[pdal-commits] [PDAL/PDAL] 11b568: provide default constructor for PluginInfo, no ini...
GitHub noreply at github.com
Tue Mar 10 11:42:39 PDT 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 11b568891987a826956b2424fb935b1aa2b9b4bc
      https://github.com/PDAL/PDAL/commit/11b568891987a826956b2424fb935b1aa2b9b4bc
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-03-10 (Tue, 10 Mar 2015)
  Changed paths:
    M filters/chipper/ChipperFilter.cpp
    M filters/colorization/ColorizationFilter.cpp
    M filters/crop/CropFilter.cpp
    M filters/decimation/DecimationFilter.cpp
    M filters/ferry/FerryFilter.cpp
    M filters/merge/MergeFilter.cpp
    M filters/mortonorder/MortonOrderFilter.cpp
    M filters/range/RangeFilter.cpp
    M filters/reprojection/ReprojectionFilter.cpp
    M filters/sort/SortFilter.cpp
    M filters/splitter/SplitterFilter.cpp
    M filters/stats/StatsFilter.cpp
    M filters/transformation/TransformationFilter.cpp
    M include/pdal/pdal_macros.hpp
    M io/bpf/BpfReader.cpp
    M io/bpf/BpfWriter.cpp
    M io/faux/FauxReader.cpp
    M io/las/LasReader.cpp
    M io/las/LasWriter.cpp
    M io/optech/OptechReader.cpp
    M io/qfit/QfitReader.cpp
    M io/sbet/SbetReader.cpp
    M io/sbet/SbetWriter.cpp
    M io/terrasolid/TerrasolidReader.cpp
    M io/text/TextWriter.cpp
    M kernels/delta/DeltaKernel.cpp
    M kernels/diff/DiffKernel.cpp
    M kernels/info/InfoKernel.cpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/random/RandomKernel.cpp
    M kernels/sort/SortKernel.cpp
    M kernels/translate/TranslateKernel.cpp
    M plugins/attribute/filters/AttributeFilter.cpp
    M plugins/cpd/kernel/Cpd.cpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/hexbin/filters/HexBin.cpp
    M plugins/icebridge/io/IcebridgeReader.cpp
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/nitf/io/NitfReader.cpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/oci/io/OciReader.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/p2g/io/P2gWriter.cpp
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/PCLBlock.cpp
    M plugins/pcl/io/PCLVisualizer.cpp
    M plugins/pcl/io/PcdReader.cpp
    M plugins/pcl/io/PcdWriter.cpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M plugins/pgpointcloud/io/PgReader.cpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/python/filters/PredicateFilter.cpp
    M plugins/python/filters/ProgrammableFilter.cpp
    M plugins/rxp/io/RxpReader.cpp
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
  Log Message:
  provide default constructor for PluginInfo, no initializer lists on msvc
  Commit: 945f4d62aee36b176e3af362b8254174d730ea9b
      https://github.com/PDAL/PDAL/commit/945f4d62aee36b176e3af362b8254174d730ea9b
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
  Log Message:
  Merge pull request #801 from PDAL/plugin-manager-fix
Compare: https://github.com/PDAL/PDAL/compare/a1a28cc86796...945f4d62aee3
More information about the pdal-commits mailing list
