[pdal-commits] [PDAL/PDAL] 68ff98: Squashed commit of the following:
GitHub noreply at github.com
Wed Mar 18 16:39:24 PDT 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 68ff984be2e2db1de85a7a391817663505feacd0
      https://github.com/PDAL/PDAL/commit/68ff984be2e2db1de85a7a391817663505feacd0
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-03-18 (Wed, 18 Mar 2015)
  Changed paths:
    M doc/api/cpp/index.rst
    R doc/api/cpp/pointbuffer.rst
    R doc/api/cpp/pointcontext.rst
    A doc/api/cpp/pointtable.rst
    A doc/api/cpp/pointview.rst
    M doc/metadata.rst
    M doc/pipeline.rst
    M doc/stages/filters.hexbin.rst
    M doc/stages/filters.pclblock.rst
    M doc/stages/readers.buffer.rst
    M doc/tutorial/overview.rst
    M doc/tutorial/pcl_block_tutorial.rst
    M doc/tutorial/writing.rst
    M examples/writing/tutorial.cpp
    M filters/chipper/ChipperFilter.cpp
    M filters/chipper/ChipperFilter.hpp
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M filters/crop/CropFilter.cpp
    M filters/crop/CropFilter.hpp
    M filters/decimation/DecimationFilter.cpp
    M filters/decimation/DecimationFilter.hpp
    M filters/ferry/FerryFilter.cpp
    M filters/ferry/FerryFilter.hpp
    M filters/merge/MergeFilter.hpp
    M filters/mortonorder/MortonOrderFilter.cpp
    M filters/mortonorder/MortonOrderFilter.hpp
    M filters/range/RangeFilter.cpp
    M filters/range/RangeFilter.hpp
    M filters/reprojection/ReprojectionFilter.cpp
    M filters/reprojection/ReprojectionFilter.hpp
    M filters/sort/SortFilter.hpp
    M filters/splitter/SplitterFilter.cpp
    M filters/splitter/SplitterFilter.hpp
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    M filters/transformation/TransformationFilter.cpp
    M filters/transformation/TransformationFilter.hpp
    M include/pdal/BufferReader.hpp
    M include/pdal/Compression.hpp
    M include/pdal/DbReader.hpp
    M include/pdal/DbWriter.hpp
    M include/pdal/Filter.hpp
    M include/pdal/KDIndex.hpp
    M include/pdal/Kernel.hpp
    M include/pdal/Metadata.hpp
    M include/pdal/PDALUtils.hpp
    M include/pdal/PipelineManager.hpp
    M include/pdal/PipelineWriter.hpp
    R include/pdal/PointBuffer.hpp
    R include/pdal/PointBufferIter.hpp
    R include/pdal/PointContext.hpp
    A include/pdal/PointLayout.hpp
    A include/pdal/PointTable.hpp
    A include/pdal/PointView.hpp
    A include/pdal/PointViewIter.hpp
    M include/pdal/QuadIndex.hpp
    R include/pdal/RawPtBuf.hpp
    M include/pdal/Reader.hpp
    M include/pdal/Stage.hpp
    M include/pdal/Utils.hpp
    M include/pdal/Writer.hpp
    M include/pdal/pdal.hpp
    M include/pdal/plang/BufferedInvocation.hpp
    M io/bpf/BpfReader.cpp
    M io/bpf/BpfReader.hpp
    M io/bpf/BpfWriter.cpp
    M io/bpf/BpfWriter.hpp
    M io/faux/FauxReader.cpp
    M io/faux/FauxReader.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M io/las/LasWriter.cpp
    M io/las/LasWriter.hpp
    M io/optech/OptechReader.cpp
    M io/optech/OptechReader.hpp
    M io/qfit/QfitReader.cpp
    M io/qfit/QfitReader.hpp
    M io/rialto/RialtoCommon.cpp
    M io/rialto/RialtoCommon.hpp
    M io/rialto/RialtoWriter.cpp
    M io/rialto/RialtoWriter.hpp
    M io/sbet/SbetReader.cpp
    M io/sbet/SbetReader.hpp
    M io/sbet/SbetWriter.cpp
    M io/sbet/SbetWriter.hpp
    M io/terrasolid/TerrasolidReader.cpp
    M io/terrasolid/TerrasolidReader.hpp
    M io/text/TextWriter.cpp
    M io/text/TextWriter.hpp
    M kernels/delta/DeltaKernel.cpp
    M kernels/delta/DeltaKernel.hpp
    M kernels/diff/DiffKernel.cpp
    M kernels/diff/DiffKernel.hpp
    M kernels/info/InfoKernel.cpp
    M kernels/info/InfoKernel.hpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/pipeline/PipelineKernel.hpp
    M kernels/random/RandomKernel.cpp
    M kernels/sort/SortKernel.cpp
    M kernels/translate/TranslateKernel.cpp
    M plugins/attribute/filters/AttributeFilter.cpp
    M plugins/attribute/filters/AttributeFilter.hpp
    M plugins/cpd/kernel/Cpd.cpp
    M plugins/cpd/kernel/Cpd.hpp
    M plugins/geowave/io/GeoWaveReader.cpp
    M plugins/geowave/io/GeoWaveReader.hpp
    M plugins/geowave/io/GeoWaveWriter.cpp
    M plugins/geowave/io/GeoWaveWriter.hpp
    M plugins/greyhound/io/Exchanges.cpp
    M plugins/greyhound/io/Exchanges.hpp
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundReader.hpp
    M plugins/hexbin/filters/HexBin.cpp
    M plugins/hexbin/filters/HexBin.hpp
    M plugins/hexbin/test/HexbinFilterTest.cpp
    M plugins/icebridge/io/IcebridgeReader.cpp
