
    R io/qfit/QfitReader.cpp
    R io/qfit/QfitReader.hpp
    R io/sbet/CMakeLists.txt
    R io/sbet/SbetCommon.cpp
    R io/sbet/SbetCommon.hpp
    R io/sbet/SbetReader.cpp
    R io/sbet/SbetReader.hpp
    R io/sbet/SbetWriter.cpp
    R io/sbet/SbetWriter.hpp
    R io/terrasolid/CMakeLists.txt
    R io/terrasolid/TerrasolidReader.cpp
    R io/terrasolid/TerrasolidReader.hpp
    R io/text/CMakeLists.txt
    R io/text/TextWriter.cpp
    R io/text/TextWriter.hpp
    R kernels/CMakeLists.txt
    R kernels/Kernel.cpp
    R kernels/Kernel.hpp
    R kernels/KernelFactory.cpp
    R kernels/KernelFactory.hpp
    R kernels/KernelInfo.cpp
    R kernels/KernelInfo.hpp
    R kernels/KernelSupport.cpp
    R kernels/KernelSupport.hpp
    R kernels/delta/CMakeLists.txt
    R kernels/delta/DeltaKernel.cpp
    R kernels/delta/DeltaKernel.hpp
    R kernels/diff/CMakeLists.txt
    R kernels/diff/DiffKernel.cpp
    R kernels/diff/DiffKernel.hpp
    R kernels/info/CMakeLists.txt
    R kernels/info/InfoKernel.cpp
    R kernels/info/InfoKernel.hpp
    R kernels/pipeline/CMakeLists.txt
    R kernels/pipeline/PipelineKernel.cpp
    R kernels/pipeline/PipelineKernel.hpp
    R kernels/random/CMakeLists.txt
    R kernels/random/RandomKernel.cpp
    R kernels/random/RandomKernel.hpp
    R kernels/sort/CMakeLists.txt
    R kernels/sort/SortKernel.cpp
    R kernels/sort/SortKernel.hpp
    R kernels/translate/CMakeLists.txt
    R kernels/translate/TranslateKernel.cpp
    R kernels/translate/TranslateKernel.hpp
    M plugins/mrsid/io/MrsidReader.hpp
    M plugins/oci/io/OciCommon.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/oci/io/OciWriter.hpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/GroundKernel.hpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/PCLKernel.hpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.hpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M plugins/pcl/kernel/ViewKernel.hpp
    M src/CMakeLists.txt
    A src/Kernel.cpp
    A src/KernelFactory.cpp
    A src/KernelInfo.cpp
    A src/KernelSupport.cpp
    A src/filters/CMakeLists.txt
    A src/filters/chipper/CMakeLists.txt
    A src/filters/chipper/ChipperFilter.cpp
    A src/filters/chipper/ChipperFilter.hpp
    A src/filters/colorization/CMakeLists.txt
    A src/filters/colorization/ColorizationFilter.cpp
    A src/filters/colorization/ColorizationFilter.hpp
    A src/filters/crop/CMakeLists.txt
    A src/filters/crop/CropFilter.cpp
    A src/filters/crop/CropFilter.hpp
    A src/filters/decimation/CMakeLists.txt
    A src/filters/decimation/DecimationFilter.cpp
    A src/filters/decimation/DecimationFilter.hpp
    A src/filters/ferry/CMakeLists.txt
    A src/filters/ferry/FerryFilter.cpp
    A src/filters/ferry/FerryFilter.hpp
    A src/filters/merge/CMakeLists.txt
    A src/filters/merge/MergeFilter.hpp
    A src/filters/mortonorder/CMakeLists.txt
    A src/filters/mortonorder/MortonOrderFilter.cpp
    A src/filters/mortonorder/MortonOrderFilter.hpp
    A src/filters/reprojection/CMakeLists.txt
    A src/filters/reprojection/ReprojectionFilter.cpp
    A src/filters/reprojection/ReprojectionFilter.hpp
    A src/filters/sort/CMakeLists.txt
    A src/filters/sort/SortFilter.hpp
    A src/filters/splitter/CMakeLists.txt
    A src/filters/splitter/SplitterFilter.cpp
    A src/filters/splitter/SplitterFilter.hpp
    A src/filters/stats/CMakeLists.txt
    A src/filters/stats/StatsFilter.cpp
    A src/filters/stats/StatsFilter.hpp
    A src/filters/transformation/CMakeLists.txt
    A src/filters/transformation/TransformationFilter.cpp
    A src/filters/transformation/TransformationFilter.hpp
