[pdal-commits] [PDAL/PDAL] 23de90: Move StageRunner.hpp to src dir.
GitHub noreply at github.com
Tue Mar 17 12:01:15 PDT 2015
  Branch: refs/heads/stream
  Home:   https://github.com/PDAL/PDAL
  Commit: 23de909b31ed1528ff86bfcab3d8e618eed57272
      https://github.com/PDAL/PDAL/commit/23de909b31ed1528ff86bfcab3d8e618eed57272
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-03-04 (Wed, 04 Mar 2015)
  Changed paths:
    R include/pdal/StageRunner.hpp
    M src/CMakeLists.txt
    M src/Stage.cpp
    A src/StageRunner.hpp
  Log Message:
  Commit: 814077b55c5b227f38e7f19a4d32af5109a6fe43
      https://github.com/PDAL/PDAL/commit/814077b55c5b227f38e7f19a4d32af5109a6fe43
  Date:   2015-03-13 (Fri, 13 Mar 2015)
  Changed paths:
    M include/pdal/KDIndex.hpp
    M io/bpf/BpfCompressor.hpp
    M kernels/delta/DeltaKernel.cpp
    M kernels/info/InfoKernel.cpp
    M src/KDIndex.cpp
    M test/unit/PointBufferTest.cpp
  Log Message:
  Remove unused arguments.
  Commit: 39aa7d7c6d355f5bcd6d3d298aec8ca34d8eb1de
      https://github.com/PDAL/PDAL/commit/39aa7d7c6d355f5bcd6d3d298aec8ca34d8eb1de
  Changed paths:
    M README.md
    A appveyor.yml
    M cmake/compiler_options.cmake
    M cmake/unix_compiler_options.cmake
    M cmake/win32_compiler_options.cmake
    A doc/_static/logo/dongle/back.ai
    A doc/_static/logo/dongle/front.ai
    M doc/compilation/dependencies.rst
    M doc/conf.py
    M doc/stages/filters.chipper.rst
    M doc/stages/filters.programmable.rst
    M doc/stages/index.rst
    M doc/stages/readers.buffer.rst
    M doc/stages/readers.nitf.rst
    A doc/stages/readers.sqlite.rst
    M doc/stages/writers.rialto.rst
    A doc/stages/writers.sqlite.rst
    M doc/tutorial/pcl_block_tutorial.rst
    M doc/tutorial/pcl_spec.rst
    M doc/vagrant.rst
    M include/pdal/GDALUtils.hpp
    M include/pdal/PointBuffer.hpp
    M include/pdal/pdal_types.hpp
    M include/pdal/plugin.h
    M include/pdal/util/Bounds.hpp
    M include/pdal/util/FileUtils.hpp
    M io/las/GeotiffSupport.hpp
    M io/las/LasHeader.cpp
    M io/optech/OptechReader.cpp
    M plugins/nitf/io/MetadataReader.hpp
    M plugins/nitf/io/NitfFile.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/tre_plugins.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/pcl/io/PCLVisualizer.cpp
    M plugins/pcl/pipeline/PCLPipeline.cpp
    M plugins/python/filters/PredicateFilter.cpp
    M plugins/python/filters/ProgrammableFilter.cpp
    A scripts/appveyor/install.cmd
    M src/DynamicLibrary.cpp
    M src/PipelineReader.cpp
    M src/PluginManager.cpp
    M src/Utils.cpp
    M test/data/plang/from-module.xml.in
    M test/unit/FileUtilsTest.cpp
    M test/unit/Support.cpp
    M test/unit/SupportTest.cpp
    M test/unit/UserCallbackTest.cpp
    M test/unit/apps/pcinfoTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/io/qfit/QFITReaderTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: f9441563e083849aba01252269f9ea1c14ad606b
      https://github.com/PDAL/PDAL/commit/f9441563e083849aba01252269f9ea1c14ad606b
  Changed paths:
    M include/pdal/PDALUtils.hpp
  Log Message:
  Don't access different lists in loop.
