[pdal-commits] [PDAL/PDAL] 3d3966: reexport_library for libpdal_util
GitHub noreply at github.com
Thu Oct 1 08:00:19 PDT 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 3d3966c0d89d3b0f0d2326487dd7599abe995dfc
      https://github.com/PDAL/PDAL/commit/3d3966c0d89d3b0f0d2326487dd7599abe995dfc
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-09-01 (Tue, 01 Sep 2015)
  Changed paths:
    M src/CMakeLists.txt
  Log Message:
  Commit: a8c586a81f510a6e35cb3bd30d8273b14113c343
      https://github.com/PDAL/PDAL/commit/a8c586a81f510a6e35cb3bd30d8273b14113c343
  Date:   2015-09-11 (Fri, 11 Sep 2015)
  Changed paths:
    M include/pdal/Compression.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
  Log Message:
  Decompress with LAZperf and v. 2 VLR item types.
  Commit: 44dc1282b8553e2914de618359642e79cfdf6a08
      https://github.com/PDAL/PDAL/commit/44dc1282b8553e2914de618359642e79cfdf6a08
  Changed paths:
  Log Message:
  Fix #ifdefs.
  Commit: 609b4da5e586e30309438945a55ce62952dbf228
      https://github.com/PDAL/PDAL/commit/609b4da5e586e30309438945a55ce62952dbf228
  Changed paths:
    A test/data/las/autzen_trim.las
    A test/data/laz/autzen_trim.laz
    M test/unit/io/las/LasReaderTest.cpp
  Log Message:
  Test for reading with LAZperf.
Allow programmatic selection of LAZperf or LASzip.
  Commit: 95b8147a28539cf18f6f289bd27b2b5fba068833
      https://github.com/PDAL/PDAL/commit/95b8147a28539cf18f6f289bd27b2b5fba068833
  Date:   2015-09-16 (Wed, 16 Sep 2015)
  Changed paths:
    M include/pdal/Options.hpp
    M io/las/LasUtils.hpp
    M io/las/LasWriter.cpp
    M io/las/LasWriter.hpp
  Log Message:
  First-cut at LAZperf compression.
  Commit: c5037fb648bf83121844edf0c36341917e324ae7
      https://github.com/PDAL/PDAL/commit/c5037fb648bf83121844edf0c36341917e324ae7
  Changed paths:
    M .gitignore
    M CMakeLists.txt
    A HOWTORELEASE.txt
    M apps/CMakeLists.txt
    M apps/pdal-config.in
    A apps/pdal.pc.in
    M cmake/examples/hobu-config.sh
    M doc/apps.rst
    M doc/conf.py
    M doc/docs.rst
    M doc/download.rst
    M doc/faq.rst
    M doc/stages/filters.ferry.rst
    A doc/stages/filters.greedyprojection.rst
    A doc/stages/filters.gridprojection.rst
    A doc/stages/filters.ground.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.mortonorder.rst
    A doc/stages/filters.movingleastsquares.rst
    A doc/stages/filters.poisson.rst
    A doc/stages/filters.radiusoutlier.rst
    M doc/stages/filters.splitter.rst
    A doc/stages/filters.statisticaloutlier.rst
    M doc/stages/filters.stats.rst
    A doc/stages/filters.voxelgrid.rst
    M doc/stages/index.rst
    M doc/stages/readers.bpf.rst
    M doc/stages/readers.buffer.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.null.rst
    M doc/stages/writers.text.rst
    M doc/tutorial/index.rst
    A doc/tutorial/liblas_to_pdal.rst
    M doc/tutorial/overview.rst
    M doc/tutorial/pcl_spec.rst
    M doc/tutorial/reading.rst
    M doc/vagrant.rst
    M filters/crop/CropFilter.cpp
    M include/pdal/Kernel.hpp
    M include/pdal/KernelSupport.hpp
    M include/pdal/Metadata.hpp
    M include/pdal/PipelineManager.hpp
    M include/pdal/PipelineWriter.hpp
    M include/pdal/PointView.hpp
    M include/pdal/XMLSchema.hpp
    A include/pdal/plang/Array.hpp
    A include/pdal/plang/BufferedInvocation.hpp
    A include/pdal/plang/Environment.hpp
    A include/pdal/plang/Invocation.hpp
    A include/pdal/plang/Redirector.hpp
    A include/pdal/plang/Script.hpp
    M include/pdal/util/Bounds.hpp
    M include/pdal/util/Utils.hpp
