[pdal-commits] [PDAL/PDAL] de2457: Make code match documentation.
GitHub noreply at github.com
Fri Mar 13 07:45:47 PDT 2015
  Branch: refs/heads/stream
  Home:   https://github.com/PDAL/PDAL
  Commit: de245756a2883de0f5efc54894b0f2a61725e610
      https://github.com/PDAL/PDAL/commit/de245756a2883de0f5efc54894b0f2a61725e610
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-03-11 (Wed, 11 Mar 2015)
  Changed paths:
    M plugins/python/filters/PredicateFilter.cpp
    M plugins/python/filters/ProgrammableFilter.cpp
    M test/data/plang/from-module.xml.in
  Log Message:
  Commit: 50a945080a441000d8a0eddf3d4b12ea1be7d790
      https://github.com/PDAL/PDAL/commit/50a945080a441000d8a0eddf3d4b12ea1be7d790
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M cmake/unix_compiler_options.cmake
    M include/pdal/GDALUtils.hpp
    M include/pdal/pdal_types.hpp
    M include/pdal/util/Bounds.hpp
    M io/las/GeotiffSupport.hpp
    M plugins/nitf/io/MetadataReader.hpp
    M plugins/nitf/io/NitfFile.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/tre_plugins.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/pcl/io/PCLVisualizer.cpp
    M plugins/pcl/pipeline/PCLPipeline.cpp
  Log Message:
  turn off -Wfloat-equal
  Commit: c43fc994f09282afe08ebfde93c7c54de9c1b3bd
      https://github.com/PDAL/PDAL/commit/c43fc994f09282afe08ebfde93c7c54de9c1b3bd
  Changed paths:
    M test/unit/Support.cpp
    M test/unit/UserCallbackTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/io/qfit/QFITReaderTest.cpp
  Log Message:
  remove float-equal from test/
  Commit: 2f6e2cdc228d93b6ecb9fbccbdd8c7e958d39b70
      https://github.com/PDAL/PDAL/commit/2f6e2cdc228d93b6ecb9fbccbdd8c7e958d39b70
  Changed paths:
  Log Message:
  Merge pull request #807 from PDAL/excise-float-equal
  Commit: 9280e19cfcea662bb085579174ebace46cdbeeed
      https://github.com/PDAL/PDAL/commit/9280e19cfcea662bb085579174ebace46cdbeeed
  Changed paths:
  Log Message:
  Merge pull request #808 from PDAL/issues-805
  Commit: 9ecafe907fb921e9b08defae8d79cdb951aecdea
      https://github.com/PDAL/PDAL/commit/9ecafe907fb921e9b08defae8d79cdb951aecdea
  Changed paths:
    A doc/_static/logo/dongle/back.ai
    A doc/_static/logo/dongle/front.ai
    M doc/compilation/dependencies.rst
    M doc/conf.py
    M doc/stages/filters.chipper.rst
    M doc/stages/filters.programmable.rst
    M doc/stages/index.rst
    M doc/stages/readers.buffer.rst
    M doc/stages/readers.nitf.rst
    A doc/stages/readers.sqlite.rst
    M doc/stages/writers.rialto.rst
    A doc/stages/writers.sqlite.rst
    M doc/tutorial/pcl_block_tutorial.rst
    M doc/tutorial/pcl_spec.rst
    M doc/vagrant.rst
  Log Message:
  a bunch of doc updates
  Commit: 138ea75fa352e1f289b2a87104b27647430cefea
      https://github.com/PDAL/PDAL/commit/138ea75fa352e1f289b2a87104b27647430cefea
  Changed paths:
    M doc/conf.py
    M doc/vagrant.rst
  Log Message:
  Merge pull request #809 from PDAL/hobu-doc-updates-3-2015
  Commit: 80524809c2a2d4eb68ff33ecd9e052a368a21f14
      https://github.com/PDAL/PDAL/commit/80524809c2a2d4eb68ff33ecd9e052a368a21f14
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-03-12 (Thu, 12 Mar 2015)
  Changed paths:
    M README.md
    A appveyor.yml
    A scripts/appveyor/install.cmd
  Log Message:
  Add initial appveyor configuration with status badge
  Commit: 57cb2c8c1e3aced14112881639508e53aff8b2e9
      https://github.com/PDAL/PDAL/commit/57cb2c8c1e3aced14112881639508e53aff8b2e9
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M README.md
    A appveyor.yml
  Log Message:
  Merge pull request #813 from PDAL/appveyor
Add initial appveyor configuration with status badge. Still have some kinks to work out with the tests and optional components, but this is a reasonable start.