  Commit: 0fb7e95f47c15feded025b0274a18f916d078366
      https://github.com/PDAL/PDAL/commit/0fb7e95f47c15feded025b0274a18f916d078366
  Changed paths:
  Log Message:
  Merge pull request #817 from PDAL/issues-816
  Commit: f84859f20f74a6a8533cf95b53661d12f442fe71
      https://github.com/PDAL/PDAL/commit/f84859f20f74a6a8533cf95b53661d12f442fe71
  Changed paths:
    M .gitignore
    M README.md
    M Vagrantfile
    M apps/pdal.cpp
    A appveyor.yml
    M doc/conf.py
    M doc/download.rst
    A doc/stages/readers.optech.rst
    A doc/stages/writers.rialto.rst
    M doc/tutorial/writing.rst
    M doc/vagrant.rst
    M examples/writing/tutorial.cpp
    M filters/chipper/ChipperFilter.cpp
    M filters/chipper/ChipperFilter.hpp
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M filters/crop/CropFilter.cpp
    M filters/crop/CropFilter.hpp
    M filters/decimation/DecimationFilter.cpp
    M filters/decimation/DecimationFilter.hpp
    M filters/ferry/FerryFilter.cpp
    M filters/ferry/FerryFilter.hpp
    M filters/merge/CMakeLists.txt
    A filters/merge/MergeFilter.cpp
    M filters/merge/MergeFilter.hpp
    M filters/mortonorder/MortonOrderFilter.cpp
    M filters/mortonorder/MortonOrderFilter.hpp
    M filters/range/RangeFilter.cpp
    M filters/range/RangeFilter.hpp
    M filters/reprojection/ReprojectionFilter.cpp
    M filters/reprojection/ReprojectionFilter.hpp
    M filters/sort/CMakeLists.txt
    A filters/sort/SortFilter.cpp
    M filters/sort/SortFilter.hpp
    M filters/splitter/SplitterFilter.cpp
    M filters/splitter/SplitterFilter.hpp
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    M filters/transformation/TransformationFilter.cpp
    M filters/transformation/TransformationFilter.hpp
    M include/pdal/BufferReader.hpp
    R include/pdal/Charbuf.hpp
    M include/pdal/Compression.hpp
    R include/pdal/Drivers.hpp
    R include/pdal/Extractor.hpp
    M include/pdal/Filter.hpp
    R include/pdal/Filters.hpp
    R include/pdal/IStream.hpp
    R include/pdal/Inserter.hpp
    M include/pdal/Kernel.hpp
    M include/pdal/KernelFactory.hpp
    R include/pdal/KernelInfo.hpp
    M include/pdal/KernelSupport.hpp
    R include/pdal/Kernels.hpp
    R include/pdal/OStream.hpp
    M include/pdal/PipelineManager.hpp
    M include/pdal/PipelineReader.hpp
    A include/pdal/PluginManager.hpp
    M include/pdal/PointContext.hpp
    M include/pdal/QuadIndex.hpp
    M include/pdal/RawPtBuf.hpp
    M include/pdal/Reader.hpp
    M include/pdal/Stage.hpp
    M include/pdal/StageFactory.hpp
    R include/pdal/StageInfo.hpp
    M include/pdal/Utils.hpp
    M include/pdal/Writer.hpp
    M include/pdal/pdal_macros.hpp
    A include/pdal/plugin.h
    A include/pdal/util/Charbuf.hpp
    A include/pdal/util/Extractor.hpp
    A include/pdal/util/Georeference.hpp
    A include/pdal/util/IStream.hpp
    A include/pdal/util/Inserter.hpp
    A include/pdal/util/OStream.hpp
    M io/CMakeLists.txt
    M io/bpf/BpfHeader.cpp
    M io/bpf/BpfReader.cpp
    M io/bpf/BpfReader.hpp
    M io/bpf/BpfWriter.cpp
    M io/bpf/BpfWriter.hpp
    M io/faux/FauxReader.cpp
    M io/faux/FauxReader.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M io/las/LasUtils.cpp
    M io/las/LasWriter.cpp
    M io/las/LasWriter.hpp
    M io/las/VariableLengthRecord.hpp
    A io/optech/CMakeLists.txt
    A io/optech/OptechCommon.hpp
    A io/optech/OptechReader.cpp
    A io/optech/OptechReader.hpp
    A io/optech/OptechRotationMatrix.hpp
    M io/qfit/QfitReader.cpp
    M io/qfit/QfitReader.hpp
    A io/rialto/CMakeLists.txt
    A io/rialto/RialtoCommon.cpp
    A io/rialto/RialtoCommon.hpp
    A io/rialto/RialtoWriter.cpp
    A io/rialto/RialtoWriter.hpp
    M io/sbet/SbetReader.cpp
    M io/sbet/SbetReader.hpp
    M io/sbet/SbetWriter.cpp
    M io/sbet/SbetWriter.hpp
    M io/terrasolid/TerrasolidReader.cpp
    M io/terrasolid/TerrasolidReader.hpp
    M io/text/TextWriter.cpp
    M io/text/TextWriter.hpp
    M kernels/delta/DeltaKernel.hpp
    M kernels/diff/DiffKernel.cpp
    M kernels/diff/DiffKernel.hpp
    M kernels/info/InfoKernel.hpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/pipeline/PipelineKernel.hpp
    M kernels/random/RandomKernel.cpp
    M kernels/random/RandomKernel.hpp
    M kernels/sort/SortKernel.cpp
    M kernels/sort/SortKernel.hpp
    M kernels/translate/TranslateKernel.cpp
    M kernels/translate/TranslateKernel.hpp
    M pdal_defines.h.in
    M plugins/CMakeLists.txt
    M plugins/attribute/filters/AttributeFilter.cpp
    M plugins/attribute/filters/AttributeFilter.hpp
    M plugins/cpd/kernel/Cpd.cpp
    M plugins/cpd/kernel/Cpd.hpp
    M plugins/cpd/test/CpdKernelTest.cpp
    M plugins/geowave/io/GeoWaveReader.cpp
