[pdal-commits] [PDAL/PDAL] 843b99: wip readers.tindex
GitHub noreply at github.com
Fri Oct 2 14:54:57 PDT 2015
  Branch: refs/heads/readers.tindex
  Home:   https://github.com/PDAL/PDAL
  Commit: 843b99d5ce98eb1fb86c3157cd37d9d7174c80c1
      https://github.com/PDAL/PDAL/commit/843b99d5ce98eb1fb86c3157cd37d9d7174c80c1
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-10-02 (Fri, 02 Oct 2015)
  Changed paths:
    M include/pdal/GDALUtils.hpp
    M io/CMakeLists.txt
    A io/tindex/CMakeLists.txt
    A io/tindex/TIndexReader.cpp
    A io/tindex/TIndexReader.hpp
    M src/StageFactory.cpp
    A test/data/pipeline/tindex.xml
  Log Message:
  wip readers.tindex
  Commit: 169ab3994909ba0c563fa782a9120a7ffb03177c
      https://github.com/PDAL/PDAL/commit/169ab3994909ba0c563fa782a9120a7ffb03177c
  Changed paths:
    M io/tindex/TIndexReader.cpp
    M io/tindex/TIndexReader.hpp
    M test/data/pipeline/tindex.xml
  Log Message:
  wip readers.tindex working
  Commit: a0a937c6f751bdc1da33cdd9dcd74abb5132d23d
      https://github.com/PDAL/PDAL/commit/a0a937c6f751bdc1da33cdd9dcd74abb5132d23d
  Changed paths:
    M doc/stages/filters.ferry.rst
    M doc/stages/filters.range.rst
    M doc/stages/writers.bpf.rst
    M filters/ferry/FerryFilter.cpp
    M filters/ferry/FerryFilter.hpp
    M filters/range/RangeFilter.cpp
    M filters/range/RangeFilter.hpp
    M include/pdal/Kernel.hpp
    M include/pdal/util/Utils.hpp
    M io/bpf/BpfWriter.cpp
    M io/bpf/BpfWriter.hpp
    M kernels/translate/TranslateKernel.cpp
    M src/CMakeLists.txt
    M src/Kernel.cpp
    M test/data/filters/ferry.xml.in
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/RangeFilterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into readers.tindex
  Commit: 65d8b28e4850006234c07015423323ece59cac50
      https://github.com/PDAL/PDAL/commit/65d8b28e4850006234c07015423323ece59cac50
  Changed paths:
    A test/data/pipeline/tindex.xml.in
  Log Message:
  example for readers.tindex
  Commit: fe94ddab472bf5f9ac2984e90730dec917856fcb
      https://github.com/PDAL/PDAL/commit/fe94ddab472bf5f9ac2984e90730dec917856fcb
  Changed paths:
  Log Message:
  use readers.tindex if file extension is .tindex
Compare: https://github.com/PDAL/PDAL/compare/843b99d5ce98^...fe94ddab472b
More information about the pdal-commits mailing list
