[pdal-commits] [PDAL/PDAL] 0e6131: add capability to cull bad reprojection
GitHub noreply at github.com
Fri Oct 30 11:53:51 PDT 2015
  Branch: refs/heads/stream
  Home:   https://github.com/PDAL/PDAL
  Commit: 0e6131322861fc0286fd5d9067e028cc0d0136b3
      https://github.com/PDAL/PDAL/commit/0e6131322861fc0286fd5d9067e028cc0d0136b3
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-10-20 (Tue, 20 Oct 2015)
  Changed paths:
    M filters/reprojection/ReprojectionFilter.cpp
    M filters/reprojection/ReprojectionFilter.hpp
  Log Message:
  Commit: dddc40a3d34b6063723ef62878616fe84dd7b408
      https://github.com/PDAL/PDAL/commit/dddc40a3d34b6063723ef62878616fe84dd7b408
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M doc/stages/writers.las.rst
  Log Message:
  LasWriter doc update.
  Commit: 37cce0cd9c2d43d9e96554a0aaedc52280384b3e
      https://github.com/PDAL/PDAL/commit/37cce0cd9c2d43d9e96554a0aaedc52280384b3e
  Changed paths:
    M doc/stages/filters.range.rst
    M filters/range/RangeFilter.cpp
    M filters/range/RangeFilter.hpp
    M test/unit/filters/RangeFilterTest.cpp
  Log Message:
  Allow negation of ranges.
Close #1001
  Commit: 3b03118b42aebf2439d47066da306fe91c3f8c02
      https://github.com/PDAL/PDAL/commit/3b03118b42aebf2439d47066da306fe91c3f8c02
  Changed paths:
  Log Message:
  Change range negation character to '!' from '~'.
  Commit: 98450fce1cb520eb226037cc07b77b42a807868d
      https://github.com/PDAL/PDAL/commit/98450fce1cb520eb226037cc07b77b42a807868d
  Date:   2015-10-21 (Wed, 21 Oct 2015)
  Changed paths:
  Log Message:
  make transform() call simpler when we want to cull bad points
  Commit: 5093484fbfc08d2f7df4db690747ec63e5e5930f
      https://github.com/PDAL/PDAL/commit/5093484fbfc08d2f7df4db690747ec63e5e5930f
  Changed paths:
  Log Message:
  Merge pull request #1011 from PDAL/issues/1009-cull-bad-reprojection
add capability to cull bad reprojection #1009
  Commit: 5a3d73d73dfe769bdf6a9ec58a07a565ad0afb56
      https://github.com/PDAL/PDAL/commit/5a3d73d73dfe769bdf6a9ec58a07a565ad0afb56
  Date:   2015-10-23 (Fri, 23 Oct 2015)
  Changed paths:
    A doc/stages/filters.randomize.rst
    M doc/stages/filters.sort.rst
    M filters/CMakeLists.txt
    A filters/randomize/CMakeLists.txt
    A filters/randomize/RandomizeFilter.cpp
    A filters/randomize/RandomizeFilter.hpp
    M test/unit/CMakeLists.txt
    A test/unit/filters/RandomizeFilterTest.cpp
  Log Message:
  Randomize filter.
  Commit: b5533d267e531172e94f1e8386937c6cf5d29dae
      https://github.com/PDAL/PDAL/commit/b5533d267e531172e94f1e8386937c6cf5d29dae
  Changed paths:
    M filters/randomize/RandomizeFilter.cpp
    M test/unit/filters/RandomizeFilterTest.cpp
  Log Message:
  Look for FauxReader in the right place.