    M plugins/geowave/io/GeoWaveWriter.cpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundReader.hpp
    M plugins/hexbin/filters/HexBin.cpp
    M plugins/hexbin/filters/HexBin.hpp
    M plugins/hexbin/test/HexbinFilterTest.cpp
    M plugins/icebridge/io/IcebridgeReader.cpp
    M plugins/icebridge/io/IcebridgeReader.hpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/mrsid/io/MrsidReader.hpp
    M plugins/nitf/io/NitfReader.cpp
    M plugins/nitf/io/NitfReader.hpp
    M plugins/nitf/io/NitfWriter.hpp
    M plugins/nitf/test/NitfWriterTest.cpp
    M plugins/oci/io/OciCommon.cpp
    M plugins/oci/io/OciReader.cpp
    M plugins/oci/io/OciReader.hpp
    M plugins/oci/io/OciWrapper.cpp
    M plugins/oci/io/OciWrapper.h
    M plugins/oci/io/OciWriter.cpp
    M plugins/oci/io/OciWriter.hpp
    M plugins/oci/test/OCITest.cpp
    M plugins/p2g/io/P2gWriter.cpp
    M plugins/p2g/io/P2gWriter.hpp
    M plugins/pcl/CMakeLists.txt
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/GroundFilter.hpp
    M plugins/pcl/filters/PCLBlock.cpp
    M plugins/pcl/filters/PCLBlock.hpp
    M plugins/pcl/io/PCLVisualizer.hpp
    M plugins/pcl/io/PcdReader.cpp
    M plugins/pcl/io/PcdReader.hpp
    M plugins/pcl/io/PcdWriter.cpp
    M plugins/pcl/io/PcdWriter.hpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/GroundKernel.hpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/PCLKernel.hpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.hpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M plugins/pcl/kernel/ViewKernel.hpp
    M plugins/pcl/test/PCLBlockFilterTest.cpp
    M plugins/pgpointcloud/io/PgReader.cpp
    M plugins/pgpointcloud/io/PgReader.hpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/pgpointcloud/io/PgWriter.hpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M plugins/python/filters/PredicateFilter.hpp
    M plugins/python/filters/ProgrammableFilter.hpp
    M plugins/python/test/PredicateFilterTest.cpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M plugins/rxp/io/RxpReader.cpp
    M plugins/rxp/io/RxpReader.hpp
    M plugins/rxp/test/RxpReaderTest.cpp
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteReader.hpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M plugins/sqlite/io/SQLiteWriter.hpp
    M plugins/sqlite/test/SQLiteTest.cpp
    A scripts/linux-install-scripts/geowave
    A scripts/linux-install-scripts/geowave.sh
    M scripts/linux-install-scripts/packages.sh
    R scripts/linux-install-scripts/pdal.sh
    A scripts/linux-install-scripts/pdal_clone.sh
    A scripts/linux-install-scripts/pdal_install.sh
    R src/Charbuf.cpp
    A src/DynamicLibrary.cpp
    A src/DynamicLibrary.h
    M src/KDIndex.cpp
    M src/Kernel.cpp
    M src/KernelFactory.cpp
    R src/KernelInfo.cpp
    M src/KernelSupport.cpp
    M src/PipelineManager.cpp
    M src/PipelineWriter.cpp
    A src/PluginManager.cpp
    M src/QuadIndex.cpp
    M src/Stage.cpp
    M src/StageFactory.cpp
    R src/StageInfo.cpp
    M src/Utils.cpp
    M src/util/Bounds.cpp
    M src/util/CMakeLists.txt
    A src/util/Charbuf.cpp
    M src/util/FileUtils.cpp
    A src/util/Georeference.cpp
    A test/data/io/header.json
    A test/data/optech/sample.csd
    M test/unit/CMakeLists.txt
    M test/unit/CompressionTest.cpp
    A test/unit/GeoreferenceTest.cpp
    M test/unit/LogTest.cpp
    M test/unit/MetadataTest.cpp
    M test/unit/OptionsTest.cpp
    M test/unit/PipelineManagerTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/StageTester.hpp
    M test/unit/UtilsTest.cpp
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/DecimationFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/RangeFilterTest.cpp
    M test/unit/filters/SortFilterTest.cpp
    M test/unit/filters/SplitterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
    M test/unit/filters/TransformationFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/buffer/BufferTest.cpp
    M test/unit/io/faux/FauxReaderTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
    A test/unit/io/optech/OptechReaderTest.cpp
    A test/unit/io/rialto/RialtoWriterTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
    M test/unit/io/sbet/SbetWriterTest.cpp
    A test/unit/io/terrasolid/TerrasolidReaderTest.cpp
    M tools/lasdump/Dumper.cpp
    M tools/lasdump/Header.hpp
    M tools/lasdump/Vlr.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issues-778
Conflicts:
	src/CMakeLists.txt
	src/Stage.cpp
  Commit: 86df11f823a7da339ab4c716644475c91823f2b9
      https://github.com/PDAL/PDAL/commit/86df11f823a7da339ab4c716644475c91823f2b9
  Date:   2015-03-16 (Mon, 16 Mar 2015)
  Changed paths:
  Log Message:
  Handle bad filter stage on reading pipeline.