    M io/bpf/BpfReader.hpp
    M io/bpf/BpfWriter.hpp
    M kernels/info/InfoKernel.cpp
    M kernels/info/InfoKernel.hpp
    M kernels/translate/CMakeLists.txt
    M kernels/translate/TranslateKernel.cpp
    M kernels/translate/TranslateKernel.hpp
    A package.sh
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/pcl/CMakeLists.txt
    A plugins/pcl/filters/GreedyProjectionFilter.cpp
    A plugins/pcl/filters/GreedyProjectionFilter.hpp
    A plugins/pcl/filters/GridProjectionFilter.cpp
    A plugins/pcl/filters/GridProjectionFilter.hpp
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/GroundFilter.hpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.cpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.hpp
    M plugins/pcl/filters/PCLBlock.cpp
    A plugins/pcl/filters/PoissonFilter.cpp
    A plugins/pcl/filters/PoissonFilter.hpp
    A plugins/pcl/filters/RadiusOutlierFilter.cpp
    A plugins/pcl/filters/RadiusOutlierFilter.hpp
    A plugins/pcl/filters/StatisticalOutlierFilter.cpp
    A plugins/pcl/filters/StatisticalOutlierFilter.hpp
    A plugins/pcl/filters/VoxelGridFilter.cpp
    A plugins/pcl/filters/VoxelGridFilter.hpp
    M plugins/pcl/pipeline/PCLPipeline.hpp
    M plugins/python/CMakeLists.txt
    M plugins/python/filters/CMakeLists.txt
    M plugins/python/filters/PredicateFilter.cpp
    M plugins/python/filters/PredicateFilter.hpp
    M plugins/python/filters/ProgrammableFilter.cpp
    M plugins/python/filters/ProgrammableFilter.hpp
    R plugins/python/plang/BufferedInvocation.cpp
    R plugins/python/plang/BufferedInvocation.hpp
    M plugins/python/plang/CMakeLists.txt
    R plugins/python/plang/Environment.cpp
    R plugins/python/plang/Environment.hpp
    R plugins/python/plang/Invocation.cpp
    R plugins/python/plang/Invocation.hpp
    A plugins/python/plang/Plang.cpp
    A plugins/python/plang/Plang.hpp
    R plugins/python/plang/Redirector.cpp
    R plugins/python/plang/Redirector.hpp
    R plugins/python/plang/Script.cpp
    R plugins/python/plang/Script.hpp
    M plugins/python/test/PLangTest.cpp
    M plugins/python/test/PredicateFilterTest.cpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    A python/CHANGES.txt
    A python/MANIFEST.in
    A python/README.rst
    A python/VERSION.txt
    A python/pdal/Pipeline.cpp
    A python/pdal/Pipeline.hpp
    M python/pdal/__init__.py
    A python/pdal/libpdalpython.pyx
    M python/pdal/pipeline_xml.py
    R python/pdal/test.py
    R python/pdal/version.py
    A python/setup.py
    A python/test/__init__.py
    A python/test/test_libpdal.py
    A python/test/test_pipeline.py
    M schemas/LAS.xsd
    M src/GlobalEnvironment.cpp
    M src/Kernel.cpp
    M src/KernelSupport.cpp
    M src/PipelineWriter.cpp
    M src/SpatialReference.cpp
    M src/XMLSchema.cpp
    A src/plang/Array.cpp
    A src/plang/BufferedInvocation.cpp
    A src/plang/CMakeLists.txt
    A src/plang/Environment.cpp
    A src/plang/Invocation.cpp
    A src/plang/Redirector.cpp
    A src/plang/Script.cpp
    M src/util/CMakeLists.txt
    M test/unit/XMLSchemaTest.cpp
    M test/unit/apps/pc2pcTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into lasperf
  Commit: f2bf939bcd5d43a5a738b4e0ac07342f1897d702
      https://github.com/PDAL/PDAL/commit/f2bf939bcd5d43a5a738b4e0ac07342f1897d702
  Date:   2015-09-17 (Thu, 17 Sep 2015)
  Changed paths:
    M doc/stages/readers.las.rst
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
  Fix chunking of LazPerf writer.
Add LazPerf writer test.
Add documentation regarding compressor/decompressor selection.