  Commit: 70d501fcc5c4b12d2543b55eeadeab59fa1e40d9
      https://github.com/PDAL/PDAL/commit/70d501fcc5c4b12d2543b55eeadeab59fa1e40d9
  Changed paths:
    M CMakeLists.txt
    M io/ply/CMakeLists.txt
    R vendor/rply-1.1.3/LICENSE
    R vendor/rply-1.1.3/etc/convert.c
    R vendor/rply-1.1.3/etc/dump.c
    R vendor/rply-1.1.3/etc/input.ply
    R vendor/rply-1.1.3/etc/sconvert.c
    R vendor/rply-1.1.3/manual/manual.html
    R vendor/rply-1.1.3/manual/reference.css
    R vendor/rply-1.1.3/manual/rply.png
    R vendor/rply-1.1.3/rply.c
    R vendor/rply-1.1.3/rply.h
    A vendor/rply-1.1.4/LICENSE
    A vendor/rply-1.1.4/etc/convert.c
    A vendor/rply-1.1.4/etc/dump.c
    A vendor/rply-1.1.4/etc/input.ply
    A vendor/rply-1.1.4/etc/sconvert.c
    A vendor/rply-1.1.4/manual/manual.html
    A vendor/rply-1.1.4/manual/reference.css
    A vendor/rply-1.1.4/manual/rply.png
    A vendor/rply-1.1.4/rply.c
    A vendor/rply-1.1.4/rply.h
    A vendor/rply-1.1.4/rplyfile.h
  Log Message:
  New rply version.
  Commit: aae5a5c8723d674179d9441106f30aaeff86586b
      https://github.com/PDAL/PDAL/commit/aae5a5c8723d674179d9441106f30aaeff86586b
  Author: Connor Manning <connor at hobu.co>
  Date:   2015-10-26 (Mon, 26 Oct 2015)
  Changed paths:
    M io/las/LasReader.cpp
  Log Message:
  Add all dimensions for LAS QuickInfo.
  Commit: 9cd9d7046a3a1e8c906df711ce019f761d20d4f2
      https://github.com/PDAL/PDAL/commit/9cd9d7046a3a1e8c906df711ce019f761d20d4f2
  Changed paths:
    A doc/stages/filters.divider.rst
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.nitf.rst
    A filters/divider/CMakeLists.txt
    A filters/divider/DividerFilter.cpp
    A filters/divider/DividerFilter.hpp
    A test/unit/filters/DividerFilterTest.cpp
  Log Message:
  Divider filter.
  Commit: 100caa48df8aa1bdf955d355e5529aff9c7e73a2
      https://github.com/PDAL/PDAL/commit/100caa48df8aa1bdf955d355e5529aff9c7e73a2
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: b8e8011a1ce355ce869545a6ba18242592d2633d
      https://github.com/PDAL/PDAL/commit/b8e8011a1ce355ce869545a6ba18242592d2633d
  Date:   2015-10-27 (Tue, 27 Oct 2015)
  Changed paths:
    M doc/Makefile
    A doc/_templates/layout.html
    R doc/_themes/bootstrap/bootstrap.js
    R doc/_themes/bootstrap/bootstrap.min.js
    R doc/_themes/bootstrap/indexsidebar.html
    R doc/_themes/bootstrap/static/bootstrap-default.css
    R doc/_themes/bootstrap/static/bootstrap-default.min.css
    R doc/_themes/bootstrap/static/bootstrap-dropdown.js
    R doc/_themes/bootstrap/static/bootstrap-engineauth.css
    R doc/_themes/bootstrap/static/bootstrap-engineauth.min.css
    R doc/_themes/bootstrap/static/bootstrap-responsive.css
    R doc/_themes/bootstrap/static/bootstrap-responsive.min.css
    R doc/_themes/bootstrap/static/bootstrap-sapling.css
    R doc/_themes/bootstrap/static/jquery.js
    R doc/_themes/bootstrap/static/sphinx-bootstrap.css
    M doc/api/cpp/bounds.rst
    A doc/api/cpp/filter.rst
    M doc/api/cpp/index.rst
    M doc/api/cpp/log.rst
    M doc/api/cpp/metadata.rst
    R doc/api/cpp/option.rst
    M doc/api/cpp/options.rst
    M doc/api/cpp/pointtable.rst
    M doc/api/cpp/pointview.rst
    M doc/api/cpp/reader.rst
    M doc/api/cpp/stage.rst
    M doc/api/cpp/writer.rst
    M doc/api/index.rst
    M doc/community.rst
    M doc/compilation/media/OSGeo4WInstallIConv.png
    M doc/compilation/unix.rst
    M doc/conf.py
    M doc/development/index.rst
    R doc/docs.rst
    M doc/faq.rst
    M doc/index.rst
    M doc/stages/filters.statisticaloutlier.rst
    M doc/stages/index.rst
    M doc/stages/readers.bpf.rst
    M doc/stages/readers.gdal.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.ply.rst
    M doc/stages/writers.geowave.rst
    M doc/tutorial/liblas_to_pdal.rst
    M doc/tutorial/pcl_ground.rst
    M doc/tutorial/reading.rst
    M doc/tutorial/using.rst
    M doc/tutorial/writing-filter.rst
    M doc/tutorial/writing-kernel.rst
    M doc/tutorial/writing-reader.rst
    M doc/tutorial/writing-writer.rst
    M doc/tutorial/writing.rst
    M doc/vagrant.rst
    M include/pdal/Stage.hpp
  Log Message:
  Documentation work. New theme and some organization.
