[pdal-commits] [PDAL/PDAL] 170cc9: Make some PCL functions accessible as filters
GitHub noreply at github.com
Mon Sep 14 18:45:10 PDT 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 170cc9974bed1d3e7f421ff7000ceca35e8772d6
      https://github.com/PDAL/PDAL/commit/170cc9974bed1d3e7f421ff7000ceca35e8772d6
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-09-14 (Mon, 14 Sep 2015)
  Changed paths:
    M doc/conf.py
    A doc/stages/filters.greedyprojection.rst
    A doc/stages/filters.gridprojection.rst
    A doc/stages/filters.ground.rst
    A doc/stages/filters.movingleastsquares.rst
    A doc/stages/filters.poisson.rst
    A doc/stages/filters.radiusoutlier.rst
    A doc/stages/filters.statisticaloutlier.rst
    A doc/stages/filters.voxelgrid.rst
    M doc/stages/index.rst
    M plugins/pcl/CMakeLists.txt
    A plugins/pcl/filters/GreedyProjectionFilter.cpp
    A plugins/pcl/filters/GreedyProjectionFilter.hpp
    A plugins/pcl/filters/GridProjectionFilter.cpp
    A plugins/pcl/filters/GridProjectionFilter.hpp
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/GroundFilter.hpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.cpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.hpp
    M plugins/pcl/filters/PCLBlock.cpp
    A plugins/pcl/filters/PoissonFilter.cpp
    A plugins/pcl/filters/PoissonFilter.hpp
    A plugins/pcl/filters/RadiusOutlierFilter.cpp
    A plugins/pcl/filters/RadiusOutlierFilter.hpp
    A plugins/pcl/filters/StatisticalOutlierFilter.cpp
    A plugins/pcl/filters/StatisticalOutlierFilter.hpp
    A plugins/pcl/filters/VoxelGridFilter.cpp
    A plugins/pcl/filters/VoxelGridFilter.hpp
    M plugins/pcl/pipeline/PCLPipeline.hpp
  Log Message:
* Statistical Outlier
* Radius Outlier
* Voxel Grid
* Moving Least Squares
* Grid Projection
* Poisson Surface Reconstruction
* Greedy Projection Triangulation
Enable pngmath extension within Sphinx.
Glob readers, writers, and filters in stage documentation.
  Commit: 6a9112f028e5cff4a3f997f0403486cda5b71f82
      https://github.com/PDAL/PDAL/commit/6a9112f028e5cff4a3f997f0403486cda5b71f82
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M doc/conf.py
  Log Message:
  Merge pull request #995 from PDAL/pcl-stuff-as-filters
Compare: https://github.com/PDAL/PDAL/compare/b9490d5e73a9...6a9112f028e5
More information about the pdal-commits mailing list
