[pdal-commits] [PDAL/PDAL] 765c0a: Turn PCL on in Travis as an optional component
GitHub noreply at github.com
Thu Jul 16 11:35:39 PDT 2015
  Branch: refs/heads/grid-1.4.0
  Home:   https://github.com/PDAL/PDAL
  Commit: 765c0a0802ca260341ab591bf68e635cb4423120
      https://github.com/PDAL/PDAL/commit/765c0a0802ca260341ab591bf68e635cb4423120
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-06-19 (Fri, 19 Jun 2015)
  Changed paths:
    M scripts/ci/before_install.sh
    M scripts/ci/script.sh
  Log Message:
  Commit: 1b8c75b0d40f0f0403298b0a57ac475d4f5a725a
      https://github.com/PDAL/PDAL/commit/1b8c75b0d40f0f0403298b0a57ac475d4f5a725a
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-07-05 (Sun, 05 Jul 2015)
  Changed paths:
  Log Message:
  Merge pull request #943 from PDAL/pcl-travis
  Commit: c378b6c9fba0fa55ac1b742278a98c86373343e4
      https://github.com/PDAL/PDAL/commit/c378b6c9fba0fa55ac1b742278a98c86373343e4
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-07-06 (Mon, 06 Jul 2015)
  Changed paths:
    M io/las/LasWriter.cpp
    M io/las/LasWriter.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/NitfWriter.hpp
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
  Make LasWriter a FlexWriter.
  Commit: 5d4f28ac074cec54934a10657ffaed329d806fbc
      https://github.com/PDAL/PDAL/commit/5d4f28ac074cec54934a10657ffaed329d806fbc
  Changed paths:
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.las.rst
  Log Message:
  Add documentation for LasWriter as FlexWriter.
  Commit: 3cf759b2e5dac96c71c36a68b5fdb3c7798ef4d2
      https://github.com/PDAL/PDAL/commit/3cf759b2e5dac96c71c36a68b5fdb3c7798ef4d2
  Date:   2015-07-07 (Tue, 07 Jul 2015)
  Changed paths:
    M io/las/LasReader.cpp
    M plugins/nitf/io/MetadataReader.cpp
    M plugins/nitf/io/NitfFile.cpp
    M plugins/nitf/io/NitfReader.cpp
    M plugins/nitf/test/NitfWriterTest.cpp
  Log Message:
  Add tests for NitfWriter as FlexWriter.
  Commit: 835a7d7a1e92eebae60b8aec45c10aafebe2b3c8
      https://github.com/PDAL/PDAL/commit/835a7d7a1e92eebae60b8aec45c10aafebe2b3c8
  Date:   2015-07-08 (Wed, 08 Jul 2015)
  Changed paths:
    M doc/stages/writers.nitf.rst
  Log Message:
  Update NitfWriter documentation.
Remove dead code.
  Commit: d880913e032a14476061e56ddfdac0fd5d634c28
      https://github.com/PDAL/PDAL/commit/d880913e032a14476061e56ddfdac0fd5d634c28
  Date:   2015-07-10 (Fri, 10 Jul 2015)
  Changed paths:
    M kernels/tindex/TIndexKernel.cpp
  Log Message:
  Fix comment typo.
  Commit: b62a05b3b654db332d452f09218b85bb41822cde
      https://github.com/PDAL/PDAL/commit/b62a05b3b654db332d452f09218b85bb41822cde
  Changed paths:
    M test/unit/filters/ReprojectionFilterTest.cpp
  Log Message:
  Fix GEOTIFF include directive.
  Commit: 95f6d9447bf90f28d6e037bfbc017d8f88eb579d
      https://github.com/PDAL/PDAL/commit/95f6d9447bf90f28d6e037bfbc017d8f88eb579d
  Changed paths:
  Log Message:
  Fix repro filter test now that GEOTIFF macro is fixed.
  Commit: d7312644c3180a1e68346f6cced5674f2b098155
      https://github.com/PDAL/PDAL/commit/d7312644c3180a1e68346f6cced5674f2b098155
  Changed paths:
    M io/las/GeotiffSupport.cpp
  Log Message:
  Remove dead code.
  Commit: 2af45ade3b219459749e7ec2db7a29ae6ffb1853
      https://github.com/PDAL/PDAL/commit/2af45ade3b219459749e7ec2db7a29ae6ffb1853
  Date:   2015-07-13 (Mon, 13 Jul 2015)
  Changed paths:
    M doc/stages/filters.stats.rst
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    M test/unit/filters/StatsFilterTest.cpp
  Log Message:
  Add "count" option to stats filter.