  Commit: 2b65a65f1c5e86e9ddb019d0bfb568d81b0962b7
      https://github.com/PDAL/PDAL/commit/2b65a65f1c5e86e9ddb019d0bfb568d81b0962b7
  Changed paths:
    M io/faux/FauxReader.cpp
    M test/unit/io/faux/FauxReaderTest.cpp
  Log Message:
  Don't divide by zero.
Close #1015
  Commit: 8e89f2b6c6e4131758acd6ffda42ecc65b6eca16
      https://github.com/PDAL/PDAL/commit/8e89f2b6c6e4131758acd6ffda42ecc65b6eca16
  Changed paths:
    M doc/Makefile
    M doc/api/index.rst
    M doc/community.rst
    M doc/conf.py
    R doc/docs.rst
    M doc/faq.rst
    M doc/index.rst
    M doc/vagrant.rst
  Log Message:
  Commit: 4922ea9542dc2114a8b5ee572340bc4439e6a9c1
      https://github.com/PDAL/PDAL/commit/4922ea9542dc2114a8b5ee572340bc4439e6a9c1
  Date:   2015-10-28 (Wed, 28 Oct 2015)
  Changed paths:
    M doc/conf.py
    M doc/stages/filters.chipper.rst
  Log Message:
  cull top links for shorter heading on website
  Commit: 72e68ccf65b559ef5a8c82c42b5b534383c99bbb
      https://github.com/PDAL/PDAL/commit/72e68ccf65b559ef5a8c82c42b5b534383c99bbb
  Changed paths:
    A doc/stages/ranges.rst
  Log Message:
  Have range filter support multiple ranges for each dimension.
Use simple and consistent logical arrangement of ranges.
Close #1014
  Commit: 6a248326d2161fc228ce56c02e3065e91e5e96fc
      https://github.com/PDAL/PDAL/commit/6a248326d2161fc228ce56c02e3065e91e5e96fc
  Changed paths:
    M doc/stages/ranges.rst
  Log Message:
  Fix range doc.
  Commit: 13d3c7f6beac5f9899ff0bd22a1113583eb6fb01
      https://github.com/PDAL/PDAL/commit/13d3c7f6beac5f9899ff0bd22a1113583eb6fb01
  Changed paths:
    M CMakeLists.txt
    M doc/Makefile
    M doc/api/index.rst
    M doc/community.rst
    M doc/conf.py
    R doc/docs.rst
    M doc/faq.rst
    M doc/index.rst
    M doc/vagrant.rst
    M include/pdal/PointLayout.hpp
    M include/pdal/PointTable.hpp
    M io/faux/FauxReader.hpp
    M src/Stage.cpp
    R test/data/logs/logtest.txt
    M test/unit/LogTest.cpp
    M test/unit/StreamingTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into stream
  Commit: a6222e3af98c9774dec9347d2a0cc60245376cb5
      https://github.com/PDAL/PDAL/commit/a6222e3af98c9774dec9347d2a0cc60245376cb5
  Changed paths:
    M src/Stage.cpp
  Log Message:
  Filtered streaming works.
Update RangeFilter to streaming.
Update FauxReader to streaming.
Add real streaming test.
  Commit: 744d90c112778d8f453ad44ef4f8b4c6593fb63f
      https://github.com/PDAL/PDAL/commit/744d90c112778d8f453ad44ef4f8b4c6593fb63f
  Date:   2015-10-30 (Fri, 30 Oct 2015)
  Changed paths:
    M io/sbet/SbetReader.cpp
    M io/sbet/SbetReader.hpp
  Log Message:
  Pass PointRef as reference. (Need a better name).
Compare: https://github.com/PDAL/PDAL/compare/c3aa7576443c...744d90c11277
More information about the pdal-commits mailing list