    M plugins/icebridge/io/IcebridgeReader.hpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/nitf/io/NitfReader.cpp
    M plugins/nitf/io/NitfReader.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/NitfWriter.hpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/nitf/test/NitfWriterTest.cpp
    M plugins/oci/io/OciCommon.hpp
    M plugins/oci/io/OciReader.cpp
    M plugins/oci/io/OciReader.hpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/oci/io/OciWriter.hpp
    M plugins/oci/test/OCITest.cpp
    M plugins/p2g/io/P2gWriter.cpp
    M plugins/p2g/io/P2gWriter.hpp
    M plugins/pcl/PCLConversions.hpp
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/GroundFilter.hpp
    M plugins/pcl/filters/PCLBlock.cpp
    M plugins/pcl/filters/PCLBlock.hpp
    M plugins/pcl/io/PCLVisualizer.cpp
    M plugins/pcl/io/PCLVisualizer.hpp
    M plugins/pcl/io/PcdReader.cpp
    M plugins/pcl/io/PcdReader.hpp
    M plugins/pcl/io/PcdWriter.cpp
    M plugins/pcl/io/PcdWriter.hpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M plugins/pcl/test/PCLBlockFilterTest.cpp
    M plugins/pgpointcloud/io/PgReader.cpp
    M plugins/pgpointcloud/io/PgReader.hpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/pgpointcloud/io/PgWriter.hpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M plugins/pgpointcloud/test/Pgtest-Support.hpp.in
    M plugins/python/filters/PredicateFilter.cpp
    M plugins/python/filters/PredicateFilter.hpp
    M plugins/python/filters/ProgrammableFilter.cpp
    M plugins/python/filters/ProgrammableFilter.hpp
    M plugins/python/test/PredicateFilterTest.cpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M plugins/rxp/io/RxpPointcloud.cpp
    M plugins/rxp/io/RxpPointcloud.hpp
    M plugins/rxp/io/RxpReader.cpp
    M plugins/rxp/io/RxpReader.hpp
    M plugins/rxp/test/RxpReaderTest.cpp
    M plugins/sqlite/io/SQLiteCommon.hpp
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteReader.hpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M plugins/sqlite/io/SQLiteWriter.hpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M src/CMakeLists.txt
    M src/DbReader.cpp
    M src/DbWriter.cpp
    M src/KDIndex.cpp
    M src/Kernel.cpp
    M src/PipelineManager.cpp
    M src/PipelineWriter.cpp
    R src/PointBuffer.cpp
    A src/PointLayout.cpp
    A src/PointTable.cpp
    A src/PointView.cpp
    M src/QuadIndex.cpp
    M src/Stage.cpp
    M src/StageRunner.hpp
    M src/Writer.cpp
    M src/plang/BufferedInvocation.cpp
    M test/CMakeLists.txt
    M test/data/logs/logtest.txt
    M test/data/logs/logtest_1.txt
    M test/data/logs/logtest_123.txt
    R test/perf/CMakeLists.txt
    R test/perf/SchemaPerfTest.cpp
    R test/perf/chipper.xml
    R test/perf/chipper_nocache.xml
    R test/perf/timer.hpp
    M test/unit/CMakeLists.txt
    M test/unit/CompressionTest.cpp
    M test/unit/LogTest.cpp
    M test/unit/MetadataTest.cpp
    M test/unit/PipelineManagerTest.cpp
    R test/unit/PointBufferTest.cpp
    R test/unit/PointContextTest.cpp
    A test/unit/PointTableTest.cpp
    A test/unit/PointViewTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/StageTester.hpp
    M test/unit/Support.cpp
    M test/unit/Support.hpp
    M test/unit/XMLSchemaTest.cpp
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/DecimationFilterTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/filters/RangeFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M test/unit/filters/SortFilterTest.cpp
    M test/unit/filters/SplitterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
    M test/unit/filters/TransformationFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/buffer/BufferTest.cpp
    M test/unit/io/faux/FauxReaderTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
    M test/unit/io/optech/OptechReaderTest.cpp
    M test/unit/io/qfit/QFITReaderTest.cpp
    M test/unit/io/rialto/RialtoWriterTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
    M test/unit/io/sbet/SbetWriterTest.cpp
    M test/unit/io/terrasolid/TerrasolidReaderTest.cpp
  Log Message:
Break out layout into its own class.
Rename PointContext -> PointTable
Merge RawPtBuf into PointTable
Rename PointBuffer -> PointView
  Commit: 7dc3404dc0a74a1889e62ccab04b488afb2c4df4
      https://github.com/PDAL/PDAL/commit/7dc3404dc0a74a1889e62ccab04b488afb2c4df4
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    A scripts/bash-completion/README
    A scripts/bash-completion/pdal
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL
Compare: https://github.com/PDAL/PDAL/compare/0758a89178d9...7dc3404dc0a7
More information about the pdal-commits mailing list