    A src/io/CMakeLists.txt
    A src/io/bpf/BpfCompressor.cpp
    A src/io/bpf/BpfCompressor.hpp
    A src/io/bpf/BpfHeader.cpp
    A src/io/bpf/BpfHeader.hpp
    A src/io/bpf/BpfReader.cpp
    A src/io/bpf/BpfReader.hpp
    A src/io/bpf/BpfWriter.cpp
    A src/io/bpf/BpfWriter.hpp
    A src/io/bpf/CMakeLists.txt
    A src/io/faux/CMakeLists.txt
    A src/io/faux/FauxReader.cpp
    A src/io/faux/FauxReader.hpp
    A src/io/las/CMakeLists.txt
    A src/io/las/GeotiffSupport.cpp
    A src/io/las/GeotiffSupport.hpp
    A src/io/las/LasError.hpp
    A src/io/las/LasHeader.cpp
    A src/io/las/LasHeader.hpp
    A src/io/las/LasReader.cpp
    A src/io/las/LasReader.hpp
    A src/io/las/LasWriter.cpp
    A src/io/las/LasWriter.hpp
    A src/io/las/SummaryData.cpp
    A src/io/las/SummaryData.hpp
    A src/io/las/VariableLengthRecord.cpp
    A src/io/las/VariableLengthRecord.hpp
    A src/io/las/ZipPoint.cpp
    A src/io/las/ZipPoint.hpp
    A src/io/qfit/CMakeLists.txt
    A src/io/qfit/QfitReader.cpp
    A src/io/qfit/QfitReader.hpp
    A src/io/sbet/CMakeLists.txt
    A src/io/sbet/SbetCommon.cpp
    A src/io/sbet/SbetCommon.hpp
    A src/io/sbet/SbetReader.cpp
    A src/io/sbet/SbetReader.hpp
    A src/io/sbet/SbetWriter.cpp
    A src/io/sbet/SbetWriter.hpp
    A src/io/terrasolid/CMakeLists.txt
    A src/io/terrasolid/TerrasolidReader.cpp
    A src/io/terrasolid/TerrasolidReader.hpp
    A src/io/text/CMakeLists.txt
    A src/io/text/TextWriter.cpp
    A src/io/text/TextWriter.hpp
    A src/kernels/CMakeLists.txt
    A src/kernels/delta/CMakeLists.txt
    A src/kernels/delta/DeltaKernel.cpp
    A src/kernels/delta/DeltaKernel.hpp
    A src/kernels/diff/CMakeLists.txt
    A src/kernels/diff/DiffKernel.cpp
    A src/kernels/diff/DiffKernel.hpp
    A src/kernels/info/CMakeLists.txt
    A src/kernels/info/InfoKernel.cpp
    A src/kernels/info/InfoKernel.hpp
    A src/kernels/pipeline/CMakeLists.txt
    A src/kernels/pipeline/PipelineKernel.cpp
    A src/kernels/pipeline/PipelineKernel.hpp
    A src/kernels/random/CMakeLists.txt
    A src/kernels/random/RandomKernel.cpp
    A src/kernels/random/RandomKernel.hpp
    A src/kernels/sort/CMakeLists.txt
    A src/kernels/sort/SortKernel.cpp
    A src/kernels/sort/SortKernel.hpp
    A src/kernels/translate/CMakeLists.txt
    A src/kernels/translate/TranslateKernel.cpp
    A src/kernels/translate/TranslateKernel.hpp
    A src/util/Bounds.cpp
    A src/util/CMakeLists.txt
    M test/unit/CMakeLists.txt
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/DecimationFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M test/unit/filters/SortFilterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
    M test/unit/filters/TransformationFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/buffer/BufferTest.cpp
    M test/unit/io/faux/FauxReaderTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
    M test/unit/io/qfit/QFITReaderTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
    M test/unit/io/sbet/SbetWriterTest.cpp
    R util/Bounds.cpp
    R util/CMakeLists.txt
    R util/README
    R util/pdal
  Log Message:
  Reorg library files
Public headers remain in ./include/pdal.
All filters, IO, kernels move from top-level back to ./src. The key difference
between this and the original layout is that the headers for these capabilities
are now treated as local/private headers and are not installed as part of the
public API.
Kernel class (along with KernelInfo, KernelFactory, KernelSupport) move into
the public API.
More information about the pdal-commits mailing list
