[pdal-commits] [PDAL/PDAL] fde089: Set and use m_srs variable in LasWriter.
GitHub noreply at github.com
Sat Sep 5 05:37:54 PDT 2015
  Branch: refs/heads/python-extension-module
  Home:   https://github.com/PDAL/PDAL
  Commit: fde0892ad29cfa10e736c050d8c5bd6b24a983c5
      https://github.com/PDAL/PDAL/commit/fde0892ad29cfa10e736c050d8c5bd6b24a983c5
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-08-25 (Tue, 25 Aug 2015)
  Changed paths:
    M io/las/LasWriter.cpp
    M io/las/LasWriter.hpp
    M test/unit/io/las/LasWriterTest.cpp
  Log Message:
Add tests for set SRS.
Close #981
  Commit: c6956bd02963a408f087d35bd9d0980203a4345d
      https://github.com/PDAL/PDAL/commit/c6956bd02963a408f087d35bd9d0980203a4345d
  Changed paths:
  Log Message:
  Don't run SRS tests without Geotiff.
  Commit: aa843f5f5f409d0ef853411dddc2ef89c64e3452
      https://github.com/PDAL/PDAL/commit/aa843f5f5f409d0ef853411dddc2ef89c64e3452
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-08-30 (Sun, 30 Aug 2015)
  Changed paths:
  Log Message:
  Merge branch 'master' into python-extension-module
  Commit: 5d411931b606924f6c1c0e4264621d153d3d985e
      https://github.com/PDAL/PDAL/commit/5d411931b606924f6c1c0e4264621d153d3d985e
  Date:   2015-08-31 (Mon, 31 Aug 2015)
  Changed paths:
    A include/pdal/plang/Array.hpp
    M include/pdal/plang/Environment.hpp
    M plugins/python/filters/PredicateFilter.cpp
    M plugins/python/test/PLangTest.cpp
    M plugins/python/test/PredicateFilterTest.cpp
    A src/plang/Array.cpp
    M src/plang/CMakeLists.txt
    M src/plang/Environment.cpp
    M src/plang/Invocation.cpp
  Log Message:
  remove custom plang exception, just use pdal::pdal_error
  Commit: b9c69c47b9a1f831befe87c520f561b497c89853
      https://github.com/PDAL/PDAL/commit/b9c69c47b9a1f831befe87c520f561b497c89853
  Changed paths:
    M doc/stages/writers.las.rst
    M include/pdal/Metadata.hpp
    M include/pdal/Options.hpp
    M include/pdal/PointTable.hpp
    M include/pdal/pdal_types.hpp
    M include/pdal/util/Utils.hpp
    M io/las/CMakeLists.txt
    A io/las/HeaderVal.hpp
    M io/las/LasReader.cpp
    M io/las/LasReader.hpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M src/PointTable.cpp
    M src/Writer.cpp
    M src/util/Utils.cpp
    A test/data/las/4_1.las
    A test/data/las/4_6.las
    M test/unit/io/sbet/SbetReaderTest.cpp
  Log Message:
  New forwarding syntax.
  Commit: be392c656fa65590fc36c6303f937991b34fc1bc
      https://github.com/PDAL/PDAL/commit/be392c656fa65590fc36c6303f937991b34fc1bc
  Changed paths:
    M cmake/examples/hobu-config.sh
    M doc/stages/index.rst
    A doc/stages/readers.mrsid.rst
    M kernels/translate/TranslateKernel.cpp
    M plugins/cpd/CMakeLists.txt
    M plugins/cpd/kernel/Cpd.cpp
    M plugins/cpd/kernel/Cpd.hpp
    M plugins/cpd/test/CpdKernelTest.cpp
    M plugins/mrsid/CMakeLists.txt
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/mrsid/io/MrsidReader.hpp
    A plugins/mrsid/test/MrsidTest.cpp
    M src/StageFactory.cpp
    A test/data/mrsid/Tetons_200k.las.sid
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: a80911c7b4418792c48db5d07411074505b61055
      https://github.com/PDAL/PDAL/commit/a80911c7b4418792c48db5d07411074505b61055
  Date:   2015-09-01 (Tue, 01 Sep 2015)
  Changed paths:
    M plugins/python/filters/ProgrammableFilter.cpp
  Log Message:
  Revert "Revert "control initialization of plang::Environment""
This reverts commit d3791d0c5dba5368dc68ae22ab062efc716c5e48.
  Commit: f27b96785d40f6241a3178886d1d32589778e151
      https://github.com/PDAL/PDAL/commit/f27b96785d40f6241a3178886d1d32589778e151
  Changed paths:
    M io/las/HeaderVal.hpp
  Log Message:
  Diagnostic fixes for old GCC.
  Commit: 06cdef0565ff799f460af88f28121e2703c52862
      https://github.com/PDAL/PDAL/commit/06cdef0565ff799f460af88f28121e2703c52862
  Date:   2015-09-02 (Wed, 02 Sep 2015)
  Changed paths:
    M src/Writer.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into python-extension-module
  Commit: 7d5855c418c1569d1ed57921a5734193fcbdf47b
      https://github.com/PDAL/PDAL/commit/7d5855c418c1569d1ed57921a5734193fcbdf47b
  Changed paths:
    M CMakeLists.txt
    M PDALConfig.cmake.in
    M apps/CMakeLists.txt
    M cmake/macros.cmake
    M plugins/python/plang/CMakeLists.txt
    M src/CMakeLists.txt
    A src/libpdalcpp
    M test/unit/PointTableTest.cpp
  Log Message:
  Use linker script to avoid linking two libraries.