Close #955
  Commit: 3363eb800219f1163879caf068fc3551f3749ecc
      https://github.com/PDAL/PDAL/commit/3363eb800219f1163879caf068fc3551f3749ecc
  Changed paths:
    M kernels/info/InfoKernel.cpp
  Log Message:
  Allow info kernel to take extra command-line options.
  Commit: 6a676e94ac9caa2c0d8f48ee967ade474a268f92
      https://github.com/PDAL/PDAL/commit/6a676e94ac9caa2c0d8f48ee967ade474a268f92
  Changed paths:
  Log Message:
  Fix writing of point formats 6-10 to match spec.
  Commit: 38f77ae3b71a85768342d1ea6dbdca6b16760a2a
      https://github.com/PDAL/PDAL/commit/38f77ae3b71a85768342d1ea6dbdca6b16760a2a
  Date:   2015-07-14 (Tue, 14 Jul 2015)
  Changed paths:
  Log Message:
  Fix 1.4 scan angle.
  Commit: 813dd0031846c469000950dd2e2cc36b88aa11a5
      https://github.com/PDAL/PDAL/commit/813dd0031846c469000950dd2e2cc36b88aa11a5
  Changed paths:
    M test/unit/CompressionTest.cpp
  Log Message:
  Update CompressionTest for new schema.
  Commit: 82bfafc137b799df9528bb7a02c123edd05eca0d
      https://github.com/PDAL/PDAL/commit/82bfafc137b799df9528bb7a02c123edd05eca0d
  Date:   2015-07-15 (Wed, 15 Jul 2015)
  Changed paths:
    M include/pdal/Metadata.hpp
    M include/pdal/Options.hpp
    R include/pdal/Utils.hpp
    A include/pdal/util/Utils.hpp
    M io/las/LasError.hpp
    M io/las/LasHeader.cpp
    M io/las/LasUtils.cpp
    M plugins/oci/io/OciCommon.cpp
    M plugins/pgpointcloud/io/PgCommon.hpp
    M src/CMakeLists.txt
    M src/GDALUtils.cpp
    M src/KernelFactory.cpp
    M src/KernelSupport.cpp
    M src/Log.cpp
    M src/PipelineManager.cpp
    M src/PluginManager.cpp
    M src/PointLayout.cpp
    M src/QuadIndex.cpp
    M src/SpatialReference.cpp
    M src/StageFactory.cpp
    R src/Utils.cpp
    M src/pdal_config.cpp
    M src/util/CMakeLists.txt
    M src/util/FileUtils.cpp
    A src/util/Utils.cpp
    M test/unit/FileUtilsTest.cpp
    M test/unit/Support.hpp
    M test/unit/SupportTest.cpp
    M test/unit/UtilsTest.cpp
    M test/unit/apps/MergeTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
  Log Message:
  Move Utils.XX to util subdir.
  Commit: be086e00aa2cd2bcc967a2dc731a197c62c1481d
      https://github.com/PDAL/PDAL/commit/be086e00aa2cd2bcc967a2dc731a197c62c1481d
  Changed paths:
    M include/pdal/PDALUtils.hpp
    M kernels/delta/DeltaKernel.cpp
    M kernels/diff/DiffKernel.cpp
    M src/Kernel.cpp
    M src/Options.cpp
    M src/PDALUtils.cpp
    M src/PipelineWriter.cpp
    M test/unit/BoundsTest.cpp
    M test/unit/OptionsTest.cpp
    M test/unit/PDALUtilsTest.cpp
    M test/unit/PointViewTest.cpp
  Log Message:
  Put all utilities in the same namespace.
  Commit: e4913f75be8590fc090362405aa6ecca04caedb2
      https://github.com/PDAL/PDAL/commit/e4913f75be8590fc090362405aa6ecca04caedb2
  Changed paths:
    M src/PDALUtils.cpp
  Log Message:
  Remove dead code.
  Commit: fca26d854440d60c66b4447d6709317380ccfac7
      https://github.com/PDAL/PDAL/commit/fca26d854440d60c66b4447d6709317380ccfac7
  Date:   2015-07-16 (Thu, 16 Jul 2015)
  Changed paths:
    M src/GDALUtils.cpp
    M src/Kernel.cpp
    M src/Log.cpp
    M src/Options.cpp
    M src/PDALUtils.cpp
    M src/QuadIndex.cpp
    R src/Utils.cpp
  Log Message:
  Merge branch 'master' into grid-1.4.0
Compare: https://github.com/PDAL/PDAL/compare/089156986055...fca26d854440
More information about the pdal-commits mailing list