  Commit: ed03a4768e7f03457f2bbdd2c013ce4965204b4c
      https://github.com/PDAL/PDAL/commit/ed03a4768e7f03457f2bbdd2c013ce4965204b4c
  Changed paths:
    M README.md
  Log Message:
  fix typo in README
  Commit: 54c9d60f1112572e7f3d5cee78251d9afdecf33d
      https://github.com/PDAL/PDAL/commit/54c9d60f1112572e7f3d5cee78251d9afdecf33d
  Changed paths:
    M README.md
  Log Message:
  update url in appveyor badge
  Commit: 8cb61251b0001fc9e23658da94663cee4c939465
      https://github.com/PDAL/PDAL/commit/8cb61251b0001fc9e23658da94663cee4c939465
  Changed paths:
    M include/pdal/PointContext.hpp
    M include/pdal/RawPtBuf.hpp
    M test/unit/PointContextTest.cpp
  Log Message:
  Change signature of update function to ease users creating their own buffer.
  Commit: c3aa28cd07488025dd24678edb6a9bdc7a4ae4ed
      https://github.com/PDAL/PDAL/commit/c3aa28cd07488025dd24678edb6a9bdc7a4ae4ed
  Date:   2015-03-13 (Fri, 13 Mar 2015)
  Changed paths:
    M README.md
  Log Message:
  fix the appveyor badge once again
  Commit: 163a3bb232069ce9aa03a2a31bf4d3308fafa582
      https://github.com/PDAL/PDAL/commit/163a3bb232069ce9aa03a2a31bf4d3308fafa582
  Changed paths:
    M cmake/win32_compiler_options.cmake
    M include/pdal/PointBuffer.hpp
  Log Message:
  silence two particularly noisy warnings on windows (c4244 and c4290)
  Commit: 350c05e58a444edd89bd020e91bf41cdfcb01fdf
      https://github.com/PDAL/PDAL/commit/350c05e58a444edd89bd020e91bf41cdfcb01fdf
  Changed paths:
    M cmake/compiler_options.cmake
    M include/pdal/plugin.h
    M include/pdal/util/FileUtils.hpp
    M io/las/LasHeader.cpp
    M io/optech/OptechReader.cpp
    M src/DynamicLibrary.cpp
    M src/PipelineReader.cpp
    M src/PluginManager.cpp
    M src/Utils.cpp
    M test/unit/FileUtilsTest.cpp
    M test/unit/SupportTest.cpp
    M test/unit/apps/pcinfoTest.cpp
  Log Message:
  use standard compiler macros
  Commit: 61151e495335aca8a59f0ee003860459a7905574
      https://github.com/PDAL/PDAL/commit/61151e495335aca8a59f0ee003860459a7905574
  Changed paths:
    M appveyor.yml
  Log Message:
  update slack notification token
  Commit: b0407cc3ff1245be3bff54ed495a8e987032ac7d
      https://github.com/PDAL/PDAL/commit/b0407cc3ff1245be3bff54ed495a8e987032ac7d
  Changed paths:
    M README.md
    A appveyor.yml
    M doc/conf.py
    M doc/vagrant.rst
    M src/Utils.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into stream
Compare: https://github.com/PDAL/PDAL/compare/d605f703e922...b0407cc3ff12
More information about the pdal-commits mailing list