Pass though specific errors detected on parsing.
  Commit: b07a294498bca683a2f36c2120acaa88459dcc7a
      https://github.com/PDAL/PDAL/commit/b07a294498bca683a2f36c2120acaa88459dcc7a
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Changed paths:
    M cmake/modules/FindLASzip.cmake
  Log Message:
  Don't use PATH_PREFIXES in FindLASzip
PATH_PREFIXES was getting confused by a /usr/local/bin/laszip.
Fixes #820
  Commit: 4468ae7ed9b09e4173b464eb9436e047f78a0bbd
      https://github.com/PDAL/PDAL/commit/4468ae7ed9b09e4173b464eb9436e047f78a0bbd
  Changed paths:
  Log Message:
  Remove debug.
  Commit: 30ff9d62747ee9a023dd31d344b0dfeecfd55742
      https://github.com/PDAL/PDAL/commit/30ff9d62747ee9a023dd31d344b0dfeecfd55742
  Changed paths:
  Log Message:
  Merge pull request #827 from PDAL/issues-822
Issues 822
  Commit: 9343620d262be822f831e7bfb9c81396b7faeae5
      https://github.com/PDAL/PDAL/commit/9343620d262be822f831e7bfb9c81396b7faeae5
  Changed paths:
  Log Message:
  Fix text.
  Commit: b4ad6cf28c066d65b09127a1737834e52103d82c
      https://github.com/PDAL/PDAL/commit/b4ad6cf28c066d65b09127a1737834e52103d82c
  Changed paths:
  Log Message:
  Merge pull request #828 from PDAL/issues-822
Fix text.
  Commit: e4f0bd532ad369035d1d2b8c25cca5775d7f2670
      https://github.com/PDAL/PDAL/commit/e4f0bd532ad369035d1d2b8c25cca5775d7f2670
  Changed paths:
  Log Message:
  Merge pull request #824 from gadomski/issues/820-laszip-and-lastools-cmake
  Commit: cb922669e2af33d3a132684c0811ff5b1244b964
      https://github.com/PDAL/PDAL/commit/cb922669e2af33d3a132684c0811ff5b1244b964
  Changed paths:
  Log Message:
  Merge pull request #823 from PDAL/issues-778
Issues 778
  Commit: 4632cc21b9203efe4aa36eac050a18a4f0951691
      https://github.com/PDAL/PDAL/commit/4632cc21b9203efe4aa36eac050a18a4f0951691
  Changed paths:
    M src/Kernel.cpp
  Log Message:
  Don't open LAZ file if we can't compress.
  Commit: 2dbf53b96b4bb71fda6984c5f1f6a97272d02296
      https://github.com/PDAL/PDAL/commit/2dbf53b96b4bb71fda6984c5f1f6a97272d02296
  Changed paths:
  Log Message:
  Remove unused option "cloud_id" from OCI writer.
  Commit: 458afd859293d46bb66984d899e51be85574f33e
      https://github.com/PDAL/PDAL/commit/458afd859293d46bb66984d899e51be85574f33e
  Changed paths:
  Log Message:
  Merge pull request #830 from PDAL/issues-812
  Commit: f64e7dbed3b51a2849b8ec7655f2df2a8d86dd84
      https://github.com/PDAL/PDAL/commit/f64e7dbed3b51a2849b8ec7655f2df2a8d86dd84
  Changed paths:
    M src/Kernel.cpp
  Log Message:
  Merge pull request #831 from PDAL/issues-821
  Commit: 3c3d4131b243a9e9986bfc67bacdf64ecd6fbccf
      https://github.com/PDAL/PDAL/commit/3c3d4131b243a9e9986bfc67bacdf64ecd6fbccf
  Date:   2015-03-17 (Tue, 17 Mar 2015)
  Changed paths:
    M src/KDIndex.cpp
    M src/Kernel.cpp
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL into stream
Compare: https://github.com/PDAL/PDAL/compare/b0407cc3ff12...3c3d4131b243
More information about the pdal-commits mailing list
