[pdal-commits] [PDAL/PDAL] 4db692: Fixup pdal options.
GitHub noreply at github.com
Wed Jul 1 07:36:09 PDT 2015
  Branch: refs/heads/grid-1.4.0
  Home:   https://github.com/PDAL/PDAL
  Commit: 4db692a32f5dff928e4c229346f2791f1448f146
      https://github.com/PDAL/PDAL/commit/4db692a32f5dff928e4c229346f2791f1448f146
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-06-25 (Thu, 25 Jun 2015)
  Changed paths:
    M apps/pdal.cpp
    M cmake/macros.cmake
    M doc/docs.rst
    M doc/index.rst
    M doc/tutorial/overview.rst
    M include/pdal/Utils.hpp
    M include/pdal/pdal_config.hpp
    M io/las/LasWriter.cpp
    M src/Utils.cpp
    M src/pdal_config.cpp
    M test/unit/UtilsTest.cpp
  Log Message:
  Fixup pdal options.
  Commit: aa558c965cd2af0b8abfe2cd8502cad9679ab9bb
      https://github.com/PDAL/PDAL/commit/aa558c965cd2af0b8abfe2cd8502cad9679ab9bb
  Changed paths:
    M include/pdal/SpatialReference.hpp
  Log Message:
  Remove unimplemented function definition.
Close #946
  Commit: 1f439e25d5fab80ac4655f2134e6356d860c41a9
      https://github.com/PDAL/PDAL/commit/1f439e25d5fab80ac4655f2134e6356d860c41a9
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Changed paths:
    M scripts/ci/before_install.sh
    M scripts/ci/script.sh
  Log Message:
  Enable hexbin tests on travis
The travis package is called "hexboundary", because there's already a
debian packaged named hexbin.
  Commit: 4298d12c9bf97a12f1a1efa1021fc6fc1e17df26
      https://github.com/PDAL/PDAL/commit/4298d12c9bf97a12f1a1efa1021fc6fc1e17df26
  Changed paths:
    M plugins/hexbin/test/HexbinFilterTest.cpp
  Log Message:
  Remove outfile check in the hexbin test
Hexbin appears to be non-deterministic in the ordering of its output
hexes, and so this test was failing on Ubuntu precise even though the
output polygons appeared correct to visual inspection (just in a
different order).
  Commit: 5075b6e7f3cf26aa8bc8c35d6cacc62ef16fa03d
      https://github.com/PDAL/PDAL/commit/5075b6e7f3cf26aa8bc8c35d6cacc62ef16fa03d
  Changed paths:
    M doc/apps.rst
    M kernels/info/InfoKernel.cpp
  Log Message:
  Allow a count to be provided as part of `pdal info --query`.
Close #922
  Commit: 5207a58820626ca2051d7ec802829f46105939de
      https://github.com/PDAL/PDAL/commit/5207a58820626ca2051d7ec802829f46105939de
  Changed paths:
  Log Message:
  Merge pull request #948 from gadomski/hexboundary-on-travis
Hexer on travis
  Commit: 747426c4aea81637f3e0bf71a558c2608a98337e
      https://github.com/PDAL/PDAL/commit/747426c4aea81637f3e0bf71a558c2608a98337e
  Date:   2015-06-26 (Fri, 26 Jun 2015)
  Changed paths:
    M CMakeLists.txt
    A cmake/modules/FindMatlab.cmake
    M doc/stages/index.rst
    A doc/stages/writers.matlab.rst
    M plugins/CMakeLists.txt
    A plugins/matlab/CMakeLists.txt
    A plugins/matlab/io/MatlabWriter.cpp
    A plugins/matlab/io/MatlabWriter.hpp
    A plugins/matlab/test/MatlabWriterTest.cpp
    M src/StageFactory.cpp
  Log Message:
  Add a matlab writer
It's very dumb. But it works.
Fixes #907.
  Commit: a03493153d05e7f528f691e7c3af9e94c8bfeff7
      https://github.com/PDAL/PDAL/commit/a03493153d05e7f528f691e7c3af9e94c8bfeff7
  Author: Connor Manning <connor at hobu.co>
  Changed paths:
  Log Message:
  Remove extraneous quotation mark.