Linker scripts don't work on OSX :(  Use --reexport_library instead.
Actually use custom PointTable in test.
Close #977
  Commit: 397582adb367ad63e22667925c32828c52663865
      https://github.com/PDAL/PDAL/commit/397582adb367ad63e22667925c32828c52663865
  Changed paths:
    M include/pdal/PointView.hpp
    M include/pdal/plang/Array.hpp
    M python/MANIFEST.in
    M python/libpdalpython/Pipeline.cpp
    M python/libpdalpython/Pipeline.hpp
    M python/libpdalpython/libpdalpython.pyx
    M python/setup.py
    M python/test/__init__.py
    M python/test/test_libpdal.py
    M src/plang/Array.cpp
  Log Message:
  wip
  Commit: 81f6671e3a60d775aca368e731081a3ccbb53bf3
      https://github.com/PDAL/PDAL/commit/81f6671e3a60d775aca368e731081a3ccbb53bf3
  Date:   2015-09-03 (Thu, 03 Sep 2015)
  Changed paths:
  Log Message:
  wip single array
  Commit: de3b2b6603b89d6a8bbcd536cfd6384b20095e0d
      https://github.com/PDAL/PDAL/commit/de3b2b6603b89d6a8bbcd536cfd6384b20095e0d
  Changed paths:
  Log Message:
  wip single array
  Commit: eaaaae38319a4feff231fe91d7cd292b36b0cdc4
      https://github.com/PDAL/PDAL/commit/eaaaae38319a4feff231fe91d7cd292b36b0cdc4
  Changed paths:
  Log Message:
  working but unaligned
  Commit: dcef66cebb9ea14dec3843f9c3447a3c38a3af36
      https://github.com/PDAL/PDAL/commit/dcef66cebb9ea14dec3843f9c3447a3c38a3af36
  Changed paths:
  Log Message:
  Add support for VLR forwarding.
  Commit: 3f74ffd353a2819188d58204a4d09cfb0ba0ad53
      https://github.com/PDAL/PDAL/commit/3f74ffd353a2819188d58204a4d09cfb0ba0ad53
  Changed paths:
  Log Message:
  array fetching working
  Commit: 38f7267862968580ceb26216f5ed9148fa4aeb10
      https://github.com/PDAL/PDAL/commit/38f7267862968580ceb26216f5ed9148fa4aeb10
  Date:   2015-09-04 (Fri, 04 Sep 2015)
  Changed paths:
  Log Message:
  Remove Utils::saturation_cast.
  Commit: f4a326a52f854b611f4eb0fdcd65ee7aca4725f4
      https://github.com/PDAL/PDAL/commit/f4a326a52f854b611f4eb0fdcd65ee7aca4725f4
  Changed paths:
  Log Message:
  working implementation to read PDAL pipeline -> numpy Array
  Commit: 7c3be8040b52bdd0746e1c9ab3251098f02be757
      https://github.com/PDAL/PDAL/commit/7c3be8040b52bdd0746e1c9ab3251098f02be757
  Changed paths:
  Log Message:
  Revert "Revert "Revert "control initialization of plang::Environment"""
This reverts commit a80911c7b4418792c48db5d07411074505b61055.
  Commit: 0ed8ba13aa83c7f262a72a9f0163b5e4b4bc5772
      https://github.com/PDAL/PDAL/commit/0ed8ba13aa83c7f262a72a9f0163b5e4b4bc5772
  Changed paths:
  Log Message:
  Revert "Revert "Revert "Revert "control initialization of plang::Environment""""
This reverts commit 7c3be8040b52bdd0746e1c9ab3251098f02be757.
  Commit: 11cfdf497cad320ec304a5728c823b5420dc85bb
      https://github.com/PDAL/PDAL/commit/11cfdf497cad320ec304a5728c823b5420dc85bb
  Changed paths:
  Log Message:
  cython interface cleanups
  Commit: 95bd0876f13dc737f49e333b5e7d059dd4a6f154
      https://github.com/PDAL/PDAL/commit/95bd0876f13dc737f49e333b5e7d059dd4a6f154
  Changed paths:
    M plugins/python/filters/ProgrammableFilter.hpp
    M plugins/python/plang/BufferedInvocation.cpp
    M plugins/python/plang/BufferedInvocation.hpp
    M plugins/python/plang/Invocation.cpp
    M plugins/python/plang/Invocation.hpp
    A plugins/python/plang/Plang.cpp
    A plugins/python/plang/Plang.hpp
    M src/SpatialReference.cpp
  Log Message:
  Metadata for python filters.
  Commit: 2a6effce4f048d44c39a3d86e8809f278f25e162
      https://github.com/PDAL/PDAL/commit/2a6effce4f048d44c39a3d86e8809f278f25e162
  Date:   2015-09-05 (Sat, 05 Sep 2015)
  Changed paths:
    M CMakeLists.txt
    M include/pdal/plang/BufferedInvocation.hpp
    M include/pdal/plang/Invocation.hpp
    A plugins/python/plang/CMakeLists.txt
    A src/libpdalcpp
    M src/plang/BufferedInvocation.cpp
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/d3791d0c5dba...2a6effce4f04
More information about the pdal-commits mailing list
