[pdal-commits] [PDAL/PDAL] edffaf: start refactoring GDAL raster support
GitHub noreply at github.com
Thu Sep 17 10:38:38 PDT 2015
  Branch: refs/heads/gdal-reader
  Home:   https://github.com/PDAL/PDAL
  Commit: edffafa076a0acc452866a6d28a91eb196676489
      https://github.com/PDAL/PDAL/commit/edffafa076a0acc452866a6d28a91eb196676489
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-09-15 (Tue, 15 Sep 2015)
  Changed paths:
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M include/pdal/GDALUtils.hpp
    M io/CMakeLists.txt
    A io/gdal/CMakeLists.txt
    A io/gdal/GDALReader.cpp
    A io/gdal/GDALReader.hpp
    M io/ply/PlyReader.cpp
    M src/GDALUtils.cpp
  Log Message:
  Commit: 8de621df25e7a4b45193a311218e28f56d80e09b
      https://github.com/PDAL/PDAL/commit/8de621df25e7a4b45193a311218e28f56d80e09b
  Changed paths:
    M doc/conf.py
    M doc/docs.rst
    M doc/stages/filters.ferry.rst
    A doc/stages/filters.greedyprojection.rst
    A doc/stages/filters.gridprojection.rst
    A doc/stages/filters.ground.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.mortonorder.rst
    A doc/stages/filters.movingleastsquares.rst
    A doc/stages/filters.poisson.rst
    A doc/stages/filters.radiusoutlier.rst
    M doc/stages/filters.splitter.rst
    A doc/stages/filters.statisticaloutlier.rst
    M doc/stages/filters.stats.rst
    A doc/stages/filters.voxelgrid.rst
    M doc/stages/index.rst
    M doc/stages/readers.buffer.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.null.rst
    M doc/stages/writers.text.rst
    M doc/tutorial/liblas_to_pdal.rst
    M doc/tutorial/overview.rst
    M doc/tutorial/pcl_spec.rst
    M doc/tutorial/reading.rst
    M doc/vagrant.rst
    M include/pdal/Kernel.hpp
    M include/pdal/KernelSupport.hpp
    M include/pdal/PipelineManager.hpp
    M kernels/info/InfoKernel.cpp
    M kernels/info/InfoKernel.hpp
    M plugins/pcl/CMakeLists.txt
    A plugins/pcl/filters/GreedyProjectionFilter.cpp
    A plugins/pcl/filters/GreedyProjectionFilter.hpp
    A plugins/pcl/filters/GridProjectionFilter.cpp
    A plugins/pcl/filters/GridProjectionFilter.hpp
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/GroundFilter.hpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.cpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.hpp
    M plugins/pcl/filters/PCLBlock.cpp
    A plugins/pcl/filters/PoissonFilter.cpp
    A plugins/pcl/filters/PoissonFilter.hpp
    A plugins/pcl/filters/RadiusOutlierFilter.cpp
    A plugins/pcl/filters/RadiusOutlierFilter.hpp
    A plugins/pcl/filters/StatisticalOutlierFilter.cpp
    A plugins/pcl/filters/StatisticalOutlierFilter.hpp
    A plugins/pcl/filters/VoxelGridFilter.cpp
    A plugins/pcl/filters/VoxelGridFilter.hpp
    M plugins/pcl/pipeline/PCLPipeline.hpp
    M src/Kernel.cpp
    M src/KernelSupport.cpp
  Log Message:
  Merge branch 'master' into gdal-reader
  Commit: 1c82c17e263617867a8930c60a9d7c6c1d17d58c
      https://github.com/PDAL/PDAL/commit/1c82c17e263617867a8930c60a9d7c6c1d17d58c
  Changed paths:
    M src/GDALUtils.cpp
  Log Message:
  single pixel reading for gdal::Raster
  Commit: 0c7abc0597489a1852cfbab51fdde756324924f6
      https://github.com/PDAL/PDAL/commit/0c7abc0597489a1852cfbab51fdde756324924f6
  Changed paths:
    M src/GDALUtils.cpp
  Log Message:
  GDAL bands count from 1
  Commit: cf6b07b75cbf86bd18d9319468f559942f5e8eff
      https://github.com/PDAL/PDAL/commit/cf6b07b75cbf86bd18d9319468f559942f5e8eff
  Changed paths:
  Log Message:
  refactor filters.colorization to use gdal::Raster
  Commit: 5f3c2e9dacf821ebb7e63410d7fbfa14e1102da5
      https://github.com/PDAL/PDAL/commit/5f3c2e9dacf821ebb7e63410d7fbfa14e1102da5
  Changed paths:
  Log Message:
  reference tyop
  Commit: 237b0eeb442101dbd02d1fffeefa1e2fcc5a5fd5
      https://github.com/PDAL/PDAL/commit/237b0eeb442101dbd02d1fffeefa1e2fcc5a5fd5
  Date:   2015-09-17 (Thu, 17 Sep 2015)
  Changed paths:
    M io/gdal/GDALReader.cpp
    M io/gdal/GDALReader.hpp
    M src/GDALUtils.cpp
    M src/StageFactory.cpp
  Log Message:
  implement readers.gdal to read raster sources as point clouds
  Commit: 04920b4b9ad91ddb2a6af543623794fa579fc82b
      https://github.com/PDAL/PDAL/commit/04920b4b9ad91ddb2a6af543623794fa579fc82b
  Changed paths:
    A doc/stages/readers.gdal.rst
  Log Message:
  docs for readers.gdal
  Commit: 0b726716ff6901056c9c1b7af6c6d6e725ada81a
      https://github.com/PDAL/PDAL/commit/0b726716ff6901056c9c1b7af6c6d6e725ada81a
  Changed paths:
    M src/GDALUtils.cpp
  Log Message:
  read row/col instead of col/row. Make sure to not read junk after done with block data
Compare: https://github.com/PDAL/PDAL/compare/edffafa076a0^...0b726716ff69
More information about the pdal-commits mailing list