  Commit: 3db340f141691861d332594a0d8312ad15b0ea1a
      https://github.com/PDAL/PDAL/commit/3db340f141691861d332594a0d8312ad15b0ea1a
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #949 from gadomski/issues/907-matlab-writer
Add a matlab writer
  Commit: b5e548087dc081c705ce0394a06d28cca08cb09f
      https://github.com/PDAL/PDAL/commit/b5e548087dc081c705ce0394a06d28cca08cb09f
  Changed paths:
    M filters/reprojection/ReprojectionFilter.cpp
    M filters/transformation/TransformationFilter.cpp
    M include/pdal/Kernel.hpp
    M include/pdal/Options.hpp
    M include/pdal/UserCallback.hpp
    M include/pdal/pdal_error.hpp
    M include/pdal/pdal_internal.hpp
    M include/pdal/pdal_types.hpp
    M include/pdal/plang/PythonEnvironment.hpp
    M io/las/LasReader.cpp
    M io/las/SummaryData.cpp
    M io/optech/OptechCommon.hpp
    M io/ply/PlyReader.cpp
    M io/text/TextWriter.cpp
    M plugins/greyhound/io/Exchanges.cpp
    M plugins/greyhound/io/WebSocketClient.cpp
    M plugins/icebridge/io/Hdf5Handler.cpp
    M plugins/icebridge/io/Hdf5Handler.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/pgpointcloud/io/PgCommon.hpp
    M plugins/python/filters/PredicateFilter.cpp
    M plugins/python/test/PredicateFilterTest.cpp
    M plugins/rxp/io/RxpReader.cpp
    M plugins/rxp/test/RxpReaderTest.cpp
    M plugins/sqlite/io/SQLiteCommon.hpp
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M src/GDALUtils.cpp
    M src/Options.cpp
    M src/PipelineReader.cpp
    M src/plang/Invocation.cpp
    M src/plang/PythonEnvironment.cpp
    M src/util/FileUtils.cpp
    M test/unit/OptionsTest.cpp
    M test/unit/UserCallbackTest.cpp
    M test/unit/filters/TransformationFilterTest.cpp
    M test/unit/plang/PLangTest.cpp
  Log Message:
  Simplify exception hierarchy.
Close #12
  Commit: 3ee5b839dc7da76afb543465ca6e69c7d55de684
      https://github.com/PDAL/PDAL/commit/3ee5b839dc7da76afb543465ca6e69c7d55de684
  Changed paths:
    R include/pdal/pdal_error.hpp
    M src/CMakeLists.txt
  Log Message:
  Remove pdal_error.
  Commit: 5aeb6b4b3f7ee3a2be5b4fffe9fcdbdf322211c3
      https://github.com/PDAL/PDAL/commit/5aeb6b4b3f7ee3a2be5b4fffe9fcdbdf322211c3
  Date:   2015-06-30 (Tue, 30 Jun 2015)
  Changed paths:
    M io/bpf/BpfWriter.cpp
    M io/bpf/BpfWriter.hpp
    M test/unit/io/bpf/BPFTest.cpp
  Log Message:
  Add support for writing extra BPF header data.
  Commit: 7757f672f60f5e966b3334df1e63b53ad083b4dc
      https://github.com/PDAL/PDAL/commit/7757f672f60f5e966b3334df1e63b53ad083b4dc
  Changed paths:
    M doc/stages/writers.bpf.rst
  Log Message:
  BPF writer header_data option doc.
  Commit: 57737a302e2e2cf76db7cec44b890d580bc0b8b6
      https://github.com/PDAL/PDAL/commit/57737a302e2e2cf76db7cec44b890d580bc0b8b6
  Date:   2015-07-01 (Wed, 01 Jul 2015)
  Changed paths:
    M io/las/LasWriter.hpp
    M io/sbet/SbetWriter.hpp
    M plugins/matlab/io/MatlabWriter.hpp
    M plugins/p2g/io/P2gWriter.hpp
    M plugins/pcl/io/PCLVisualizer.hpp
    M plugins/pcl/io/PcdWriter.hpp
  Log Message:
  Minor clean-up.
  Commit: b9fcb740ecfbcabe2c9000b999091f2a9ef2a0a8
      https://github.com/PDAL/PDAL/commit/b9fcb740ecfbcabe2c9000b999091f2a9ef2a0a8
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M doc/apps.rst
    M doc/docs.rst
    M doc/index.rst
    M src/GDALUtils.cpp
    M src/Options.cpp
    M src/Utils.cpp
  Log Message:
  Merge branch 'master' into grid-1.4.0
Compare: https://github.com/PDAL/PDAL/compare/9842033914bf...b9fcb740ecfb
More information about the pdal-commits mailing list