  Commit: 96f48c39a6884ccb8e4fe85a5d0270d6632addd6
      https://github.com/PDAL/PDAL/commit/96f48c39a6884ccb8e4fe85a5d0270d6632addd6
  Date:   2015-09-22 (Tue, 22 Sep 2015)
  Changed paths:
    M doc/metadata.rst
    A doc/stages/readers.gdal.rst
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M include/pdal/GDALUtils.hpp
    M io/CMakeLists.txt
    A io/gdal/CMakeLists.txt
    A io/gdal/GDALReader.cpp
    A io/gdal/GDALReader.hpp
    M io/ply/PlyReader.cpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M src/GDALUtils.cpp
    M src/StageFactory.cpp
  Log Message:
  Commit: fde27f0e5c3691730ed1e7c4ff940eadde08d477
      https://github.com/PDAL/PDAL/commit/fde27f0e5c3691730ed1e7c4ff940eadde08d477
  Date:   2015-09-23 (Wed, 23 Sep 2015)
  Changed paths:
  Log Message:
  Testing.
  Commit: 20db7d2c23e9db2fce149c00d44d3b53bf97f209
      https://github.com/PDAL/PDAL/commit/20db7d2c23e9db2fce149c00d44d3b53bf97f209
  Changed paths:
  Log Message:
  Testing.
  Commit: 6178bd346095bb9fb8f8525f809453aea41c989e
      https://github.com/PDAL/PDAL/commit/6178bd346095bb9fb8f8525f809453aea41c989e
  Changed paths:
  Log Message:
  Set correct initial offset for proper chunk size.
Remove debug.
  Commit: df358189c047898ecbca856e923f8270689c851f
      https://github.com/PDAL/PDAL/commit/df358189c047898ecbca856e923f8270689c851f
  Changed paths:
    M scripts/ci/before_install.sh
  Log Message:
  Test install of laszip
  Commit: e36e5fbf22d4ffb0fe0016baf93b42db7ad7dac8
      https://github.com/PDAL/PDAL/commit/e36e5fbf22d4ffb0fe0016baf93b42db7ad7dac8
  Changed paths:
  Log Message:
  Testing
  Commit: d93396dfb3f7996aeed618a19848e702543efe1f
      https://github.com/PDAL/PDAL/commit/d93396dfb3f7996aeed618a19848e702543efe1f
  Changed paths:
    M scripts/ci/script.sh
  Log Message:
  Testing
  Commit: 1ad9b65e7ca4f31c527711715db9cbd4c691327e
      https://github.com/PDAL/PDAL/commit/1ad9b65e7ca4f31c527711715db9cbd4c691327e
  Changed paths:
  Log Message:
  Testing
  Commit: 08c45fa0319d68154109af5046d293f7b1422ede
      https://github.com/PDAL/PDAL/commit/08c45fa0319d68154109af5046d293f7b1422ede
  Changed paths:
  Log Message:
  Testing
  Commit: 0ac26dd251e5f091abec2b34980ccf12ebe08f1e
      https://github.com/PDAL/PDAL/commit/0ac26dd251e5f091abec2b34980ccf12ebe08f1e
  Changed paths:
    A doc/stages/filters.statisticaloutlier.img1.png
    A doc/stages/filters.statisticaloutlier.img2.png
    M doc/stages/filters.statisticaloutlier.rst
    M include/pdal/Stage.hpp
    M plugins/pcl/filters/StatisticalOutlierFilter.cpp
    M src/Options.cpp
  Log Message:
  Commit: 0f3af6e181acfde175af53fe4932326118b797d3
      https://github.com/PDAL/PDAL/commit/0f3af6e181acfde175af53fe4932326118b797d3
  Changed paths:
  Log Message:
  LazPerf test depends on LasZip.
  Commit: 69aaa9e218e58349ad5443deb58a142dc2fa4ff0
      https://github.com/PDAL/PDAL/commit/69aaa9e218e58349ad5443deb58a142dc2fa4ff0
  Date:   2015-09-30 (Wed, 30 Sep 2015)
  Log Message:
  Merge branch 'lasperf'
  Commit: 05d69da580334d7e5db38351930c3e149a329c7b
      https://github.com/PDAL/PDAL/commit/05d69da580334d7e5db38351930c3e149a329c7b
  Changed paths:
  Log Message:
  Merge branch 'linkop'
Compare: https://github.com/PDAL/PDAL/compare/bbeddf418b4d...05d69da58033
More information about the pdal-commits mailing list
